97 Accord turns over but wont start
Old 09-10-2007, 07:49 PM
dmdasalla's Avatar
Default 97 Accord turns over but wont start
We tried replacing the distributor 3 times, got all new plug wires, and we still aren't getting any spark. We are testing the spark by touching the threads of the plug to the block, but we don't see any spark at all. I doubt all four plugs went out at the same time. Is there anything else that anyone can suggest checking?
Old 09-11-2007, 04:59 PM
dmdasalla's Avatar
Default Re: 97 Accord turns over but wont start (dmdasalla)
bump. anything at all?
Old 09-11-2007, 06:03 PM
H22_aCCoRd_07's Avatar
any codes????
Old 09-11-2007, 11:03 PM
dmdasalla's Avatar
the engine check light isn't on and we don't have a scanner, if thats the kinda codes ur talkin about. Idk if i can use a paper clip and just jump the wires like i can on my teg, but if you think that would yield any results, i could try. I just need to know where the wires are.
Old 09-12-2007, 04:15 AM
Duane_in_Japan's Avatar
Blk / Yel wire at distributor should have 12 volts with key on. There is no fuse protecting the distributor, power comes from the ignition switch. I show several wire diagrams based on which Accord (DX, LX.....) and which engine please. How many wires on the distributor harness.
Old 09-14-2007, 07:50 AM
dmdasalla's Avatar
Default Re: 97 Accord turns over but wont start (Duane_in_Japan)
Its a DX. Its my friends car, so I'll go over there today and check the other stuff. Thanks though
Old 09-14-2007, 11:06 AM
Mangotreemechanic's Avatar
Check whether the distributor is getting electrical power. Info is given by Duane. Is your coil and/or igniter internal or external?
samedure
03-22-2016 12:44 PM
gizmo jdm
11-14-2011 04:29 AM
linhguy
14
05-06-2009 09:29 PM
Jammersplace
17
01-29-2006 04:11 PM
ELHatchyBlanco
03-16-2004 09:57 AM
Quick Reply: 97 Accord turns over but wont start
