Old 09-06-2007, 12:05 PM   #1
drcain
drcain's Avatar
Default Need torque specs! 1997 Accord!
Can anyone help me get the Torque Specs for a 1997 Honda Accord? I need them for the upper and lower ball joints as well as the tie rod ends.
Thank you!
drcain is offline   Reply With Quote
Old 09-09-2007, 10:34 AM   #2
offcamber
offcamber's Avatar
Default Re: Need torque specs! 1997 Accord! (drcain)
sorry, don't know, but go to helminc.com and buy a repair manual if you plan to continue to mod/repair your car, or for now try going to your local auto parts store to see if they have it. you can also see if your local library has the "alldata" database.
offcamber is offline   Reply With Quote
Old 09-10-2007, 03:41 PM   #3
The-Kid
The-Kid's Avatar
Send a message via AIM to The-Kid
Default Re: Need torque specs! 1997 Accord! (offcamber)
This is from the Haynes Manual for a 94-97 Accord...
*ALL IN FT lbs
(front)
Upper control arm ball joint nut=32
Upper control arm pivot bolt/nut=22
Steering knuckle lower ball joint but=40
Lower control arm inner pivot bolt=40
Tie-rod end to steering knuckle nut=32
-96 Honda Accord EX Coupe FOR SALE AS OF 3/23/13
-02 Acura RSX Base(K&N SRI, Tanabe Strut bar, Strup Headers)
-09 Acura RL Tech
The-Kid is offline   Reply With Quote
94, 9497, 96, accord, arm, bolt, control, end, honda, outer, pivot, rod, specs, tie, torque, upper
