H.I.D. fuse keeps blowing???????
Old 09-05-2007, 04:23 PM
jdmturboitr's Avatar
Default H.I.D. fuse keeps blowing???????
I have a set of Xenon(I think) hid's and the damn fuse keeps blowing bout every 3-4 days. just pops it. I checked to make sure there wasnt anything rubbing any of the wires or anything wrong with the ballasts but they seem fine. I put the new fuse in and they are good to go for a few more days. anyone? help?
Old 09-05-2007, 04:59 PM
Naruto's Avatar
Default Re: H.I.D. fuse keeps blowing??????? (jdmturboitr)
Perhaps you need a larger amp fuse. I know when I put in the JDM OEM HID Type R headlight assemblies on mine, it kept doing the same crap til I put in a 30 amp.
If that's not the case, maybe you have a short somewhere? Bad ground maybe? I would check all of the wiring if the larger fuse doesn't work.
Old 09-05-2007, 05:08 PM
rdssk8rcs1's Avatar
Default Re: H.I.D. fuse keeps blowing??????? (Naruto)
is it teh right amp fuse for teh circuit? I would not recomend putting a larger amp fuse if its not sapposed to be there, wouldnt want to risk ruining the HIDs ballast or any other peice of the kit. Check and make sure your alternator is charging at the correct voltage.
Old 09-05-2007, 05:21 PM
as far as the correct size of fuse........how do I find out if it is correct? It is the fuse that came with the kit. It was givin to me by my wife as a birthday gift but ill see if I can find out where she got them from.
Old 09-05-2007, 05:22 PM
oh and yea, would rather keep replacing fuses instead of a bulb or ballast. hehe
Old 09-05-2007, 05:23 PM
1Point8DC2's Avatar
Default Re: H.I.D. fuse keeps blowing??????? (rdssk8rcs1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdssk8rcs1 &raquo;</TD></TR><TR><TD CLASS="quote">is it teh right amp fuse for teh circuit? I would not recomend putting a larger amp fuse if its not sapposed to be there, wouldnt want to risk ruining the HIDs ballast or any other peice of the kit. Check and make sure your alternator is charging at the correct voltage.</TD></TR></TABLE>
fuses protect wire nothing else.. same thing for breakers in a house. DO NOT increase fuse amperage unless you are positive that the wire can handle the load. you'll end up with a bigger problem if you aren't careful.
Old 09-05-2007, 05:32 PM
Default Re: H.I.D. fuse keeps blowing??????? (1Point8DC2)
my thoughts exactly. thanx fellas. any other ides?
Old 09-05-2007, 05:36 PM
alain401's Avatar
maybe need a bigger fuse or make show theres not expose wires
Old 09-05-2007, 06:18 PM
keeks707's Avatar
Well in the kits u buy online..they state that they recomend you using a larger Fuse! so if its a 15a fuse...try a 20 or even a 25!
Old 09-05-2007, 06:33 PM
TemjinX2's Avatar
blown fuses usually means your grounding out some where. check all your wiring. ballasts, the harness.
i wouldnt add a higher amp fuse until you inspected all the wiring. Adding more current to exposed wires are usually a bad idea.
Old 09-05-2007, 07:10 PM
-Darren-'s Avatar
did you hook up a relay with those?
Old 09-05-2007, 07:32 PM
Default Re: H.I.D. fuse keeps blowing??????? (-Darren-)
relay? umm the kit stated just a plug n play. so i just hooked it up color coded wise.
Old 09-05-2007, 07:34 PM
I already checked all the wires and there is nothing exposed or anything.
Old 09-05-2007, 09:10 PM
jasonjai's Avatar
did you mix up the polarity?
Old 09-05-2007, 10:21 PM
TemjinX2's Avatar
you should have a separate harness connected to the battery and ballast. The stock wiring can't take the amount of amps a ballast uses initially when you first turn them on.
It'll eventually fry your stock head light harness
just a recommendation.
Old 09-06-2007, 06:11 AM
jetblackhybrid's Avatar
Default Re: (alain401)
DO NOT use a bigger fuse! those HIDs are made to function correctly with the fuse it came with. check your connections and your grounds, if you are using a kit tht uses a seperate ground.
Old 09-06-2007, 06:20 AM
PatrickGSR94's Avatar
HID ballasts draw less current than the stock halogen headlights. However, there is a current spike for a split-second when the ballasts are first fired. This is the reason your fuses are blowing.
Stock Integra headlights have a 10A fuse for each low beam. Way back when I installed my old HID kit, I replaced the 10A fuses with 20A fuses, and I never had a problem.
But if you really want the best setup, you need to wire up custom headlight harnesses with relays. Put 20A fuses on the wires coming off the battery and going to the ballasts, and then you can keep the stock 10A fuses under the dashboard since they will only be switching the relays. I did this when I switched to my HID projector retrofit instead of the POS HID kit, which is junk in the factory Integra projectors.
Old 09-06-2007, 06:10 PM
polarity????? ummmmm ok? dont know what that is brah. please explain.
Old 09-06-2007, 06:11 PM
dont know about all this re-wiring and stuff. im not to handy when it comes to elecrical stuff hehe
Old 09-06-2007, 11:04 PM
keeks707's Avatar
I also just switched To a bigger fuse and i never had a problem plus..it is recomended if you were to read the directions!
Old 09-07-2007, 03:44 AM
* B A N N E D *
street dream gsr's Avatar
Default Re: (keeks707)
i had to change my 10s to a 20. it blew the 10amp the moment i turned the lights on. never had a problem since.
Old 09-07-2007, 04:07 AM
Jon D's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetblackhybrid &raquo;</TD></TR><TR><TD CLASS="quote">DO NOT use a bigger fuse! those HIDs are made to function correctly with the fuse it came with. </TD></TR></TABLE>
WRONG!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">HID ballasts draw less current than the stock halogen headlights. However, there is a current spike for a split-second when the ballasts are first fired. This is the reason your fuses are blowing.
CORRECT!
Old 09-08-2007, 10:09 AM
my kit didnt come with any directions. It came with 7.5 amp fuses. should I maybe go with a 10amp or so?
Old 09-09-2007, 05:40 AM
Default Re: (jdmturboitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmturboitr &raquo;</TD></TR><TR><TD CLASS="quote">my kit didnt come with any directions. It came with 7.5 amp fuses. should I maybe go with a 10amp or so? </TD></TR></TABLE>
lol what the crap?? Stock headlights use 10 amp fuses. You will need at least 15 or 20 amps to handle the power spike when the ballasts first come on.
monsterCHILD
01-06-2011 04:28 PM
AF-b16a1
06-22-2004 10:31 PM
Bucktown
Audio / Security / Video
03-08-2004 06:11 PM
specv5150
02-23-2004 05:26 AM
AutoXsi2000
09-30-2002 07:38 PM
Quick Reply: H.I.D. fuse keeps blowing???????
