GSR codes? Need help!
Old 09-02-2007, 03:35 PM
96GS-R-Kaden's Avatar
Default GSR codes? Need help!
First off, my 96 GSR wont rev past 3500rpms... Check engine light is on and these are all the codes I got...
P0335--Crank shaft position sensor A Circuit malfunction
P0336--Crank shaft position sensor A CKT range/performance
P1337--CSF SENSOR NO SIGNAL--DONT KNOW WHAT CSF IS?
P0453--EVAP emission control system pres sensor high
P0450--EVAP emission control system pres sensor fault
Dont understand these codes to much and was wondering if someone could translate it to english for me.
Old 09-03-2007, 06:11 AM
Default Re: GSR codes? Need help! (96GS-R-Kaden)
I know there has to be an expert somewhere here...
Old 04-12-2008, 04:43 AM
Anyone can help with some of these codes?
Old 04-12-2008, 05:58 AM
Daisy... Daisy...
Dogginator's Avatar
I do not know off of the top of my head. Search google for "hondahookup manuals" and you will find a great resource.
Old 04-12-2008, 10:18 AM
H22powered_94teg's Avatar
- more than likey you have a short to ground. or your sensor has gone bad.
Does your CEL flash when? if it does how many times does it flash, cause the number of times it flashes and the stops mean different thing with these codes.
P1337--CSF SENSOR NO SIGNAL--DONT KNOW WHAT CSF IS?= usually the 1337 codes are manufacture specific codes. I am trying to see if I have everseen this code at work before.
And I will check our Honda diagnostic computer and let you know about the other two havent reallseen them b4.
Old 04-12-2008, 11:49 AM
Daisy... Daisy...
Dogginator's Avatar
Code 1337 is the CKF (crankshaft speed fluctuation) sensor. Your 1996 may still be under warranty. Check out this thread:
https://honda-tech.com/zerothread/1528650
Is your car modified or stock?
Old 04-13-2008, 12:48 PM
Default Re: GSR codes? Need help! (Dogginator)
My car is completly stock for the exception of a cheap intake and a typeR transmission.
Old 04-13-2008, 08:00 PM
MrViet's Avatar
Your car is in "Limp" mode. your car all busted up. go to a mechanic. before you screw it up and vtec turns into notec.
Old 04-14-2008, 03:14 PM
I am not some ricer kid who doesn't know what he's doing. I am not driving the car nor do i plan to until I can pin-point a problem myself instead of over paying some dumb mechanic in my area who doesn't even know what V-TEC is. When I cant find the problem myself, then I will bend over and take it, then go to the Acura dealership!
Old 04-14-2008, 03:49 PM
mesonerz's Avatar
dude all i know is that i get a stupid code 43 every now and then. i know its fuel delivery system, but its so random i just cant figure it out.
Old 04-15-2008, 04:53 PM
Default Re: GSR codes? Need help! (mesonerz)
The distributor I got was purchased rebuilt when I bought the car not to long ago, I am wondering if thats part of my problem?
Old 04-15-2008, 05:14 PM
steveo135's Avatar
The crankshaft position sensor problem may be caused by your dizzy.. you will need a helms manual to diagnose that though.. I'd say start by resetting your ECM
Do like dogginator said and get a honda hookup manual
Old 04-15-2008, 06:17 PM
ITRICED's Avatar
well your crankshaft position sensor i believe is in you Dizzy and evap is emissions go to autozone and buy a manual for 20 bucks i have a book and ill try to look it up for you more
Old 04-15-2008, 06:21 PM
ITRICED's Avatar
Default Re: GSR codes? Need help! (ITRICED)
Make sure your dizzy is positioned right also
Old 04-16-2008, 05:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRICED &raquo;</TD></TR><TR><TD CLASS="quote">well your crankshaft position sensor i believe is in you Dizzy and evap is emissions go to autozone and buy a manual for 20 bucks i have a book and ill try to look it up for you more
Nope Wrong. your Crank position sensor is under your timing belt cover on the bottom of your crankshaft. you can tell that there is something under there cause if you look at a OBD1 cover and a OBD 2 cover they are not interchangeable.
I have a spare crank sensor that I can spare for the cause so you can switch them out. I don't know if giving parts away to help a fellow honda lover out is illegal on here just let me know and I can send it to ya.
Old 04-16-2008, 05:32 AM
Daisy... Daisy...
Dogginator's Avatar
Default Re: GSR codes? Need help! (H22powered_94teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22powered_94teg &raquo;</TD></TR><TR><TD CLASS="quote">I have a spare crank sensor that I can spare for the cause so you can switch them out. I don't know if giving parts away to help a fellow honda lover out is illegal on here just let me know and I can send it to ya.</TD></TR></TABLE>
There is nothing wrong with that. However, i would encourage the OP to see if the car is covered by the extended emissions warranty. Let Acura fix it for free.
Here is the link again:
Old 04-16-2008, 03:46 PM
ITRICED's Avatar
no the cranshaft flucuation sensor is next to you timing
Old 04-17-2008, 08:15 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRICED &raquo;</TD></TR><TR><TD CLASS="quote">no the cranshaft flucuation sensor is next to you timing
So wait why would your crank sensor be near your distrib or cams, if that is what you are saying. cause I
Old 04-17-2008, 08:17 AM
Cause I am pretty sure the Honda manuals don't lie and I think that you need to know what you are talking about b4 you speak..
Old 04-17-2008, 08:45 AM
steveo135's Avatar
I'm Not sure whats going on here but Your crankshaft fluctuation sensor (CKF) is located by the timing belt
You Crankshaft postion sensor (CKP) Top dead center sensor (TDC) and Cylinder position sensor (CYP) are all located on the rotor shaft inside your distributor
2 of the 4 possible fixes for for the codes P0335 & P0336 are replace the distributor housing sensor
Old 04-17-2008, 01:30 PM
Default Re: GSR codes? Need help! (steveo135)
And yes your timing belt wraps around your crank the the tensionor, water pump, the exhaust pulley, and the the intake pulley. the CKF senes changes in the cranks rotation via electromagnetic pulse from a reluctor wheel on the CRANKSHAFT timing belt gear.
Old 04-21-2008, 06:41 AM
So it seems to me that I bought a defective distributor! Got it from ebay, now I am hisitating getting another from there. Thats what I am going to start with
Old 04-21-2008, 06:43 AM
Could all these codes at the same time cause my car to rev only to 3500K? "safe mode"
Old 04-22-2008, 03:14 AM
Daisy... Daisy...
Dogginator's Avatar
Default Re: (96GS-R-Kaden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96GS-R-Kaden &raquo;</TD></TR><TR><TD CLASS="quote">Could all these codes at the same time cause my car to rev only to 3500K? "safe mode"</TD></TR></TABLE>
Yes.
Old 04-26-2008, 02:13 PM
Default Re: (Dogginator)
Makes sense, will start with the distributor, then work my way up. I have a hose that runs out of my evap canister that I just notice thats pluged with a huge screw?
Quick Reply: GSR codes? Need help!
