> Hybrid
Old 09-04-2007, 04:58 AM   #26
gibsanez
gibsanez's Avatar
Default Re: H2B Turbo CRX...... my never ending project!!! (88ED8)
I wonder if I'll have this problem with my stock x-member
Originally Posted by Rude Awakening View Post
i accidentally a daughter
gibsanez is offline Report Post   Reply With Quote
Old 09-04-2007, 05:09 AM   #27
SIXTY
SIXTY's Avatar
Originally Posted by 88ED8
did you still use the black support thing also? ^^ thats probly my only option...
What black support thing? Mine is mounted exactly like yours, just underneath the control arm, im using the same bolt hole as yours. I also used a nut on the end of that long bolt that goes through the lca, for added strength.
760/SEVEN_SIXTY/BUILT
High Desert service for Motor Swaps/Builds
PM for all inquiries
SIXTY is offline Report Post   Reply With Quote
Old 09-04-2007, 06:06 AM   #28
88ED8
88ED8's Avatar
Send a message via AIM to 88ED8 Send a message via MSN to 88ED8
Default Re: H2B Turbo CRX...... my never ending project!!! (SIXTY)
I'll take a pic for you to see
maybe...
88ED8 is offline Report Post   Reply With Quote
Old 09-04-2007, 06:18 AM   #29
88ED8
88ED8's Avatar
this thing
Old 09-04-2007, 10:06 AM   #30
SIXTY
SIXTY's Avatar
wow, ive never seen one of those before. I actually like that. I wonder if there is still room to use it underneath.
Old 09-04-2007, 10:52 AM   #31
QuarterMileMaster
QuarterMileMaster's Avatar
Send a message via AIM to QuarterMileMaster
Nice project!! Bump for a dream build of mine. Be sure and post results in my sig thread!!
J2ned Turbo Kits - You'll See...
QuarterMileMaster is offline Report Post   Reply With Quote
Old 09-04-2007, 03:15 PM   #32
hondaZvic
1999 Honda Civic
My Garage
hondaZvic's Avatar
Send a message via AIM to hondaZvic
Default Re: H2B Turbo CRX...... my never ending project!!! (QuarterMileMaster)
nice build man
MY COUPE | MY HATCH
hondaZvic is offline Report Post   Reply With Quote
Old 09-04-2007, 06:18 PM   #33
88ED8
88ED8's Avatar
I'm a definately try
fo sho
Originally Posted by hondaZvic
nice build man
Thanks!
Old 09-04-2007, 06:28 PM   #34
88ED8
88ED8's Avatar
another pic
Old 09-04-2007, 06:51 PM   #35
PnkRokCountryboy
PnkRokCountryboy's Avatar
Send a message via AIM to PnkRokCountryboy
oh expletive. haha sick shit
PnkRokCountryboy is offline Report Post   Reply With Quote
Old 09-05-2007, 09:04 AM   #36
Noemotion_91DA
Noemotion_91DA's Avatar
I noticed that you went with the skunk2 manifold, Did you have to pound the fire wall in a bit to make it fit?
Noemotion_91DA is offline Report Post   Reply With Quote
Old 09-05-2007, 11:24 AM   #37
88ED8
88ED8's Avatar
Default Re: H2B Turbo CRX...... my never ending project!!! (PnkRokCountryboy)
nope, not at all, endless space back there
Old 09-05-2007, 11:34 AM   #38
gibsanez
gibsanez's Avatar
I'll be changing my oil filter from the top of the car
Old 09-05-2007, 11:39 AM   #39
88ED8
88ED8's Avatar
Default Re: H2B Turbo CRX...... my never ending project!!! (gibsanez)
haha, I knew that space was good for something....
Old 09-05-2007, 12:07 PM   #40
skunked
skunked's Avatar
Send a message via AIM to skunked
I do the same
2.2L H2B NA DC2 S/P 12.1@110
http://www.quartersportsdrag.com/
SINISTER RACING
skunked is offline Report Post   Reply With Quote
Old 09-05-2007, 05:48 PM   #41
88ED8
88ED8's Avatar
Default Re: H2B Turbo CRX...... my never ending project!!! (skunked)
pic of the clearance from manifold to firewall
Old 09-07-2007, 07:55 AM   #42
22boost
22boost's Avatar
Build looks really good . Somethings that you might want to reconsider that I ran into issues with on my turbo H, was one go with larger injectors, H22s use ALOT of fuel...partly because they make so much torque, more torque=more fuel. Those injectors will work just fine for what you have right now, but if you plan on building the block any and running more boost, your going to need more fuel.
Also that fuel pump will work just fine but same thing, I think the walbros are good for about 450-500hp, but even still maybe look into upgrading your fuel system.
Im not sure what brand clutch your using but Im currently running a Competition stg3/lightened flywheel and it slips pretty bad 3-4 once you reach vtec.. I have now a Competition stg5 and reserfaced stock flywheel Im waiting to put in. You will be doing some serious shifting with that ITR transmission...I can only imagine...Ha, my stock gears always felt a little long untill I decided to turbocharge...
Heres the pic of the Peakboost hard return line kit.
Let me know how that 44mm gate works for you, Im only running a 38mm...with the 3lb spring it will hold around 5-6psi, but on the top end im looking at 10psi. Once I get some funds Joe at TempstRacing is going to weld in another flange and add another 38mm gate to my manifold.
You should be looking at some good numbers, at around 10psi/slipping clutch my car managed to put down 380whp on the dyno. Mind you this is a bone stock jdm h22w/euroR intake manifold.
Modified by 22boost at 8:16 AM 9/7/2007
THC#101
22boost is offline Report Post   Reply With Quote
Old 09-07-2007, 02:04 PM   #43
88ED8
88ED8's Avatar
Default Re: H2B Turbo CRX...... my never ending project!!! (22boost)
Thanks for the insight, yea I know the fuel system is a little on the weak side... When the built motor stage comes into play I'll up grade everything, heat treat gears/DSS lev 5.9, sump/external pump/-8AN lines ect ect.....
The cluch I'm useing is a SPEC stg 3 6puc sprung... I think it can hold like 325lb/ft of torque, wich should hold what I make. I will definately upgrade that later to maybe a Clutch Masters twin disk H2B specific setup...
as far as ther oil drain on the turbo goes I thinking about using a weld on -10AN fitting on the pan with a straight or 45* then to a 45* on the turbo using all push lock fittings
as far as the oil feed goes I can't seem to find a definate yes or no on wether I need a oil restictor or not. I found this regutaled inlet flangethat can be drilled out bigger if too small
If any one knows what size that hole should be let me know...
Old 09-07-2007, 02:10 PM   #44
QuarterMileMaster
You shouldn't need an oil restrictor on a normal t3/t4 journal bearing turbo. Typically those are only needed for small t25-t28, and bb turbos.
Old 09-07-2007, 02:15 PM   #45
88ED8
88ED8's Avatar
so with the dowel pins in the main girdle being replaced with solid pins to block oil to the balance shafts making the oil pressure a little higher than a normal H22, it should still be fine? and the turbo is a T3/To4R with a 360* bearing...
Old 09-07-2007, 03:11 PM   #46
pynikal
pynikal's Avatar
car looks awesome man. gl with the build. post up numbers. eta on first run or is that still a ways away???
+2000 posts (dam mods)
The replacement for displacement is technology.
pynikal is offline Report Post   Reply With Quote
Old 09-07-2007, 04:12 PM   #47
88ED8
88ED8's Avatar
Default Re: (pynikal)
Thanks, and yea man, still got along way to go, if all goes as planed maybe 2.5-3 months, but nothing ever goes as planed....
Old 09-08-2007, 03:14 PM   #48
mattcivic
mattcivic's Avatar
Send a message via AIM to mattcivic
Default Re: (88ED8)
so gangster u plannin on running a fuel cell? i see u have a huge hole cut out in the back whats up with that?
<U>MY RIDES</U>[b]
01 dodge 2500 6-speed cummins
89 civic wagon B18c1, crv 5 speed trans AWD FTW!
mattcivic is offline Report Post   Reply With Quote
Old 09-08-2007, 05:49 PM   #49
88ED8
88ED8's Avatar
Default Re: (mattcivic)
Originally Posted by mattcivic
huge hole cut out
lol, what happen was....
that area was badly rusted out so rather than repair it, I cut it all out, I plan on using aluminum to cover it should look gangster when done
Old 09-09-2007, 02:32 AM   #50
hondaZvic
1999 Honda Civic
My Garage
hondaZvic's Avatar
Default Re: (88ED8)
nice.
MY COUPE | MY HATCH
Bookmarks
brakes, civic, crx, disk, etm, fuck, h22a, h2b, honda, integra, project, projects, series, turbo, turbocrx, whats
