| Welcome to Honda-Tech! | ||
#1 |
| Garage is empty, add now |
I've had a carbon fiber hood on my crx for a couple of years now. It has real bad sun damaged. Is there any product out there that can repair the hood. When its wet, it looks BRAND NEW! I've sEEn lots of cars driving around with the same problem.
any help? THANKS! |
#2 |
Have someone who has paint knowledge take a look at it. Probably just need to be wet sanded and cleared. The clear build is what you need for UV protection.
••••• FS: '05 Acura TL Cat-Back OEM Dual Muffler Exhaust , $350 Houston, TX •••••• |
#3 | |
Location: The Burbs of NYC, where you can park your car on the street & they wont steal it NY
Indeed....wetsand with 4-500 grit and reclearcoat!
EJ8 Squad Member #396 |
#4 |
Cool
i'll try it myself.... i got nothing to lose, right? - right!
#5 |
sand it down with 320 grit sandpaper and shoot few coats of high grade automotive catalized clearcoat
#6 |
For a noob I wouldn't recommend to go that coarse, finish it with around 800 if your doing it by hand and just clearing. Paint it yourself if you have the knowledge and equipment.
#7 |
http://www.g2ic.com/forums/showthread.php?t=168889
im no paint guy, but i saw this and thought about this thread. hope that helps!
2000 VSM Integra LS Sedan 2007 Storm Silver Fit Sport vouch: pmpm06,jxhxb,patric8332 |
#8 | |
simple 1500 +2000grit is what we did and off the self polish/ rubing compound and carnuba wax
built ka-t
#9 |
Yep, you can pretty much buff/polish anything to make it shiny. But to fix the problem it would need clear. After all that wet sanding you would be half way there to refinish the part. I suppose if you have the time to do it on a regular basis, but why not go for the gold.
| Tags |
| car, carbon, cf, damage, damaged, fiber, fix, fixing, hood, hoods, integra, repair, sun, wet, when |
