Old 08-28-2007, 09:28 PM   #1
turbotime
turbotime's Avatar
Default Car wont start: relay clicking, headlights turn off electronics help! HELP!
Ok out of nowhere my car wont start anymore. I open the door, interior light comes on, put key in ignition, courtesy chime sounds. Turn key, computer makes a clicking noise and there is a tappin/scratching coming from the front right river footwell area which i am assuming is some sort of relay....all the instrument lights dim and flicker.
Turn on the headlights, all the lights and instrument cluster go out completely car doesnt even click or anything when i try to turn it on. Press brake pedal, similar situation, instrument lights go off completely, car wont even make a noise when i try to start it. Remove foot from brake, interior lights and instrument lights come back on, car still wont start but at least teh relay makes noise when i try and turn it over....
What the hell is going on here? Car was fine 5minutes ago! is the main relay dead? Is the battery dead? WTFFfff PLEASE HELP!!!!
turbotime is offline   Reply With Quote
Old 08-28-2007, 09:34 PM   #2
Eran
HT White Ops
Eran's Avatar
iTrader Rating: (1)
Sounds like your battery is dead.
You could also have an alternator problem, but get a jump start first.
JDMREVEREND / SEAN CORBETT IS A THIEF
[ CR-XTASY ][ Flickr. ][ anti|hero ][ dSoc:124 ]
Eran is offline   Reply With Quote
Old 10-29-2007, 02:22 PM   #3
_decker
_decker's Avatar
iTrader Rating: (1)
Default Re: (Eran)
Im also having this problem in my 93 hatch. I left the lights on overnight and when I tried to jump start the car, it wouldn't turn over. I get the chime, and the lights on the cluster come on and when but when I push in the clutch and turn the key, there is a clicking/humming noise from the left lower dash, that's it. I got the car to turn over for about one second one time then it seems like it had no more juice, but it was hooked up to another car.
The battery is about 6 months old and the alternator is about a year old. I checked the grounds and the connection to the starter and everything seemed ok. Im thinking is the starter but does anybody else have and idea of what it could be?
_decker is offline   Reply With Quote
Old 11-29-2007, 03:46 PM   #4
TruckracerV
TruckracerV's Avatar
Check the actual cables, i just had this problem on my nissan and needed to replace cables, no probs since
TruckracerV is offline   Reply With Quote
Old 11-29-2007, 05:55 PM   #5
eskimo10
eskimo10's Avatar
I agree with both. I have personally had my alternator take a crap on me and that had exactly the same symptoms you are describing. Also I worked on a neon that had similar symptoms and it turned out to be the battery wire to the starter that was frayed and melted. I would start with both of those. Check your wires first if they're fine, try and get a jump start, if you start it up then you could have an alternator problem like the voltage regulator taking a crap on you or something. Hope this helps!
12/09 -- Forging a physique that leaves no doubt. [relentless]
His temple.My fortress.
Originally Posted by Cynical 1 View Post
the engine will keep running until it blows up... after that, it won't run anymore...
eskimo10 is offline   Reply With Quote
Old 11-29-2007, 07:34 PM   #6
civic_coupe_585
civic_coupe_585's Avatar
Send a message via AIM to civic_coupe_585
try cleaning your terminal wires with some sand paper until you can see copper, then clean off the terminals, then use battery terminal protectant to see if its just corrosion. it could be your ignition [the electronic part] mine **** the bed too. there was a recall for the prelude and accord but not for the civic. junkyard the part too it'll deff. be alot cheaper then the stealership they were asking $520 for just the part. do it yourself too its pretty easy. take apart the column and then disconnect the harnesses there should be like 3 of them.
civic_coupe_585 is offline   Reply With Quote
Old 11-30-2007, 12:09 PM   #7
RyanG
1994 Honda Civic
My Garage
RyanG's Avatar
Default Re: Car wont start: relay clicking, headlights turn off electronics help! HELP! (turbotime)
check all of your grounds to make shure that they are all snug and secure
when you lost you called me a cheater you cant hang around the 1.8L
94 civic hatch B18b1
There is no replacement for displacement? It's called a turbocharger. Also known as Displacement On Demand.
RyanG is offline   Reply With Quote
05, civic, clicking, clicks, crx, dash, dim, e46, honda, ignition, jump, lights, relay, sound, start, starter, wont
