| Register | FAQ | Search | Today's Posts | Mark Forums Read | My Recent Topics | My Notes | Dealer Listings | Garage | Vendor Directory |
#1 | |||||
Need suggestions on good xbox 360 games - I don't play multi-player (online) and first person shooters I reserve for the computer - Any suggestions are welcome '97 EX - Stock as stock can get - Daily driver, KYB struts, Tokico reds, I/H/E Last edited by Syndacate; 12-28-2008 at 01:19 AM. |
#2 |
To those that would like to see the circuit in action, I will add to this thread.
![]() As you can see from the picture above, there are 4 rotary positions in this civic dial. If you examine the blower resistor in this picture, you will see how current flow through the dial and attains the correct speed. It does this by creating a resistance as he stated above, and I will use 5 Ohm's in this case for each squiggly line in the blower resistor. As you see in the 4 position (red wire) the current is unopposed, and travels with full voltage to the blower for max speed. You blower works in high only because there is a separate ground line from the resistor box that has no added resistance, and thus gives you high only, even if the resistor is faulty. Position 3 (blue) goes through the resistor, and one squiggly line (5 Ohms) This will give a slightly lower speed than max because of the voltage used to pass the resistor. If the resistor that this position uses fails, the entire unit fails, because the other two positions require passage of this squiggly line to obtain the next lower speed. Position 2 (green) Goes the same route, but it passes through two squigglies (10 Ohms) which gives the next lower speed. If the second resistor this position uses fails, this position, and the 1st position will fail, because the first uses this to obtain the next lower speed. Position 1 (purple) Takes the same route into the resistor, and passes all 3 squigglies, for 15 Ohms in this case, of resistance, obtaining the lowest speed setting. If this third resistor fails, this position will not work, but 2, 3, and 4 will, since none of those positions use the third resistor. Why it fails: Resistors produce heat by soaking up power, and after a while, they can fail, by either overheating, and in some cars, water entering the blower since some units are cooled by the blower motor air. The lowest speed setting will use the most current, as it must pass through all 3 resistors in this case to obtain its speed, and is the most likely to fail, resulting in only high speed. Not to steal from Syndacate, but just adding another way of seeing it. I hope it helps you all.
Vehicle need work? If you live in my area, send me a message, I may be able to help you! |
#3 | |
.Thx
Need suggestions on good xbox 360 games - I don't play multi-player (online) and first person shooters I reserve for the computer - Any suggestions are welcome '97 EX - Stock as stock can get - Daily driver, KYB struts, Tokico reds, I/H/E |
#4 |
Perfect timing on this thread. I just read up on it and fixed my blower issue (fan speeds 1 and 2 dead). FYI in the advance auto parts online section, the part is located under replacement parts>switches>blower motor resistor. The borg warner part is RU801.
The OEM acura part number is 79330-SR3-A01 and is cheaper than the borg warner part (online). |
#5 |
Excellent post, well written, thorough and informative, thanks!!!
-Walter
'91 Talon TSi AWD (ForSale) '99 Ducati 748S (996 swap) '93 Civic CX HB (5.spd) |
#6 |
I sent a PM to the OP, but I think there may be some differences in the setup from one used here. I have a 2000 Si and here is what it looks like for mine
![]() The resistor I got was from Amazon and the guy f'ed up the first one, but actually got me an OEM one from Honda in return. Here's the pic of where it sits at ![]() The base of mine actually sits in the area secured by the clips. I don't know how to get the damn thing out. Any suggestions? Sorry about the size of the pictures. I took them with my phone. |
#7 |
Wow, I wish I would have known about this a long time ago instead of freezing my nuts off too!
JG |
#8 |
i just changed my resistor and nttin changed, itsmoked up and the blower motor turned red. none of my fan speeds work. i know its getting power cuz whenerver ichange the speed my idles lowers
#9 |
I am having the same issue with my 96 jdm civic Si 4dr...mine looks completely different and is on the left side of the car.. but its just a small metal circle thing and not a resistor like urs...i am thinking my issue is the climate control unit...
| Bookmarks |
| Tags |
| 2000, 2002, accord, acura, blower, current, heat, high, honda, integra, moter, motor, pack, replaced, resistor, speed, takes |
