timing belt tensioner what size is it???
Old 08-23-2007, 03:47 PM
killacam661's Avatar
Default timing belt tensioner what size is it???
like title says..... and i cant get my belt on without loosening the tensioner.....right? any suggestions i just pulled the head off now need to put the timing belt back on.
Old 08-23-2007, 04:33 PM
non-VTEC's Avatar
Default Re: timing belt tensioner what size is it??? (killacam661)
good luck trying to slip that belt on without undoing the tensioner.........just do it properly......i can guarantee you will fight with it over an hour before figuring out it's easier to take 5 minutes to undo the tensioner and time it properly....
Old 08-23-2007, 04:36 PM
Default Re: timing belt tensioner what size is it??? (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">good luck trying to slip that belt on without undoing the tensioner.........just do it properly......i can guarantee you will fight with it over an hour before figuring out it's easier to take 5 minutes to undo the tensioner and time it properly....</TD></TR></TABLE>
thats why i was asking what size it is. i heard it was a 14mm bit mine looks to be a 17mm. and without taking the cover off i cant access the tensioner. i wasnt asking for a shortcut.
Old 08-23-2007, 08:17 PM
ttt soemone know quit bein lazy
Old 08-23-2007, 08:47 PM
BLacK FirE's Avatar
yes it is a 14mm.
Old 08-23-2007, 10:12 PM
Default Re: timing belt tensioner what size is it??? (BLacK FirE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLacK FirE &raquo;</TD></TR><TR><TD CLASS="quote">yes it is a 14mm.</TD></TR></TABLE>
hmmmm mine has like a 16 1/2 mm bolt ..... to big for 17mm and 11/16 ....and 16mm and 5/8 were too small. i dont know what size it is and i dont want to round it off. its a wierd *** size and i dont know why theres not a 14mm bolt on the tensioner. gay!!!!
vtec ayday
Comp97GSR
12-30-2022 12:10 PM
CivicBlacksheep
46
02-10-2013 09:51 AM
slide inside
10-22-2009 09:25 AM
tikishow
Classic Hondas
10
03-19-2008 02:21 PM
Benhawk
01-29-2007 11:49 AM
Quick Reply: timing belt tensioner what size is it???
