> Honda CRX / EF Civic (1988-1991)
Old 08-15-2007, 09:24 PM   #1
90_Si
90_Si's Avatar
Default Car wont start on first turn of key but starts the second time
I did a search and did not come up with a whole lot that was applicable. The engine is a sohc zc. In the morning when I start it, it will not start the first time.. but on the second time I turn the key it starts perfectly.The main relay came to mind, but usually it is the opposite. The engine has a new timing belt, distributor cap/rotor, water pump, spark plugs, ignition wires.. basically anything that would ever wear out has been replaced. It has also had a can of seafoam ran through the fuel/vacuum/crank case. The distributor cap and rotor made the start much smoother and such in general terms, but did nothing as far as the issue at hand. It only happens in the mornings, so once it has been driven for the day it starts just fine. It seems the engine has to completely cool down for it to start the delayed start. I am at a loss for what it could be, any help or ideas would be appreciated.
1990 Civic Si SOHC ZC
2004 Mustang GT
90_Si is offline   Reply With Quote
Old 08-15-2007, 09:41 PM   #2
garageEF
garageEF's Avatar
Send a message via AIM to garageEF
Default Re: Car wont start on first turn of key but starts the second time (90_Si)
bump cause im having a similar problem.
Originally Posted by RC_Benjamin
when does that hottie turn 16? i need a ride
garageEF is offline   Reply With Quote
Old 08-15-2007, 10:48 PM   #3
EFM_ookie
EFM_ookie's Avatar
Default Re: Car wont start on first turn of key but starts the second time (garageEF)
can u hear the main relay click when it doenst start?
project 88 civic DX Now RHD caged up!!
K24...........soon!!!!!
Build thread! http://www.honda-tech.com/showthread...964504&page=26
EFM_ookie is offline   Reply With Quote
Old 08-15-2007, 11:00 PM   #4
90_Si
90_Si's Avatar
Default Re: Car wont start on first turn of key but starts the second time (EFM_ookie)
No, everything sounds normal other than it wont actually start on the first turn of the key. The weird thing is is that on the first go round I can let it turn over 10 times or two times and it wont start, but in either case if I let the key off and then turn it the second time it starts right up completely normally. It does this on every single cold starts, but once it has been started, whether for just a second or driven all day it starts normally until the car sits overnight and then the problem arises again.
2004 Mustang GT
Old 08-15-2007, 11:01 PM   #5
garageEF
garageEF's Avatar
try priming your fuel pump a few times before trying to start it.....just to see if it is a fuel pressure issue.
Old 08-15-2007, 11:05 PM   #6
90_Si
90_Si's Avatar
How do I prime the fuel pump?
2004 Mustang GT
Old 08-15-2007, 11:08 PM   #7
garageEF
garageEF's Avatar
just click the key to "on" a few times...you will notice the check engine light coming on, then turning off after a few seconds...that is your pump priming.
Old 08-15-2007, 11:14 PM   #8
90_Si
90_Si's Avatar
just did it and after priming it it started normally. I am assuming it has sat long enough to have cooled to where the issue would arise.. I will do it again in the morning to make sure. That fits my assumption that it is something to do with the fuel system. As far as fixing it, is it going to be a matter of having to get a new fuel pump?
2004 Mustang GT
Old 08-15-2007, 11:35 PM   #9
garageEF
garageEF's Avatar
definatley a fuel issue.....when you turn your car off...there is enough fuel in the system for it to start normally for an hour or so....im sorry but i have no idea where you would start to diagnose your problem...best of luck to you
Old 08-16-2007, 12:02 AM   #10
90_Si
90_Si's Avatar
well at least I know specifically where to look for the problem now, thats a start.
2004 Mustang GT
Old 08-16-2007, 12:22 AM   #11
garageEF
garageEF's Avatar
your welcome
Old 08-16-2007, 12:36 AM   #12
i_VTEC
i_VTEC's Avatar
The same thing happens to my 88 CRX Si. The first start of the day, when i try and start the car it turns over and sounds fine, but it wont start. But as soon as i do it the second time it starts right up........
"SOHC My DOHC"
EJ8 SQUAD Member # 662.
i_VTEC is offline   Reply With Quote
Old 08-16-2007, 12:45 AM   #13
garageEF
garageEF's Avatar
Default Re: Car wont start on first turn of key but starts the second time (LS-VRex)
well now you know what the problem is....
Old 03-15-2013, 05:32 PM   #14
sorwdfish
sorwdfish's Avatar
its your ignition key starter. switch it out... every time my car sounds funny i take it in to the mechanics and have them diagnose my car for free. then they tell me the problem so i tell them ill come back when i get payed and never do so i know whats wrong with my car for free.
sorwdfish is offline   Reply With Quote
1990, 1st, 2nd, car, doesnt, key, mustang, start, starting, starts, time, turn, turning, wont, works
