trunk light
Old 08-11-2007, 01:55 PM
omarisramo's Avatar
Default trunk light
my trunk light appears to be on when it is closed and says its closed when its open
u guys have any idea how to fix this
Old 08-11-2007, 05:16 PM
bseriescrxsi's Avatar
Default Re: trunk light (omarisramo)
replace truck sensor and check your grounding wires...something is reversing the ground on it and confusing it when its open and closing
Old 08-11-2007, 05:20 PM
phootbag's Avatar
Default Re: trunk light (bseriescrxsi)
Electrical problems are best diagnosed when you have electrical schematics.
Besides, if you know that the indicator is showing opposite the actual condition, and it works that way reliably, what's wrong?
Old 08-11-2007, 05:40 PM
361 accord's Avatar
Default Re: trunk light (phootbag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phootbag &raquo;</TD></TR><TR><TD CLASS="quote">Electrical problems are best diagnosed when you have electrical schematics.
Besides, if you know that the indicator is showing opposite the actual condition, and it works that way reliably, what's wrong?</TD></TR></TABLE>
lol good one, i would assume its annoying
Old 08-11-2007, 08:30 PM
omarisramo's Avatar
how would i b able to fix it?
Old 08-11-2007, 08:38 PM
Global Moderator
tech8's Avatar
What year and trim level is your car?
There probably is something wrong with the trunk latch switch.
Old 08-12-2007, 05:34 AM
phootbag's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phootbag &raquo;</TD></TR><TR><TD CLASS="quote">Electrical problems are best diagnosed when you have electrical schematics. </TD></TR></TABLE>
Old 08-12-2007, 09:27 AM
Global Moderator
tech8's Avatar
Basically, the trunk latch switch turns the trunk light on/off. There are two terminals on the switch, which connects to a 2-P connector, the terminal prongs on the switch are shaped in different directions, so that it cannot be connected the wrong way. The 2-P switch connector wires run through the underhood fuse/relay box, protected by the No. 37 (7.5A) fuse, to the trunk light assembly and bulb (3.4w).
The trunk latch switch is held by the 3 bolts. There also is a lock rod, which can be disconnected by rotating the plastic clip off the rod.
Modified by tech8 at 10:54 AM 8/12/2007
Old 08-12-2007, 07:24 PM
omarisramo's Avatar
its a 95 accord lx
with that pic what should i do? i ve seen that so wats up should i switch them or what?
Old 08-12-2007, 08:22 PM
Global Moderator
tech8's Avatar
The pic is a 95 EX. The problem most likely is related to the trunk latch switch.
Basically, when the trunk is open, the switch should close the contacts and the light turns on; consequently, when the trunk is closed, the switch circuit should be open/broken and the light is off. (Your car, the switch is doing the opposite.)
talkJDM
06-06-2007 01:54 PM
racereaper7
10-20-2006 07:27 AM
fknfast
Honda S2000
15
07-28-2006 09:10 PM
ushouldnous
09-22-2004 10:44 AM
B18C-VTI_R
07-13-2004 07:00 AM
Quick Reply: trunk light
