Old 10-24-2008, 08:29 PM   #51
JDMekBoosted
JDMekBoosted's Avatar
Default Re: (Skuba_Steve)
ok you see that black stripe that is in the INSIDE of the metal track? now my passenger window has that and my driver side window doesnt, its just the metal track no rubber piece inside. now im guessing that is why my driver side window keeps coming off track every single time i put it down?
JDMekBoosted is offline Report Post   Reply With Quote
Old 11-08-2008, 08:21 PM   #52
VADERS_EM2
VADERS_EM2's Avatar
Default Re: (JDMekBoosted)
YES SIR. the rubber is like a guide. i did mines today. i had it all done. i went to put the panel back up and cracked it.
VADERS_EM2 is offline Report Post   Reply With Quote
Old 02-23-2009, 08:32 PM   #53
NY_2_OC
NY_2_OC's Avatar
Default Re: DIY : WINDOW TRACK PROBLEM
My EK does this every once in a while. The plastic guides need to be replaced. If anyone has this problem you can relate to on how much you wanna shoot your door off with a bazoooka everytime you hear that "clunk" when your window comes of track. I also found that bending the metal (left side)that holds the plastic a TAD using a long wrench or screwdriver. That way it doesn't slip out as easily.
Luv your [ i v i ]
NY_2_OC is offline Report Post   Reply With Quote
Old 02-27-2009, 03:55 PM   #54
1sloej6
1sloej6's Avatar
Send a message via AIM to 1sloej6
But what if your window doesnt roll all the way up??? mine leaves about a 2inch gap from the top and wont go any further???
Team EJ6 Member-#22
1sloej6 is offline Report Post   Reply With Quote
Old 02-27-2009, 04:18 PM   #55
infinitypro12
infinitypro12's Avatar
This is a fantastic write up. There needs to be a How To section of HT were stuff like this can be categorized by car and remain permanent. Unfortunately it was way too cold and the glass place only charged me $50 for 45 minutes, two cup of coffee, and staying warm. Ha ha, if it had been warmed that week I would have done this.
It's a forum, don't get your panties in a bunch.
infinitypro12 is offline Report Post   Reply With Quote
Old 03-05-2009, 01:49 PM   #56
mattkins91
mattkins91's Avatar
Awesome post man!!!!! i hate civic windows lol
mattkins91 is offline Report Post   Reply With Quote
Old 03-05-2009, 02:13 PM   #57
89excoupe
1999 Honda Civic
89excoupe's Avatar
hey i know this thread was started a while ago but my passenger window in me 99 ex coupe goes down and up really slowly...do i need that silicone spray to solve this problem? or is it something else?
89excoupe is offline Report Post   Reply With Quote
Old 04-16-2009, 08:04 PM   #58
HyRev
HyRev's Avatar
^^^Bump....mine does to.
HyRev is offline Report Post   Reply With Quote
Old 04-20-2009, 10:10 PM   #59
TheJGB3
TheJGB3's Avatar
Send a message via AIM to TheJGB3
^^^ x3
2000 Type SH*AEM Short Ram & brake pads*JDM Front strut bar*OEM lip kit*Clear sidemarkers*OEM carbon fiber trim kit*ASE Re-Certified Tech:A4 A5 A7 X1 P2 C1
2000 Civic EX*Si front grille*OEM fogs
TheJGB3 is offline Report Post   Reply With Quote
Old 04-20-2009, 10:31 PM   #60
ifIexplode
ifIexplode's Avatar
Send a message via AIM to ifIexplode
http://images.peakcandle.com/albums/...iconespray.jpg
Da good sh*t
98ej6-b18c5 PS3. tofadeisastart
96-98 Tail lights FS (amber turn signals)
93 Integra seats FS, Black in color.
ifIexplode is offline Report Post   Reply With Quote
Old 04-20-2009, 11:11 PM   #61
DualCamEJ
1996 Honda Civic
DualCamEJ's Avatar
this is the problem i have right now but then i did this along time ago, its haunting me bacc
"DualCammin @ 9k"
DualCamEJ is offline Report Post   Reply With Quote
Old 04-21-2009, 05:14 AM   #62
Chris_Spires
Chris_Spires's Avatar
Send a message via AIM to Chris_Spires
Originally Posted by VTEC_Viking View Post
Wow this diy helps a ton! Too bad it took me so long to find it, how come it's not in the faq section?
Only thing is you don't show where to pop the clips off inside the panel. Thats the step i'm stuck on. Cause I don't want to damage the paint or hurt my door. I know there are 6 clips two on the side, 3 on the bottom , and one in the front.
if you are taking about the clips that hold the whole panel to the door, just feel for where the clips are and give it a nice tug and it should pop off. That's what I did at least
Chris_Spires is offline Report Post   Reply With Quote
Old 05-04-2009, 11:27 AM   #63
99SIFry
99SIFry's Avatar
Awesome write-up. This happened to my SI last week going through Burger King. To make things worse, I was in the process of moving so had no time to really sit down and look at it. Luckily I had a garage, my fiancé's Integra, and Honda-Tech to help me out.
I tackled the project yesterday when the weather was nice. Once I got the door panel off, I found my window slid out of the track on the front only. I Loosened the 2 gold track bolts and jiggled the window back into place. I got some silicone spray like was mentioned and lubed it up. Did a test and works great again. The hardest part was getting the damn panel to go back on properly. The speaker magnet has a tendency to attract to the door so watch out for that.
99SIFry is offline Report Post   Reply With Quote
Old 05-04-2009, 11:37 AM   #64
EG6KILIN
EG6KILIN's Avatar
Send a message via Yahoo to EG6KILIN
man I'm ready to break my window I changed it with two different trailing arm an it still roll Down like crap.....idk what else to do...
WhEn LiFe PaSSeS YoU By......DOWNSHIFT!!!!!!
NIKOND60
VOUCHES:slammedef,proudtobeawsome,mcpai,jdmfrijole s,Ilhatch,H-DEUCE,kevinsmith88
EG6KILIN is offline Report Post   Reply With Quote
Old 05-18-2009, 03:26 AM   #65
PANGES
PANGES's Avatar
lol. I just bought my 97 DX Hatch yesterday. It's 3am now, just drove home, it's really foggy and starting to sprinkle and my window fell of track. I'm too lazy to fix it now, so I just left it as far up as it'll go (about 2/3 the way up.) That means the inside of my car is probally going to be wet tomorrow. lol. Lame.
Good write up though! :D
BTW: I've never had to take the handle off manual windows before. Is it hard to take the clip off with just a pair of needle nose pliars?
PANGES is offline Report Post   Reply With Quote
Old 05-18-2009, 06:53 AM   #66
jonneyboy25
jonneyboy25's Avatar
this happen to me also kind of...my window went down really slow aand wont go back up? do you think its the motor? Can i make my window go up manually like by taking off the door panel and loosen some bolts and push it back up?
jonneyboy25 is offline Report Post   Reply With Quote
Old 05-18-2009, 09:43 AM   #67
EG6KILIN
EG6KILIN's Avatar
Nice write up but damn im hating my window right now damn you ek
NIKOND60
Old 05-18-2009, 10:04 AM   #68
popejooie
popejooie's Avatar
i had to replace both the regulators both the tracks and the weatherstripping to get my windows working, BUT the plastic clip for the passenger window piece broke as i was finishing up that side so now i gotta fix that but then FULLY WORKING POWER WINDOWS IN AN EK COUPE!!!!!!!!!!
popejooie is offline Report Post   Reply With Quote
Bookmarks
1992, automatic, average, back, car, civic, cost, diy, fix, honda, lube, pops, put, track, window
