d series ac compressor on b series motor?
ok i did an ls/vtec swap on my car and would like to keep ac. I have been told if i buy a crv ac bracket, the d16y8 ac compressor will bolt up to the crv bracket. Is this true? Will the compressor line up with the crank pulley correctly? any help would be great!
Re: d series ac compressor on b series motor? (Lordofdark176)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lordofdark176 »</TD></TR><TR><TD CLASS="quote">ok i did an ls/vtec swap on my car and would like to keep ac. I have been told if i buy a crv ac bracket, the d16y8 ac compressor will bolt up to the crv bracket. Is this true? Will the compressor line up with the crank pulley correctly? any help would be great!</TD></TR></TABLE>
yes this is absolutely true. i am running this on my b16. but here's the trick, you have to take the pulley off of the d-series bracket and put it on the crv bracket.
Re: d series ac compressor on b series motor? (philosofy1)
what do you mean take the pulley off the bracket? u mean use the crank pulley off the d16?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lordofdark176 »</TD></TR><TR><TD CLASS="quote">what do you mean take the pulley off the bracket? u mean use the crank pulley off the d16?</TD></TR></TABLE>
no, i'm totally sorry, don't know what the hell i was thinking.
you just need the crv bracket along with the pulley.
here take a look:
http://www.thehondapartsstore....ch=no
here take a look:
you may want to try to use the b series bracket you already have if you have one. a buddy of mine used to always bolt up d series comp. using 2 bolts into the brackets that came on the b series engine. he never had any problems running them that way. sorry for lack of details but its free to try it . good luck.
ok, so buy the crv ac bracket, then buy the idle pulley that goes on the ac compressor from a crv, replace the pulley thats on the compressor with the crv one, bolt it up and it should all work?
Re: d series ac compressor on b series motor? (JSPECSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR »</TD></TR><TR><TD CLASS="quote">you may want to try to use the b series bracket you already have if you have one. a buddy of mine used to always bolt up d series comp. using 2 bolts into the brackets that came on the b series engine. he never had any problems running them that way. sorry for lack of details but its free to try it . good luck.</TD></TR></TABLE>
thats a half *** job! i've seen it before, and i've also seen them get ripped out and tossed down the high way as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lordofdark176 »</TD></TR><TR><TD CLASS="quote">ok, so buy the crv ac bracket, then buy the idle pulley that goes on the ac compressor from a crv, replace the pulley thats on the compressor with the crv one, bolt it up and it should all work?</TD></TR></TABLE>
do it the right way. crv bracket, if you do not have a b-series pulley to go with it, then you will need the pulley and the pulley bracket from the crv as well.
go through the link i provided. it shows a diagram of the pulley, pulley bracket, and the compressor bracket.
compressor bracket part # 38930-P7J-000
pulley bracket part # 38941-P30-000
pulley part # 38942-P2K-T01
pulley adjusted bolt part # 90054-P3F-000 (you will definately need this bolt as well, being that the one off of your d16 is now useless).
ok so buy those parts and it will fit? sorry im so confused now lol
edit: ok i added up the part numbers you just showed me and majestic honda wants $135.27 shipped to my door step. god this is more expensive than i thought.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lordofdark176 »</TD></TR><TR><TD CLASS="quote">ok so buy those parts and it will fit? sorry im so confused now lol</TD></TR></TABLE>
sorry for the confusion. i'm taking that you do not no other a/c bracket other than your d-series one.
so if you are buying this starting fresh, then you will need to buy those parts i listed aolng with any other bolts that i have missed, but is necessary for it to work.
the dealer will be able to help you with that.
just a reminder, when you go to buy the compressor belt (if you don't have your old one), you will need to use the belt off of the d16.
there is a bracket on the engine already, we are not sure but i am guessing its an integra ls one because its a ls block. meh wen i get the car hopefully tonight ill try to identify it. if i took a pic would someone on here be able to tell me?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lordofdark176 »</TD></TR><TR><TD CLASS="quote">there is a bracket on the engine already, we are not sure but i am guessing its an integra ls one because its a ls block. meh wen i get the car hopefully tonight ill try to identify it. if i took a pic would someone on here be able to tell me?</TD></TR></TABLE>
chance are it is a b-series bracket. the bolt pattern to the block is the same, it's where the compressor mounts to that is different.
if that is the case your job has just become alot cheaper and easier.
just buy the crv a/c bracket, that's it. then unbolt everything from the ls brakcet and put it onto the crv one. it's cake!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
pulley adjusted bolt part # 90054-P3F-000 (you will definately need this bolt as well, being that the one off of your d16 is now useless).</TD></TR></TABLE>
can you post pics of these parts that are required to use a d series ac compressor on a b series swap?
Re: d series ac compressor on b series motor? (MeanGreenMachine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanGreenMachine »</TD></TR><TR><TD CLASS="quote">
this is exactly what is needed.
thanks!
so you ALL THE PARTS pictured in both of those links in order for a d series ac compressor to work with a b series swap into a 96 and up civic:???
96 and up civic because the op said d16y8 in the beginning lines of his post...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanGreenMachine »</TD></TR><TR><TD CLASS="quote">thanks!
96 and up civic because the op said d16y8 in the beginning lines of his post...</TD></TR></TABLE>
this is to use in any b-series motor in a civic, and continue to use the stcok civic a/c set up.
this is to use in any b-series motor in a civic, and continue to use the stcok civic a/c set up.</TD></TR></TABLE>
so you have to order the crv bracket, then the pulley, along with some others?
you could go to a salvage yard and get the WHOLE crv bracket that already has the pulley and all that good stuff right?
90 Si Hatch
08-13-2011 10:12 PM
Revolution2zz
07-27-2006 05:42 PM
38941p30000, ac, bolts, bracket, civic, compressor, compressors, honda, ls, motor, pulley, series, single, swap, work
