Old 07-31-2007, 07:32 PM   #1
6SPD_EK
6SPD_EK's Avatar
Default need info ABS vs non-ABS wheel hubs & bearings for civic / integra antilock brakes
Trying to get all my ducks in a row here & need help
most common brake swap is integra/civic ex.... a large percentage were originally antilock braking system.
there are different part # for front & rear hubs & bearings for the same brakes depending if they are ABS or non ABS.
question 1.) are the bearings & therefore the (inside of) the hubs different sizes? I assume there is somesort of magenetic pickup or something in the bearings for ABS system - correct or no?
question #2) if they are different sizes & I want new ones (both bearings & hubs) can I just get non-abs bearings with non-abs hubs? if i needed just bearings i would go with abs bearings but the rears are all sold as a hub/bearing assembly
6SPD_EK is offline   Reply With Quote
Old 08-01-2007, 03:24 AM   #2
6SPD_EK
6SPD_EK's Avatar
Default Re: need info ABS vs non-ABS wheel hubs & bearings for civic / integra antilock brakes (6SPD_EK)
bump -someone must know
Old 08-21-2008, 01:22 PM   #3
6SPD_EK
6SPD_EK's Avatar
found this but still need more info
Originally Posted by darrinbrewer
did some research on parts sites...
civic dx is 2.874 OD 1.4961 ID
integra is 3.1102 OD 1.6929ID
so, i have a civic dx knuckle, and ex abs(integra siz brakes) knuckles
axles that need civic knuckles..but i want to use bigger brakes
it sucks!
what are civic ex/si (abs) bearings?
abs, antilock, axles, bearing, bearings, civic, ek, front, honda, hub, hubs, integra, knuckle, knuckles, knucles, wheel, work
