> Honda Accord (1990 - 2002)
Old 07-30-2007, 02:29 PM   #1
BlkChryKord
Default 5-lug and Rear Disc Swap
OEM Parts Needed -
Front Knuckles L and R
Front V6 calipers L and R
Rear Knuckles L and R
Rear EX (4cyl) or V6 calipers L and R - they're the same
EX 4yl or V6 parking brake lines
OEM or Aftermarket rear disc brake lines - I used Russell SS lines
V6 Accord Rotors/Pads F and R
New Brake Fluid, OEM or Equivalent - I used Valvoline Syntec
Recommended - Change the outer tie rods and lower/upper ball joints if you haven't already. My tie rods were bad (torn) and my D. side lower ball joint was on its way out.
Recommended tools -
4 jack stands
Jack or two
Breaker bar (bigger the better)
17mm, 14mm 6 point sockets - preferably deep
17mm - 14mm wrenches
1/2" and 3/8" ratchets
Assorted extensions for both sized ratchets
Line wrenches (for brake lines)
PB Blaster
Propane torch (stubborn bolts or studs)
BFH - Big F*cking Hammer
Air gun
36mm socket (axle nut)
I haven't finished it yet, just got the fronts done last night and started on the rears today (7-30-07). Probably finish most of it by tonight or tomorrow. Still waiting on a few bolts to come in the mail and figuring out how I'm gonna get the parking brake lines out.
Hit a speed bump in the progress (7/30/07), one bolt on the rear pass side didn't wanna come out. It seized itself in and when I tried breaking it loose with the breaker bar I ended up tearing the rubber bushing loose. I called it quits @ 4 cuz I was just getting more pissed off and frustrated with it. Probably gonna end up cutting it out.
BlkChryKord is offline Report Post   Reply With Quote
Old 07-30-2007, 02:32 PM   #2
BlkChryKord
Default Re: 5-lug and Rear Disc Swap (BlkChryKord)
Pics
Old 07-30-2007, 03:56 PM   #3
AJ06
AJ06's Avatar
Send a message via AIM to AJ06
Niice
AJ06 is offline Report Post   Reply With Quote
Old 07-30-2007, 06:33 PM   #4
Cronousman
2000 Honda Accord
Cronousman's Avatar
=O how much money did you spend?
Honda Rocks!
Cronousman is offline Report Post   Reply With Quote
Old 07-31-2007, 05:30 AM   #5
BlkChryKord
Default Re: 5-lug and Rear Disc Swap (Cronousman)
I dunno, don't really care, I pieced it together here n there over like 5 months.
Old 07-31-2007, 06:43 AM   #6
awdgsx96
awdgsx96's Avatar
That's a good idea. I want to do a ROH conversion in front and disc in back. Whenever I see parts for the conversion I grab them up when their cheapest
(__/)
(o.O )
(> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination
Originally Posted by that guy steveee
since we know you're gay for doing this just put, "talk to the hand, bitch"
awdgsx96 is offline Report Post   Reply With Quote
Old 07-31-2007, 10:15 AM   #7
BlkChryKord
Made more progress than I thought I would this morning. Parking brakes (e-brake) are done, everything else is bolted up except the rear calipers cuz I don't have any bolts that will fit the holes. So...on with the pics! FYI - these are in reverse order.
Side view...guess you cant really see much.
Rear pass side
Rear D. side
New e-brake cables in
This bolt was a bitch to get out and an even bigger bitch to get back in.
These holes are where the two brackets for the D. side e-brake cable mount, the smaller hole is for a tab on the bracket, the larger is of course for a bolt. These were also a bitch to get back in.
Old e-brake cables, D. side out - that's the back of the carpet showing through that hole. The cables pull right out as soon as you unbolt and unhook them.
Removing old e-brake cables, grab the cable and turn it to the open side (right for Pass, left for Driv) and pull and thats it.
How its all put together once you remove the console, yes I will be cleaning it once I get to it.
Same stuff as above, just a closer shot.
Old 08-02-2007, 12:27 AM   #8
kbud
kbud's Avatar
What make/model rear knuckles did you use?
kbud is offline Report Post   Reply With Quote
Old 08-02-2007, 08:22 AM   #9
oem_certified_accord
oem_certified_accord's Avatar
which makes me wonder...has anyone ever run seperate lug patterns.. like 5 in front 4 in back or likewise? doubt it would make any sense but it would be different.
CD Squad
WhiteOnRice, gen5accstilez, TheMuffinMan, integrated civic
oem_certified_accord is offline Report Post   Reply With Quote
Old 08-02-2007, 08:01 PM   #10
BlkChryKord
Default Re: 5-lug and Rear Disc Swap (kbud)
Toyota Paseo
Well..I already put down that its V6 knuckles in the first post under what parts you'll need. Its a 98, which would probably mean 98-02 accord parts since not much else will fit.
Old 08-03-2007, 12:25 AM   #11
SuShiBoiiii
SuShiBoiiii's Avatar
Send a message via AIM to SuShiBoiiii
why dont you just get new bolts?
ALL*STAR*DETAIL
SuShiBoiiii is offline Report Post   Reply With Quote
Old 08-03-2007, 08:44 AM   #12
kbud
kbud's Avatar
How about clarifying what year your car is and what year parts used?
Old 08-03-2007, 09:29 AM   #13
BlkChryKord
Why would I get new bolts for something under the car that's just gonna rust anyways and I'll never remove again?
Kbud - how about you read up 2 posts from this one and my first post.
Old 08-03-2007, 09:47 AM   #14
kbud
kbud's Avatar
Default Re: (BlkChryKord)
No years posted in the first post. In the third post up, are you saying your car is a '98 and that you used '98-02 parts?
Old 08-03-2007, 10:25 AM   #15
chido
chido's Avatar
Props again bro...well done and a sweet ass upgrade
chido is offline Report Post   Reply With Quote
Old 08-03-2007, 04:10 PM   #16
BlkChryKord
Default Re: (kbud)
Correct!!!
Old 07-07-2009, 01:49 PM   #17
raukorist77
1992 Honda Accord
Send a message via AIM to raukorist77
help guys i really want to do this to my 92 accord LX but all the photos in this thread are gone
raukorist77 is offline Report Post   Reply With Quote
Bookmarks
