Last edit by: IB Advertising
Browse all: Specifications and General Overview
- General Information and Maintenance Schedule
Important information to help you understand your Honda
1996 to 2000 Civic Maintenance Schedule
H-T White Ops
I noticed there are a few threads regarding this, but from what I saw, one was an image, which is now down, and another is from the Haynes manual. This is from Honda, so it should be a bit more reliable as far as information goes.
If you plan on storing your vehicle long term, read this thread too:
Storing Your Car
So, here it is in case anyone has lost it. Straight from the Honda Owner's Manual for my '98 EX coupe.
MAINTENANCE SCHEDULE
The Maintenance Schedule specifies how often you should have your car serviced and what things need attention. It is essential that you have your car serviced as scheduled to retain its high level of safety, dependability, and emission control performance.
The service and time or distance intervals shown in the maintenance schedule assume you will use your car as normal transportation for passengers and their possessions. You should also follow these recommendations:
- Avoid exceeding your car's load limit. This puts excess stress on the engine, brakes, and many other parts of your car. The load limit is shown on the label on the driver's door jamb.
- Operate your car on reasonable roads within the legal speed limit.
- Drive your car regularly over a distance of several miles (kilometers).
- Always use unleaded gasoline with the proper octane rating.
Which Schedule to Follow:
Service your car according to the time and mileage periods on one of the Maintenance Schedules on the following pages. Select the schedule for "Severe Conditions" if most of your driving is done under one or more of the conditions listed on that page. Otherwise, follow the schedule for "Normal Conditions."
MAINTENANCE SCHEDULE (NORMAL CONDITIONS)
Follow the Normal Maintenance Schedule if the severe driving conditions specified in the Severe Conditions Maintenance Schedule on the next page do not apply.
NOTE: If you only OCCASIONALLY drive under a "severe" condition, you should follow the Normal Conditions Maintenance Schedule.
Service at the indicated distance or time - whichever comes first.
15000 MILES, 24000 KM, OR 12 MONTHS (1 YEAR)
Replace engine oil filter
Inspect front and rear brakes
Check parking brake adjustment
30000 MILES, 48000 KM, OR 24 MONTHS (2 YEARS)
Replace air cleaner element
Inspect valve clearance [at 30000 miles (48000 km) only]
Replace spark plugs
Inspect and adjust drive belts
Replace transmission fluid (CVT)
45000 MILES, 72000 KM, OR 36 MONTHS (3 YEARS)
Replace engine coolant
Replace brake fluid
60000 MILES, 96000 KM, OR 48 MONTHS (4 YEARS)
Replace spark plugs
75000 MILES, 120000 KM, OR 60 MONTHS (5 YEARS)
90000 MILES, 144000 KM, OR 72 MONTHS (6 YEARS)
Replace spark plugs
Replace transmission fluid (MT/AT/CVT)
Replace brake fluid
105000 MILES, 168000 KM, OR 84 MONTHS (7 YEARS)
Replace timing belt and inspect water pump
Inspect idle speed
120000 MILES, 192000 KM, OR 96 MONTHS (8 YEARS)
Replace spark plugs
OTHER:
Replace engine oil every 7500 miles (12000 km) or 12 months (1 year)
Check engine oil and coolant at each fuel stop
Rotate tires every 7500 miles (12000 km)
Inspect Supplemental Restraint System 10 years after production
ALSO:
Visually inspect the following items every 15000 miles, 42000 km, or 12 months (1 year):
Tie rod ends, steering gear box, and boots
Suspension components
Driveshaft boots
Brake hoses and lines (including ABS)
All fluid levels and condition of fluids
Cooling system hoses and connections
Exhaust system
Fuel lines and connections
MAINTENANCE SCHEDULE (SEVERE CONDITIONS)
Follow the Severe Maintenance Schedule if you drive your vehicle MAINLY under one or more of the following conditions:
- Driving less than 5 miles (8 km) per trip or, in freezing temperatures, driving less than 10 (16 km) per trip.
- Driving in hot [over 90°F (32°C)] conditions.
- Extensive idling or long periods of stop-and-go driving.
- Driving with a car-top carrier, or driving in mountainous conditions.
- Driving on muddy, dusty, or de-iced roads.
Replace air cleaner element (Use normal schedule except in dusty conditions)
Lubricate locks and hinges
Clean antenna mast
Replace spark plugs
Clean antenna mast
Replace brake fluid
Clean antenna mast
Replace spark plugs
Clean antenna mast
Clean antenna mast
Replace spark plugs
Replace brake fluid
Clean antenna mast
Inspect idle speed
Clean antenna mast
Replace spark plugs
Clean antenna mast
OTHER:
Replace engine oil and oil filter every 3750 miles (6000 km) or 6 months
Inspect front and rear brakes every 75000 miles (12000 km) or 6 months
ALSO:
Visually inspect the following items every 7500 miles (12000 km) or 6 months:
Driveshaft boots
Exhaust system
Lights and controls
Vehicle underbody
OWNER MAINTENANCE CHECKS
You should check the following items at the specified intervals.
- Engine oil level - Check every time you fill the fuel tank.
- Engine coolant level - Check the radiator reserve tank every time you fill the fuel tank.
- Windshield washer fluid - Check the level in the reservoir monthly. If weather conditions cause you to use the washers frequently, check the reservoir each time you stop for fuel.
- Tires - Check the tire pressure monthly. Examine the tread for wear and foreign objects.
- Lights - Check the operation of the headlights, parking lights, taillights, high-mount brake light, turn signals, brake lights, and license plate lights monthly.
Storing Your Car
Gasoline
Your Honda is designed to operate on unleaded gasoline with a pump octane
number of 86 or higher. Use of a lower octane gasoline can cause a
persistent, heavy metallic rapping noise in the engine that can lead to
mechanical damage.
We recommend gasolines containing detergent additives that help prevent fuel
system and engine deposits.
Using gasoline containing lead will damage your car's emissions controls.
This contributes to air pollution.
In Canada, some gasolines contain an octane-enhancing additive called MMT.
If you use such gasolines, your emission control system performance may
deteriorate and the Malfunction Indicator Lamp on your instrument panel may
turn on. If this happens, contact your authorized Honda dealer for service.
mechanical damage.
Replace spark plugs
Replace brake fluid
Replace spark plugs
Replace spark plugs
Replace brake fluid
Inspect idle speed
Replace spark plugs
OTHER:
ALSO:
Driveshaft boots
Exhaust system
Clean antenna mast
Replace spark plugs
Clean antenna mast
Replace brake fluid
Clean antenna mast
Replace spark plugs
Clean antenna mast
Clean antenna mast
Replace spark plugs
Replace brake fluid
Clean antenna mast
Inspect idle speed
Clean antenna mast
Replace spark plugs
Clean antenna mast
OTHER:
ALSO:
Driveshaft boots
Exhaust system
Lights and controls
Vehicle underbody
The following 2 users liked this post by NOFX:
Scoopy
11-20-2008 08:42 AM
Jonas99
02-24-2007 06:41 PM
