Old 07-26-2007, 11:03 AM   #1
mac_24_seven
1994 Acura Integra
mac_24_seven's Avatar
Default DIY: Moon cut valve cover for GSR, ITR heads.. Very detailed!
Figure'd I'd post this for the civic guys who has GSR and ITR swaps.
<FONT COLOR="Red"><FONT SIZE="3">DIY: Moon cut valve cover!</FONT></FONT>
Tools needed:
Valve Cover
Drill
1/8 bit
3 1/2" hole saw&lt;----- Seems to be the perfect size
Pilot bit holder thingy (don't know the exact name, sorry)
Hammer
Punch (or Phillips screw driver)
A buddy (or a vice)
Optional: A file to smooth down the edges.
Step 1: Locate your valve cover, remove it and get your tools ready to modify your valve cover!!!
What your starting out with. I used the pic as a size reference for the cam gears.
Step 2: Measure to find the center of the cams. To the center of the lil slot, it's 2 5/8", approx. May be a 1/16th off or so.
Step 3: Indent the valve cover where your going to drill, and drill a pilot hole. I made my indentions, using the hammer and a punch, about at the top of the lil ridge on the valve cover. Reference t3h pic plz.
Step 4: Put the hole saw on the drill w/the pilot bit. Using a buddy or a vice (I used my good friend Dan) secure the valve cover so it won't move, muster up some courage and start cutting the valve cover. Maybe you'll end up with something like this.
You know I gotta throw a thumbs up in there
Step 5: Optional: Using a file, file down the sharpe edges till they are smooth. Don't want to possibly knick your timing belt when you re-install your valve cover. his may keep you from possibly cutting youself too, but who cares: Your finger will heal for free, you'd have to BUY a new timing belt Plus chics dig scarzz
Step 5 (or Step 6 if optional step is used): Clean the valve cover. Don't want any bits of metal in your engine do you? I didn't think so. Clean it as best as you can.
And.................... Well, I did this about 30 mins ago, and I won't be installing my head untill next weekend, so no finished pics of it on the car, but I'll update whenever I can.
Hope this works for you guys. I didn't see a DIY detailed enough for my liking, so maye this will help somebody one day
If you see anything that could add to this DIY and make it more helpful, by all means, let me know and I'll change it.
Enj0y!
Modified by mac_24_seven at 6:38 AM 8/1/2007
94' GSR "Aeris":Turbo, shaved bay, wire tucked and more. Over 50 DIY's!
336,000 views! ITR header skid plate:$40 shipped
Precision SC34 Turbo 7lbs ---- Built, not $bought$.
mac_24_seven is offline Report Post   Reply With Quote
Old 07-26-2007, 11:05 AM   #2
bpkmrtoes
bpkmrtoes's Avatar
Send a message via AIM to bpkmrtoes
Default Re: DIY: Moon cut valve cover for GSR, ITR heads.. Very detailed! (mac_24_seven)
coool....
bpkmrtoes is offline Report Post   Reply With Quote
Old 07-26-2007, 11:11 AM   #3
andoxviii
2000 Honda Civic
andoxviii's Avatar
not too shabby.
now if only i had a b-series....
andoxviii is offline Report Post   Reply With Quote
Old 07-26-2007, 11:20 AM   #4
VRD^don
VRD^don's Avatar
Default Re: DIY: Moon cut valve cover for GSR, ITR heads.. Very detailed! (andoxviii)
OLD^skool
VRD^don is offline Report Post   Reply With Quote
Old 07-26-2007, 11:28 AM   #5
philosofy1
philosofy1's Avatar
what about b16 swaps?
good write up though, i have to repaint my valve cover soon, i'l most likely do this prior to the paint.
saved on my favorites!
VTEC Cam Identification: http://www.ff-squad.com/tech/temp/VtecCams.htm
philosofy1 is offline Report Post   Reply With Quote
Old 07-26-2007, 11:38 AM   #6
mac_24_seven
1994 Acura Integra
Default Re: DIY: Moon cut valve cover for GSR, ITR heads.. Very detailed! (philosofy1)
Can somebody verify the valve cover for the B16 is the same as the GER and ITR?
I think it is, but I'm not 100% sure.
Old 07-26-2007, 11:46 AM   #7
philosofy1
philosofy1's Avatar
all b-series vtec heads have the same valve cover.
Old 07-26-2007, 11:58 AM   #8
slowmanEK
1999 Honda Civic
slowmanEK's Avatar
Send a message via AIM to slowmanEK
Co Signed.
Awesome write up
slowmanEK is offline Report Post   Reply With Quote
Old 07-26-2007, 12:36 PM   #9
95ProjectEJ1
95ProjectEJ1's Avatar
Send a message via AIM to 95ProjectEJ1
Default Re: DIY: Moon cut valve cover for GSR, ITR heads.. Very detailed! (slowmanEK)
IFPWIGH!!!
95ProjectEJ1 is offline Report Post   Reply With Quote
Old 07-26-2007, 12:38 PM   #10
fmrprojects
fmrprojects's Avatar
Send a message via AIM to fmrprojects
Default Re: DIY: Moon cut valve cover for GSR, ITR heads.. Very detailed! (95ProjectEJ1)
nice
GOOKSPEED | REDZONE PERFORMANCE
92 Civic CX SP Dragcar
http://www.honda-tech.com/zerothread?id=1684896
fmrprojects is offline Report Post   Reply With Quote
Old 07-26-2007, 12:47 PM   #11
BlackoutVTi
BlackoutVTi's Avatar
Send a message via AIM to BlackoutVTi
Default Re: DIY: Moon cut valve cover for GSR, ITR heads.. Very detailed! (fmrprojects)
Pretty good. A simple thing, but a good DIY nonetheless
Why do people always ask if I'm Fillipino, Vietnamese or Japanese? Nobody ever guesses that I'm Chinese
It's racist to assume the obvious, didn't you know?
BlackoutVTi is offline Report Post   Reply With Quote
Old 07-26-2007, 01:25 PM   #12
bright rider
bright rider's Avatar
good work.!!!!!
bright rider is offline Report Post   Reply With Quote
Old 07-28-2007, 12:50 PM   #13
mac_24_seven
1994 Acura Integra
DIY: Painted valve cover.. Part 1
This isn;t really a DIY, per se', it's more of a pictage type thing of how things can be going so well, then turn bad so quickly .
It started out well.. I bought my supplies.
Time to try out paint remover.. Never used the stuff before. As soon as I finished spraying it, I took the following pics.. AWESOME STUFF!!!!
OH yeah!!! Things are going niceely.
Just using the hose, it comes off this easy...
And finishing sparying it..
Sweet, this is going good.
Time to wash it off with some dawn to remove any oils and whatnot.
Now, I had to wait for it to dry.. So, I decided to play with some old wheels Andrew has...
Before spray...
After spray.. Sick
and after a quick spray with the hose..
Sweet
OK, back to the valve cover.. It's dry now (hott day in Florida BTW)
So, I needed something to put over the letters on the valve cover, so when I spraye, I could just spray the letters and when I"m done, wipe it off nice and clean.
Not having any jelly or anything, I found some.. Lipstick!! Little did I know that this seemingly, innocent sitck of lipstick would ultimately be my un-doing......
Lipstick applied
Gotta throw the thumbs up in there
So, before I sprayed my valce cover, I wanted to see what it was gonna look like.. So I sptayed another old wheel of Andrews.
Maybe he won't mind
After painting that wheel, on my way back to my valce cover, I figured I"d take a pic of my wifes Accord and my buddy's civic..
SO I put the first coat of paint on my valve cover.
It's suppose to look liek thing.. hammered Bronze.
Doesnt look very hammered.
So I sprayed 2 moer coats on it and.. well, I just wasnt feeling it at all. SO, back to lowes I go to get some more paint. I get a much lighter hammered steel paint.
Somewhat hammered looking. Ehh, not really. But I ilked it better than the bronze-ish stuff.
SO, after 2 coats of that, it's time to remove the lipstick/p[aint from the letters on the valve cover.
Some TP to wipe it off with.
DANGER!!!! I'm an effin' idiot. Sometimes I should just stop while I'm ahead. But nooooooooooooooooooooooooooo....
So, damnit... I've messed it up. Thats ok though, I've got my handy dandy paint remover stuff! I'll just spray it, reove the paint, and re-spray it again.
WRONG!
I ran out of stuff.
&lt;sighs&gt;
SO.... This is what I have now
And after some more spraying..
Cliffs..
Beginning:
After paint remover:
After the bronze.
After the gray.
After I become more of an idiot.
So... yeah What can I say? I'm a n00b Something that can be so easy can turn wrong very quickly.. Always remember that when your working on a car or anything, really.
Maybe I should have just wet with the wrinkle ITR red
Enj0y!
Old 07-28-2007, 12:58 PM   #14
Hans Moleman
Hans Moleman's Avatar
Location: The Place that everybody call the southland on the, SPLA
LOL
That's a pretty cool DIY and sucks for your valve cover, but I enjoyed it for some crazy reason.
Hans Moleman is offline Report Post   Reply With Quote
Old 07-28-2007, 02:57 PM   #15
dhatb0ijohnny
dhatb0ijohnny's Avatar
so what did you use to fix the lipstick/lettering problem?
dhatb0ijohnny is offline Report Post   Reply With Quote
Old 07-28-2007, 05:11 PM   #16
em1foyo
em1foyo's Avatar
Default Re: (dhatb0ijohnny)
good stuff man. your thread was like a whole story. be sure to post up the final result.
em1foyo is offline Report Post   Reply With Quote
Old 07-28-2007, 05:38 PM   #17
hondakevin21
hondakevin21's Avatar
Default Re: (em1foyoass)
What you should've done before the lipstick incident was take some emory cloth to the lettering then got some masking tape and a razor, tape off the lettering, and cut the excess tape from the lettering. Sprayed the v.c. and removed the tape, that way the lettering would be nice and silver, and you would've got between each letter But I enjoyed the DIY
"Better to be a racer for a moment, than a spectator for life"
1997 Civic hatch, B18c1.
2003 Yellow AP1 stock......for now
hondakevin21 is offline Report Post   Reply With Quote
Old 07-28-2007, 06:04 PM   #18
RedEj8
RedEj8's Avatar
Send a message via AIM to RedEj8
Default Re: (hondakevin21)
Good write up! Ive been thinking of doing the moon cut to my valvecover for like 4 years.
Poormans R- EJ8
EJ8 Squad #261
RedEj8 is offline Report Post   Reply With Quote
Old 07-28-2007, 06:52 PM   #19
Ek4 life
Ek4 life's Avatar
Default Re: (RedEj8)
Or you know what you could have done after spraying your valve cover, take a dremel and dremel the logo's. That's what I did to mine and it looks great.
Ek4 life is offline Report Post   Reply With Quote
Old 07-28-2007, 07:04 PM   #20
Aralliius
Aralliius's Avatar
Send a message via AIM to Aralliius
Default Re: (Ek4 life)
very nice what kind of rims are those in the black civic?
Aralliius is offline Report Post   Reply With Quote
Old 07-28-2007, 07:36 PM   #21
Harryflores
Harryflores's Avatar
Default Re: (Aralliius)
Use the VHT wrinkle red spray it over then use a blade to remove paint from DOHC lettering.... easy as hell!
H. Flores
Run your car not your mouth
Honda-Tech should be sponsored by Kelloggs because it's full of Flakes
Vouches:HMO|y0whuddupb|Yogi[Supastar]|JDMDC213|cxSHOE|Jarel|
Harryflores is offline Report Post   Reply With Quote
Old 07-28-2007, 07:38 PM   #22
Harryflores
Default Re: (Harryflores)
and I forgot ... don't use your fingers to take off the Aircraft Remover!! use Brake cleaner
H. Flores
Old 07-28-2007, 08:34 PM   #23
Phil_Eg
2000 Acura Integra
Phil_Eg's Avatar
Send a message via AIM to Phil_Eg
sweet man looks easy!
SolFRESH // DC Squad // wēk'sôs // Canon // Flickr
2000 Vsm Integra Ls
Phil_Eg is offline Report Post   Reply With Quote
Old 07-28-2007, 09:12 PM   #24
sageuvagony
sageuvagony's Avatar
Send a message via AIM to sageuvagony
B series trying to be cool like us D series people by cutting holes
1997 Integra GSR and 1992 Civic LX
(__/)
(0.0 )
(&gt; &lt; )
Originally Posted by BOOSTED RIVAL
7500 to 8000 rpm? do you want your pistons to uppercut your valves?
Originally Posted by tbones
how do i check or change muffler bearings ..?! i would'nt think it would go wrong after 6 months ,
whats turn turn signal fluid?/?
sageuvagony is offline Report Post   Reply With Quote
Old 07-29-2007, 03:55 AM   #25
methos713
methos713's Avatar
Default Re: (sageuvagony)
nice write up.
Vouch list: eg8kid, redasphalt, camp1320, jdmstylesi/robearracing, N.O.B, #1151, R6Boy69, PerformanceCloseout, ValleySyder, OnlyHJC, civic dx 4dr, GoT HaTcH, Hondaruss, regamaster, soulpwr, sky9, acuraturbo90, thareddb, 96civic_hb
http://images.honda-tech.com/set1/smile/emthup.gif
methos713 is offline Report Post   Reply With Quote
Bookmarks
b16, cover, covers, cut, diy, gsr, honda, install, moon, mooncut, paint, series, valve, valvecover, valves
