#1 |
2008 Civic Si RR coupe FS. CE-28's 17x8.5 +30mm 4x114.3 IM me for details/pics http://hondamarketplace.com/showthread.php?t=2598796 |
#2 | |
He knows where you live!
very nice!
2004 NFR S2000 Quote:
#3 |
Thanks for posting this... will save me from getting frustrated when attemping to wire mine up!
CD squad #016 "it is dangerous to be right when the government is wrong" (Voltaire) |
#4 |
1997 Honda Accord |
Here's a trivial question, but I'm not sure if I was the only one wondering. The wires you have that go to nothing, (they say door harness or mirror harness) those are already wires that exist in our cars correct?
Ballz CD Squad Member126 H Deuce Deuce + Boost |
#5 |
correct. The three wires that were on the original mirrors can stay there . The two that you are adding need to be run to the relay.
give me some more time and i will explain it more in my original post.
#6 |
1997 Honda Accord |
You got all the time in the world. Didn't mean to bomb you with questions and be impatient. I was just going to start wiring these ASAP. I'll hold any further questions until after you've posted the whole thing.
#7 |
I dont care, throw questions out there in the meantime. it should help future patrons who intend on doing this!
#8 |
1997 Honda Accord |
OK regardless of color of wire, the pins you show connect to each other? The way I understand it is that you just made the wires the same color for simplicity. My wires may be different colors than yours, but as long as I connect as you show I'll be good correct? The main thing I see as being troublesome is the wiring of the passenger side and connecting it over to the driver side.
#9 | ||
Still working on this thing. There's a lot to be dictated yet. I will hopefully have pictures to help out the discussion soon!
#10 |
Good stuff... i hope to be working these wiring on my car in 2 weeks or less!
#11 |
1997 Honda Accord |
I'm gonna start soldering my wire harness sometime in the next week or so. I'll take pics as well so others can share my experience.
#12 |
i didnt do any soldering. I just used those electrical wire caps. Twisted together the wires and afterwards, twisted the caps on.
Solder might be a little extreme in this case. But hey whatever you do to to make it more professional is your choice
#13 |
Video And more pics added.
#14 |
1997 Honda Accord |
I know the soldering isn't really needed, but it will give me added peace of mind to make sure they won't come undone. It's just a pain to have to go back in and reconnect something a second time.
#15 |
I want to thank you for this thread, you made it look so easy am going to have to try this.
Try not, do or do not. There is no try! http://www.exfuze.com/luisramirez The greatest supplement on earth!! |
#16 |
1997 Honda Accord |
Is the depinning only needed if you are swapping the housings?
#17 |
you might have to de-pin the connectors "on the mount plate" in order for the switch to move the mirror plates in the proper direction.
like if you push up with the switch sold to you with your set, it might actually move the mirror down. This happened to me when i first installed them. So i had to try a couple different combinations of the pins in order for them to move in the proper direction.
#18 |
Thanks for the write-up. Can you go into more detail on which pins you had to switch around to get the mirrors to move correctly, possibly even with pics? Also can you explain more fully exactly how you depinned the connectors and which ones needed it?
Thanks! |
#19 | |
de-pinning any connector on a harness takes a little bit of studying. look at every connector carefully and you'll find a way to remove the pins. If necessary look de-pinning up on google or something. I wont be able to give a color coordination key for the wires, as some of the wires actually connect to a different color where they have been spliced. The diagram i have posted should be adequate enough to understand which wires need to go where. A couple other guys here in the Accord section are doing the powerfolds to their Accords as we speak. If they feel obligated, they can add any information to this write up to help out.
#20 |
The diagram below was originally done by arrzobuner for 4th gen accords, then revised by npor to correct a few problems (both cb7tuner members), and now revised again by me, but to work with our 5th gen accords. I tested it and everything works correctly! So here ya go ... enjoy!
![]() I finally hooked everything up in the car ... everything works! You have two options for wiring up the switch ... OPTION 1: use the stock wiring. just de-pin the red / green wire from the jdm harness and put it where it belongs (see diagram above). next, connect the red / green wire to the blue / yellow wire on the relay. OPTION 2: cut the stock harness off and splice in the jdm switch wiring. all the wires match up color wise except for 4 wires because the parts are from a jdm car and everything is backwards. also, connect the red / green wire to the blue / yellow wire on the relay. this is how the wires need to be switched around ... JDM Switch Wiring --------------> Stock Switch Wiring Blue / Orange -------------------> Lt. Green Lt. Green ------------------------> Blue / Orange Blue ------------------------------> Yellow / White Yellow / White --------------- --> Blue DON'T FORGET to change out the 7.5amp fuse in slot 7 (in the under dash fuse box) to a 10amp one as HateBreeder touched upon. Otherwise the second you try to use the powerfolding option, it will blow ... leaving you confused I made this mistake at first ...Modified by Slomies at 11:57 AM 8/9/2007
FS: Virgin P06's (auto & manual), Virgin P28 (auto) - can convert auto to manual Vouches: mikegeezy, tegasaurus, tegpilot, 2lude4u, momstaxi, DC2-JRSC'd, 91bluehatch |
#21 |
yes! thanks for the wiring diagram. Just as i figured there are a few different ways you can wire them in, Thanks for the info!
#22 |
daaanm.. just looking at that diagram... scares the hell out of me..... hope i understand it well to do mine!
#23 |
honestly it isn't that hard. don't let it scare you. now if you didn't have a diagram, then i would be scared. i was a bit when i looked at the work that HateBreeder did, but nothing a lil determination didn't fix lol
#24 |
1997 Honda Accord |
This guy above me mentioned on Gen5Alive to make sure and change the fuse for a bigger one. I think it was 10 amp? Forget the slot it's in. He knows.
#25 |
its written up in the write up. It is suggested you bump your slot "7" fuse under the drivers side of the dash to a 10 amp.
| Bookmarks |
| Tags |
| accord, connect, dc2, depin, diagram, folding, installation, jdm, mirror, mirrors, power, prelude, side, wire, wiring |
