anyone using skunk2 pro1's?
Old 07-23-2007, 05:55 PM
eglslsd's Avatar
Default anyone using skunk2 pro1's?
a have a stock type r head that im going to install in my LST setup
im going to go ls/vtec. if i use the skunk2 pro1's camshafts do i have to upgrade
the valve stem and retainers or can i just run it with my stock valve stem and retainers that came with the type r head and just upgrade the camshafts?
Old 07-23-2007, 06:20 PM
eglslsd's Avatar
Default Re: anyone using skunk2 pro1's? (eglslsd)
anything anyone
Old 07-23-2007, 06:29 PM
chubz0r's Avatar
im pretty sure you will have to or should upgrade your valves, springs, and retainers if you are going to use these. thats what i was recommended by others when i was going to run these.
Old 07-23-2007, 06:37 PM
eglslsd's Avatar
Default Re: anyone using skunk2 pro1's? (chubz0r)
will it make that much of a difference if I upgrade?
Old 07-23-2007, 07:58 PM
been there done that
doood's Avatar
tony1 and someone else recently did tests with the pro1's. search for the threads.
Kr4nG
06-12-2009 07:41 AM
Speed_1
08-03-2006 01:13 PM
1hotintegra
04-07-2004 10:02 AM
1hotintegra
06-16-2003 08:05 AM
Quick Reply: anyone using skunk2 pro1's?
