| Welcome to Honda-Tech! | ||
#1 |
How hot does an exhaust manifold get on 2001 1.7 L LX civic? Mine is cracked and I just want to do a quick fix until I get all the part in. I have a 2001 LX civic and wanted to use Alumiweld to fix it but it's working temperature is 730 degrees F.
#2 |
1992 Honda CivicMy Garage |
yah, at times you can almost double that for the gasses going through it. I'm not sure how hot the actual manifold gets, but I'd bet it's more than 750*F.
Permatex makes stuff for exhaust patching, you may want to look into that at your local parts store. edit: part #26346 is what I'm thinking of .... http://www.amazon.com/Permatex...LBZMG |
#3 |
Hey Relic,
Thanks man! Didn't know about the Permatex stuff. I will use it instead. Thanks again. |
#4 |
no problem.
be sure to post how it works. |
#5 |
um alot hotter than 750
#6 |
Sanji
The hottest exhaust temperatures should get, would be around 1400 degrees Fahrenheit.
#7 |
dont waste your time with the exhaust patches, it will not work, i promise you. the exhaust, not to mention the manifold (which gets even hotter), will heat up so much that the patch will just burn in a matter of minutes. plus, on a LX model, the cat sits on the exhaust manifold, so it will get even hotter than a manifold without a cat.
just get yourself an new manifold or header. |
#8 |
when i go touge with my crew my headers glow bright orange.. so however hot that it is lol
FG SQUAD #1 / NOTHING ON MY CAR IS FOR SALE UNTIL MAY 16TH!!!!! |
| Tags |
| caravan, civic, cracked, exhaust, fix, header, headers, honda, hot, manifold, manifolds, patch, permatex, quick, work |
