Old 07-17-2007, 11:52 AM   #1
T Rick
Send a message via AIM to T Rick
Default How to remove An EG dash
I GOT RID OF MY HATCH AND GOT A MOTORCYCLE SO I CANT TAKE NEW PICS SO....... I MADE ONE.
First off take the steering wheel off its not hard you only take out 2 star screws on the side of the wheel.
When those are out take out the airbag and unplug it.
When that is out then take out the large bolt in the middle.
Then the blinker switch and the windsheild wiper switch comes out but you have to unscrew 2 screws and take a flathead stick it here.
now take out the section where the cigarrette plug in is(4 screws 2 on top and 2 on the side)Take out the screw wen off
Then take out the glove box which is not hard there is like 4 screws.
You will need to take out the speed ometer.
Now on the top of the dash(middle) is that vent thing. pop that off with a flathead from the side. When off take out the screw(I think they are all 10 mm or maybe 12mm)
Now to take out the passenger air bag when the glove bx is out look under there and you will see 6 bolts that need to be taken out.
take out your stereo, unplug the wires on the driverside underdash fuse box.
Now work the dash board off and unscrew or unplug anything holding back.
now on both sides there are screws under the caps.
Modified by T Rick at 12:18 PM 7/17/2007
Modified by T Rick at 11:27 PM 10/21/2008
T Rick is offline Report Post   Reply With Quote
Old 07-17-2007, 12:24 PM   #2
Felliph3
Sick writeup!! I was looking for one....Good job
PS:Nice sandals :-p
Felliph3 is offline Report Post   Reply With Quote
Old 07-17-2007, 12:39 PM   #3
MagnaniEG6
MagnaniEG6's Avatar
Send a message via AIM to MagnaniEG6
Default Re: (Felliph3)
F/S: 2006 BMW 325 VMR V710 Wheels, the beater...
MagnaniEG6 is offline Report Post   Reply With Quote
Old 07-17-2007, 12:39 PM   #4
T Rick
i new somebody would see those. i live in oregon and its pissin rain outside. well somebody needed help so put on my gals sandles and took a few snaps
Old 07-17-2007, 12:50 PM   #5
perseverance
perseverance's Avatar
thx bro, as soon as i get some more money... i'm gonna go get a black interior from a salvage yard. hopefully this write up will help out. anyway u can give more info on taking off the steering wheel?
perseverance is offline Report Post   Reply With Quote
Old 07-17-2007, 01:15 PM   #6
bara6075
bara6075's Avatar
Default Re: How to remove An EG dash (T Rick)
bara6075 is offline Report Post   Reply With Quote
Old 07-17-2007, 01:44 PM   #7
instructor74
instructor74's Avatar
Send a message via AIM to instructor74
Default Re: How to remove An EG dash (bara6075)
THIS IS HUGE before you unhook the air bag plugs you must disconnect the neg battery terminal and wait 5 mins or longer. It is now safe to unplug the air bags make sure you install the safety jumper to keep the air bag from being set off be accident.
current cars
93 Civic Si got her new with 12 miles over 235,000 still running strong
09 Civic Si got 50 miles on the clock hope she is as good as the 1st one
instructor74 is offline Report Post   Reply With Quote
Old 07-17-2007, 01:49 PM   #8
T Rick
Default Re: How to remove An EG dash (instructor74)
o ya forgot you must unhook your battery and to take off the steering wheel there are side plastic peices that come off and there are star screws on each side that you unscrew when the are out take out the center of our steering wheel(airbag) unhook the plug and the take out the huge bolt on your steering wheel(Not hard to miss) Then its off
Old 07-17-2007, 01:53 PM   #9
Felliph3
Damn it, i was going to type that too but my internet went down and when it went back up i forgot. But yea be very careful or it will activate on your ass and knock you out for like 5 minutes.
Old 07-17-2007, 02:11 PM   #10
jus_spooln_wicha
jus_spooln_wicha's Avatar
Default Re: How to remove An EG dash (Felliph3)
is that a jdm climate control?
a href="http://photobucket.com" target="_blank"></a>
jus_spooln_wicha is offline Report Post   Reply With Quote
Old 07-17-2007, 02:34 PM   #11
methos713
methos713's Avatar
Default Re: How to remove An EG dash (jus_spooln_wicha)
Should sticky this. By the way, how what does the safety jumper look like? Can't you just unplug the srs plug underneath the dash?
Vouch list: eg8kid, redasphalt, camp1320, jdmstylesi/robearracing, N.O.B, #1151, R6Boy69, PerformanceCloseout, ValleySyder, OnlyHJC, civic dx 4dr, GoT HaTcH, Hondaruss, regamaster, soulpwr, sky9, acuraturbo90, thareddb, 96civic_hb
http://images.honda-tech.com/set1/smile/emthup.gif
methos713 is offline Report Post   Reply With Quote
Old 07-17-2007, 03:45 PM   #12
1.8L_allmotormilitia
Send a message via AIM to 1.8L_allmotormilitia
get a 4 puck clutch and some motor mounts and launch ! ur dash will come right off ! b carefull might land in ur lap !
1.8L_allmotormilitia is offline Report Post   Reply With Quote
Old 07-17-2007, 05:41 PM   #13
instructor74
Default Re: How to remove An EG dash (methos713)
It should be attached to the access panel on the bottom of the steering wheel . open that panel disconnect the yellow plug remove the red plug from the panel and insert into the air bag plug
current cars
Old 07-17-2007, 06:18 PM   #14
methos713
methos713's Avatar
didn't know there was a red plug there...hummm, I'll go check. Thanks.
Old 07-17-2007, 07:50 PM   #15
TTacous
TTacous's Avatar
Thanks for the write up. Now I don't have to break things taking out my dash
TTacous is offline Report Post   Reply With Quote
Old 07-17-2007, 09:23 PM   #16
akunamatta
* B A N N E D *
FYI: you do not have to remove the guage cluster and bezel in order to remove dash.
akunamatta is offline Report Post   Reply With Quote
Old 11-21-2007, 03:52 PM   #17
ydoubleonie
ydoubleonie's Avatar
Send a message via AIM to ydoubleonie
coooll... but the pics are down. can you put em back up?
_______________________________________
wealth is of the <3 and mind, not of the pocket.
ydoubleonie is offline Report Post   Reply With Quote
Old 11-21-2007, 03:58 PM   #18
Syndacate
Syndacate's Avatar
Send a message via AIM to Syndacate
I added it to the FAQ, get your pictures working.
If you need somebody to get 'em hosted for ya PM me.
Need suggestions on good xbox 360 games - I don't play multi-player (online) and first person shooters I reserve for the computer - Any suggestions are welcome
'97 EX - Stock as stock can get - Daily driver, KYB struts, Tokico reds, I/H/E
Syndacate is offline Report Post   Reply With Quote
Old 12-16-2007, 01:03 PM   #19
srg
srg's Avatar
Send a message via ICQ to srg
pics don't work can someone correct links?
srg is offline Report Post   Reply With Quote
Old 01-20-2008, 09:32 PM   #20
StoryBookSin
StoryBookSin's Avatar
Send a message via AIM to StoryBookSin
nice write up THx
1992 Subaru Legacy WRX - White
1992 Civic Hatch EG b16a - Pearl White
"Book of Story Sin"
StoryBookSin is offline Report Post   Reply With Quote
Old 01-20-2008, 09:36 PM   #21
pemd5555
pemd5555's Avatar
Default Re: (StoryBookSin)
nice write up bump thanks
Honda PACT Student
pemd5555 is offline Report Post   Reply With Quote
Old 02-16-2008, 07:42 PM   #22
ajaxK1
ajaxK1's Avatar
Default Re: (pemd5555)
someone correct the pic links please.....
ajaxK1 is offline Report Post   Reply With Quote
Old 02-16-2008, 07:46 PM   #23
BlueIntegraBoy
1998 Acura Integra
BlueIntegraBoy's Avatar
Default Re: (ajaxK1)
インテグラ タイプR 98-0425
BlueIntegraBoy is offline Report Post   Reply With Quote
Old 06-24-2008, 02:00 PM   #24
denraweb
denraweb's Avatar
Default Re: (BlueIntegraBoy)
Can someone fix the pics? This would be a great write up if there were working pics...
denraweb is offline Report Post   Reply With Quote
Old 09-29-2008, 05:53 PM   #25
iluvmyEJ1
iluvmyEJ1's Avatar
hey can you redo your pic?? it would help out alot! thanks.
iluvmyEJ1 is offline Report Post   Reply With Quote
Bookmarks
1992, 1994, 2000, 93, air, civic, dash, dashboard, honda, instructions, removal, remove, removing, si, vent
