Go Back   Honda-Tech > Honda and Acura Technical Forums > Forced Induction
Old 07-17-2007, 09:29 AM   #1
oscarmayer
oscarmayer's Avatar
Default Help with S300 boost controller components install. (Got a pic)
we reciently installed the boost control components into my S300. we faced the diods and parts the same direction as the factory like parts so everything was uniform. the controller section is not working and the pic provided by Hondata sucks. it doesn't give you enough details to see the correct direction the parts should be installed in.
Does someone have a detailed photo showing close ups of the parts installed so we can determin if we have something installed incorrectly before we start speinding a couple of hundred for Hondata to diagnosis and repair the ecu? (if it needs it)
Thanks a bunch for any help.
mike
"God created turbo lag to give V8s a chance."
oscarmayer is offline   Reply With Quote
Old 07-17-2007, 02:49 PM   #2
methos713
methos713's Avatar
Default Re: Help with S300 boost controller components install. (oscarmayer)
don't know if this is what you want, but it has pics and nice details...
http://www.honda-tech.com/zerothread?id=1348457
methos713 is offline   Reply With Quote
Old 07-17-2007, 02:55 PM   #3
RedR
RedR's Avatar
I agree the pics provided suck and i did install the components facing the same way as the stock components on the ecu.
So far its working
b00sted
RedR is offline   Reply With Quote
Old 07-17-2007, 05:29 PM   #4
tony1
tony1's Avatar
How about a pic of yours and i can tell you if it's right or not.
tony1 is offline   Reply With Quote
Old 07-17-2007, 09:02 PM   #5
mtber
H-T Basic Sponsor
mtber's Avatar
iTrader Rating: (1)
All transistors have writing on them. Face the writing towards the side of the ecu with a sticker on it stating the part number.
Concerning the diode, the stripe side faces the ecu plugs.
The resistors are not directional.
That is really all you need to know.
Phearable.net - 1-888-236-9831 - Honda-Tech Sponsors Since 2003
Chipped Ecus / Fuel Injectors/Pumps / Widebands / OBD Harnesses / Turbos
Authorized Dealer for: Hondata, AEM, Neptune, eCtune, Crome, Precision & more.
Shop with CONFIDENCE, we are a company that has been in business for 10 years!
mtber is offline   Reply With Quote
Old 07-18-2007, 10:45 AM   #6
viskii420
viskii420's Avatar
Send a message via AIM to viskii420
Does s300 comes with boost option already installed u just need the solenoid? or i'm way off on this?
ClimateGate : CLIMATE SCANDAL OF THE CENTURY!!!
|Ebay|Build|Ramku|Vouches|
viskii420 is offline   Reply With Quote
Old 07-18-2007, 11:25 AM   #7
Turbo-LS
Turbo-LS's Avatar
iTrader Rating: (4)
Send a message via AIM to Turbo-LS
Default Re: Help with S300 boost controller components install. (mtber)
Yeah i did that on my s300 and my boost option doesnt work. I even removed everything and reinstalled thinking possibly a dry socket. I also had used stock wiring and connector plugs because i have a GSR with an LS motor in it to keep it neat and thought maybe that was the issue so i hard wired the sol. to the ecu and still nothing. even switch the polarity on the sol wiring even though that shouldnt matter and still its dead. i called hondata and they basically in a nice way said **** off. so it was back to MBC for me Click the image to open in full size. 80 bucks what a waste
www.senditracing.com
ECU Socketing, BBG, Vtec
95 DC2 GSR PTE 6266 827hp PB - 9.74 @ 156.66 mph
Turbo-LS is offline   Reply With Quote
Old 07-18-2007, 12:12 PM   #8
tony1
tony1's Avatar
Default Re: Help with S300 boost controller components install. (Turbo-LS)
Every one i've ever done has worked fine. Odds are you messed up on the install somewhere.
Old 07-18-2007, 12:15 PM   #9
Turbo-LS
Turbo-LS's Avatar
iTrader Rating: (4)
Default Re: Help with S300 boost controller components install. (tony1)
yeah i was thinking that also but ive never had a problem with chipping/socketing ecu's and ive dont PLENTY of them. its no different from socketing an ecu . desoldering the joints, installing the compnents and soldering them in place.
Old 07-18-2007, 12:17 PM   #10
tony1
tony1's Avatar
But that's not to say that you can't make a mistake. Possibly the wiring on the solenoid, possibly a bad solenoid, etc.
Old 07-18-2007, 12:22 PM   #11
Turbo-LS
Turbo-LS's Avatar
iTrader Rating: (4)
Exactly but that is why i ruled that out by removing and reinstalling. im bankin on a defective sol. i wired sol. every combination possible. ive been wiring cars for 14 years so ive kinda got the hang of trouble shooting
Old 07-18-2007, 12:47 PM   #12
tony1
tony1's Avatar
There's only 2 wires and their polarity does not matter.
Could also be a bad tracer on the ecu board or something, who knows. It's about 99% not Hondata's fault though any way you look at it, right?
Old 07-19-2007, 01:22 PM   #13
oscarmayer
oscarmayer's Avatar
sent tony1 a pm.
Old 07-19-2007, 07:06 PM   #14
oscarmayer
oscarmayer's Avatar
well anyone have any good pics of the boost controller parts installed on a pcb?
Old 07-20-2007, 07:16 PM   #15
oscarmayer
oscarmayer's Avatar
Old 09-20-2007, 07:47 PM   #16
IN VTEC
2012 Lexus CT
My Garage
IN VTEC's Avatar
iTrader Rating: (2)
Ben Chang Dr Eugh
Send a message via AIM to IN VTEC
Default Re: (oscarmayer)
I need a little bit of help to make sure the components were installed correctly and that I have the software set up correctly....so here's how I installed and set up the one for the race car's ECU.
We used an AEM boost solenoid. The boost solenoid is a Mac valve product. It's a 3-way, normally closed valve. It's normally closed because the intended flow direction is from port 1 to port 2 and when the solenoid is de-energized, ports 1 and 2 are not connected and port 2 gets vented to atmosphere. To me, that's normally closed.
See .pdf file of valve type:
http://www.mdnworldwide.com/ne...5.pdf
Pneumatics Routing:
Port 1 -> Boost reference (from intake manifold, charge piping, turbo, etc.)
Port 2 -> Output to wastegate top port (above the diaphragm, opposite to the valve face)
Port 3 -> Open to atmosphere with the provided filter installed.
Electrical wiring:
Polarity at the solenoid doesn't matter.
Wire 1 - pinned to A11 (switched GND)
Wire 2 - switched 12VDC+ with 10A inline fuse
Other background info as needed:
http://www.hondata.net/forum/viewtopic.php?t=5429
It's on a P06 ECU converted to a VTEC ECU that's supposed to have the IAB circuitry, but it doesn't work. Not my fault.
R70, R71, D14, Q29 installed.
Q20 installed.
Settings in SManager: I've tried up to 50% and it still won't hit anything higher than 12psi (waste gate spring is 11psi).
Troubleshooting steps I have to do tomorrow:
1.) Wire the solenoid directly to the battery to see if it'll click.
2.) See if polarity matters on the AEM solenoid by wiring it to the battery both ways.
3.) Force the ECU to turn on the circuit by feeding the MAP sensor enough pressure to surpass the activation threshold and measure the voltage across the solenoid wires.
IN VTEC is offline   Reply With Quote
Old 09-21-2007, 12:35 AM   #17
.RTErnie
.RTErnie's Avatar
Send a message via AIM to .RTErnie
Default Re: (IN VTEC)
let me save you the trouble...the aem boost control solenoid can be wired either way. Polarity is not important. says it on the piece of paper that comes with it...and tony just said it too. Click the image to open in full size.
Eric Urness
R/TErnie Race Engineering
541 980 6022
.RTErnie is offline   Reply With Quote
Old 09-21-2007, 06:41 AM   #18
IN VTEC
2012 Lexus CT
My Garage
IN VTEC's Avatar
iTrader Rating: (2)
Ben Chang Dr Eugh
Default Re: (.RTErnie)
Yeah, it's probably not. I guess I just wanted to make sure.
I'm more worried about the ECU components not being installed correctly.
Old 09-25-2007, 09:35 AM   #19
Spunkster
Spunkster's Avatar
Send a message via AIM to Spunkster
You have to post pictures of the soldering on the bottom of the ecu
STOLEN on 10/6/03 98 ITR #265 w/ JRSC at 11 psi
265.4 hp 184.9 tq
Spunkster is offline   Reply With Quote
Old 09-25-2007, 01:37 PM   #20
gunslinger
gunslinger's Avatar
Location: Where thieves get shot in the face,, texas, usa
Default Re: (Spunkster)
The center pin on Q20 dosent look soldered properly pics of the back of the board please!
www.lonestareliteauto.com
gunslinger is offline   Reply With Quote
Old 09-25-2007, 03:13 PM   #21
IN VTEC
2012 Lexus CT
My Garage
IN VTEC's Avatar
iTrader Rating: (2)
Ben Chang Dr Eugh
Default Re: (gunslinger)
I'll pick up the ECU on Thursday and take the pictures.
Old 09-25-2007, 06:47 PM   #22
Jaker
Q29 and Q21 (right behind Q29) both look like they got a little hot. Q21 also appears to have melted plastic. I'd guess these components are blown.
http://www.PDM-Racing.com
Jaker is offline   Reply With Quote
Old 09-26-2007, 11:51 AM   #23
Spunkster
Spunkster's Avatar
What is the part number of the mac valve you are using...the datasheet indicates that there are many different versions
265.4 hp 184.9 tq
Old 09-28-2007, 04:48 PM   #24
IN VTEC
2012 Lexus CT
My Garage
IN VTEC's Avatar
iTrader Rating: (2)
Ben Chang Dr Eugh
35A AAA DDBA 1BA is the MAC valve part number for the AEM boost solenoid.
Old 09-28-2007, 09:28 PM   #25
Spunkster
Spunkster's Avatar
I'm not asking about the aem version. I'm asking what he's using
265.4 hp 184.9 tq
1ba, 35a, 35aaaaddba1ba, aaa, aem, boost, control, ddba, honda, hondata, install, mac, open, s300, solder, solenoid
