Old 07-13-2007, 07:15 PM   #1
Leb_CRX
Leb_CRX's Avatar
Send a message via ICQ to Leb_CRX Send a message via AIM to Leb_CRX
Default stripped oil drain plug
just picked up a 96 civic and the oil drain plug is stripped...constantly leaking oil
just wondering if there's any fixes to buying a new pan...I know you can't re-thread it cause the metal on the pan's too thin...wondering if there's a quick oil release thing I can put on...maybe use jbweld or something for the holder, and just use the plug
if anyone has any ideas, let me know Click the image to open in full size.
Leb_CRX is offline   Reply With Quote
Old 07-13-2007, 07:24 PM   #2
ekb16
ekb16's Avatar
iTrader Rating: (1)
Send a message via AIM to ekb16
y not just buy a new oil pan
B.A.R. member as of 3/18/09 JDM gsr in 98 hatch
Voches: chickwithastick,93allmotorcoupe,jomama,punoy69,Tom theman70
ekb16 is offline   Reply With Quote
Old 07-13-2007, 07:36 PM   #3
j.star
j.star's Avatar
New oil pan FTW. Less problems down the road
*1996 DC4 Integra LS - Project car, just need a plan
*1991 Celica GTS widebody, painted red w/ orange pearl
1999 Solara SE V6 - sold & 1992 Civic LX - sold
j.star is offline   Reply With Quote
Old 07-13-2007, 07:38 PM   #4
nighttrain33
nighttrain33's Avatar
Default Re: stripped oil drain plug (Leb_CRX)
Mine's doing the same thing. If I were going to keep the car, I probably would just buy a new pan since it is so easy to replace. But, since I am just going to sell it, I will probably just use gasket maker or something simple since I already have one of the quick-drain adaptors for it. Works just as well and I don't have to spend another $100 or whatever a new pan is.
-Shane
'07 custom midnight black Yamaha R1 (painted by my dad)
1997 Civic w/ B16, skunk2 im, exhaust, intake, Teg rears discs
2006 TBSS
nighttrain33 is offline   Reply With Quote
Old 07-13-2007, 07:43 PM   #5
97Ej6mike
97Ej6mike's Avatar
Send a message via AIM to 97Ej6mike
For now jb weld it in place if you must, but get on buying a new pan right away.
I miss My EK sedan but helllooo Subaru
I love my 400awhp Subaru STi
97Ej6mike is offline   Reply With Quote
Old 07-13-2007, 07:51 PM   #6
Leb_CRX
Leb_CRX's Avatar
Default Re: (97Ej6mike)
I just dont want to spend the money on the oil pan, and it's a messy job...and the car's a beater
I've found this:
http://cgi.ebay.com/ebaymotors...wItem
what I might do is end up putting that on, and putting jbweld around it to be safe...so when I drain the oil, all I need to do is plug in the adapter, and bam
anyone got any heads up before I do this? bad idea?...should I just man up the coin and replace the pan? Click the image to open in full size.
Old 07-13-2007, 07:52 PM   #7
tech8
tech8's Avatar
Default Re: (Leb_CRX)
Try an oversize drain plug. Kragen, Autozone, etc., and even some dealers sell them for a couple of bucks.
tech8 is offline   Reply With Quote
Old 07-13-2007, 08:46 PM   #8
97Ej6mike
97Ej6mike's Avatar
Default Re: (tech8)
But that would only be good for a limited number of uses, eventually it would just strip it out even more. Just spend the money on a new pan.
Old 07-13-2007, 08:50 PM   #9
Syndacate
Syndacate's Avatar
Send a message via AIM to Syndacate
Heat it up and use a slightly larger tap and re-thread the hole, then use a bolt of that size?
'97 Honda Civic EX - Occasional DD - KYB struts, Tokico reds, I/H/E
'05 Dodge SRT4 ACR - Occasional DD / GS AutoX car
'82 Honda CM450E - Prossible project bike; '85 Honda CB450SCL - Stock DD
Syndacate is offline   Reply With Quote
Old 07-13-2007, 08:59 PM   #10
tech8
tech8's Avatar
Not necessarily. Oversized drain plugs are self-tapping, and made just for this type of situation. There are many cars on the road, not just Hondas, that use this as a solution without further problems.
Old 07-14-2007, 02:19 AM   #11
redcoats1976
redcoats1976's Avatar
Default Re: (tech8)
mine has this problem also,too many quickee mart oil changes by previous owner.try a new oil plug first,the new threads on the plug may be just enough to fix it.i buy a new oil plug for a couple of bucks every other oil change.little bit of red thread locker on the plug threads helps too.
redcoats1976 is offline   Reply With Quote
Old 07-14-2007, 03:55 AM   #12
john666
1994 Honda Civic
john666's Avatar
Default Re: (redcoats1976)
had this problem once with a car.. what i did was buy one of theses at a autozone near my house..
what it is basicly is a nut slightly larger then the one u have.. i screwed it in with a something like a silicon to seal it in.. and to change oil there is a smaller screw in the nut u open the let the oil out.. of course it would take longer for oil changes but a quick fix if your too lazy to change the pan..
this site
http://www.burdickenterprisesi...o.htm
sells a oil changing valve for the truly lazy person in all of us.
john666 is offline   Reply With Quote
Old 07-14-2007, 05:13 AM   #13
cimo463
cimo463's Avatar
Send a message via AIM to cimo463
At the dealer we have an insert that we thread into the striped hole..and the kit comes with a slightly smaller drain plug...
97 Cyclone blue EJ6
Team EJ6 #66
88 CRX DX
cimo463 is offline   Reply With Quote
Old 07-14-2007, 08:48 PM   #14
Leb_CRX
Leb_CRX's Avatar
Default Re: (john666)
what kind of silicon did you use?
i placed bid on the ebay item..quite simular to what you have
I can go with an oversized, but to be honest I am not sure what to buy...I went to a local shop and they looked at me like I was crazy and said I need to replace the pan...which is exactly what I'm trying to avoid
thanks for the help guys Click the image to open in full size.
Old 07-14-2007, 08:54 PM   #15
Syndacate
Syndacate's Avatar
Somebody recently told me about it - use it when u snap heads off - it's a stripped bolt remover. basically you just drill a small pilot hole with a tiny bit (doesn't have to go all the way through) - then u spin this thing into it (and it's reverse thread) so as you screw it in and it tightens into the bolt it loosens in - so you just keep tightening it in and it eventually catches and starts to unspin the bolt. That's probably your best bet, though I'd drop the pan to drill it easier.
When I made my last post I didn't even think of the fact that the bolt was still in there Click the image to open in full size..
Old 07-14-2007, 09:00 PM   #16
nighttrain33
Default Re: (Syndacate)
But the head didn't break off. Somehow the bolt got cross-threaded and now won't tighten enough to keep oil from leaking. He can screw the drain plug in, but it will just keep spinning and never fully tighten.
-Shane
2006 TBSS
Old 07-14-2007, 09:00 PM   #17
Syndacate
Syndacate's Avatar
Something like this:
I can't find a picture of the reverse pick deal right now, but that works too.
What about a pair of vice grips? I'm REALLY surprised that didn't do the trick as the bolt's really big and it's not like the head broke off.
Old 07-14-2007, 09:04 PM   #18
nighttrain33
The head's not stripped, the bolt itself is. Hence the constantly leaking oil Click the image to open in full size.
-Shane
2006 TBSS
Old 07-14-2007, 09:05 PM   #19
Syndacate
Syndacate's Avatar
Default Re: (nighttrain33)
-Shane
Does it unscrew?
If so, pull and tap is ur only bet Click the image to open in full size..
If not - drill is basically ur only bet, I'd drop the pan to make it easier, either way. Empty the oil out, heat up the pan, and tap it, should work.
EDIT:
Note the "REMOVE" your oil pan...don't heat it while it's on there w/ oil in it Click the image to open in full size..
Old 07-14-2007, 09:11 PM   #20
nighttrain33
Does it unscrew?
EDIT:
It's not my car, nor my thread, but from what I have gathered, the OP is having the same problem I am. The drain plug got cross-threaded. So I can take it out, put it back in (you guys are dirty), but when I screw it back on, it will never go on tight enough and will constantly leak oil. Again, that's my problem, and only the OP can say that this is what he is going through, but that's what it sounded like to me.
-Shane
2006 TBSS
Old 07-14-2007, 09:39 PM   #21
akunamatta
* B A N N E D *
oversized plug is a good solution for a temporary fix...
akunamatta is offline   Reply With Quote
Old 07-14-2007, 10:54 PM   #22
oneludesol
oneludesol's Avatar
Send a message via AIM to oneludesol
Default Re: (akunamatta)
weld that bitch shut and get the pump that sucks the oil out through the dipstick tube for $30. Better way to to it in the first place anyway!
Maserati Coupe GT //EVOMS tuned full Kreissieg Exhaust 459hp-401tq//
Porsche 955 Turbo S //EVOMS ECT600 602hp-617tq//
25%: 2009 GOBOSH 800XP
oneludesol is online now   Reply With Quote
Old 07-14-2007, 10:56 PM   #23
nighttrain33
Default Re: (oneludesol)
Well I was kinda thinking along the same lines. Weld it and just keep my quick-drain fitting for it.
-Shane
2006 TBSS
Old 07-15-2007, 02:49 PM   #24
Leb_CRX
Leb_CRX's Avatar
what are they called? the things that suck oil through the dipstick
I've heard of them, and I know VW's use them...but for the life of me can't find a link online to buy it...and no one locally has a clue
Old 07-15-2007, 05:19 PM   #25
oneludesol
oneludesol's Avatar
http://www.skymall.com/shopping/search.htm
Lol I saw it in a skymall catalog on a flight about a year ago, I bought one somewhere else for cheaper, but here it is!! (just search oil extractor)
1997, 2003, 2007, 85, accord, big, civic, drain, fix, honda, leak, oil, oversize, pan, plug, red, stripped
