| Welcome to Honda-Tech! | ||
#1 |
Just bought some rims...all of them are clean except for one. It has some primer over spray on it. How can I remove the primer and not damage the rim. They Rota Jmags. Here are some pics:
Team Outkast est. 1994 |
#2 | |
y u rusty doe?
1970 Honda CB450My Garage |
#3 |
I would think mineral spirits would be your best bet. I dont THINK it would damage the wheel at all. Somebody correct me if I am wrong.
From Si to STi |
#4 |
i used a claybar and it got lithgt overspray off my fenders... you could try that.
#5 |
y u rusty doe?
rubbing compound or claybar + elbow grease LOL
#6 | ||
Guess I'll try the claybar...I think I have some rubbing compound if that doesn't work. Any other suggestions?
#7 |
acetone or paint thinner will do the trick. shouldnt do anything to the rims at all i wouldnt think. and it should come right off without exerting much effort at all lol
00 BMW 323i, black int, sport pkg, 5 speed 95 ej1, FnF1's, Morimoto Mini h1 retrofit, GSR, bbk intake, BDL tb, t3/t4 10psi |
#8 |
Yeah those rims are polished aluminum (It looks like anyway), you should be able to use paint thinner no problem... If not, try a razor blade, flat against the rim, should be able to scrape it off but youd have to be careful about dragging it perfectly even along the metal so you dont leave any scrapes.
#9 | ||
[i]94 Civic Ferio[i] ...::fourdoor<FONT COLOR="blue">mafia</FONT>::... Joe R @ On Demand in Westerly Quote:
#10 | |
laquer thinner, trust me i work at a shop, only thing that will take it off in 3 seconds!
PM ME FOR BODY WORK IN THE TRI-STATE AREA. Quote:
#11 |
* B A N N E D *
claybar x2...everyone says laquor thinner or w.e but if they were my wheels i wouldnt take any chances and claybar is almost effortless
#12 |
| Garage is empty, add now |
thinner or clean-ez will work fine
#13 |
spray some of that aircraft paint thinner and it should start to peel off on its own in 20 mins. get it at autozone or walmart.
#14 |
You guys are spending too much for any easy fix, just get a bottle of 90% alcohol and it will take it off.
Hybrid vehicles (Prius, etc.) have to be Smog Check for 2013! YES!...JDM motors can be Bar'd again, also B20 as LS replacement motors. http://i156.photobucket.com/albums/t...BARIntegra.jpg |
| Tags |
| aceton, acetone, cleaning, jmags, metal, overspray, paint, polished, primer, remove, rim, rims, rota, spray, strip |
