How much horsepower for a b18b on 10psi??
#26
Re: How much horsepower for a b18b on 10psi?? (_Shadow_)
Looks too rich at high rpms to me. Also, your timing may be off. the .45 bar wastegate should not hit 10psi all by itself!
#30
Re: How much horsepower for a b18b on 10psi?? (Anthony's Well Hung EK)
anyone have a video of an EG with LS-TURBO?
#31
Heres my dyno. Untuned, leaning out like a **** and on 7psi. 2.25 exhaust too.
http://mywebpages.comcast.net/turboc.../dansdyno1.avi
#32
maaaaaaaaan stfu.. you don't even know how many horsepower come out of a typical LS turbo.. it was a question because that is my next project and i figured i would throw it in because this dude has a video of one that is fast as ****.. please think before you speak
#34
pretty nice, ya you should get a 3 inch thermal and tune the carb properly, it'd run pretty nice
Also I know what a turbo ls motor puts out...its the whole reason for this post so I can figure out why my turbo LS isnt producing what it should be. Please stop wasting your time posting...it's not helping.
#35
fuckk.. i got my ls hatch dynoed on a mustang dyno @ 8psi and only pulled a measly 185hp and 170 ft/lbs.. but does it really matter what ur car can pull on the dyno?? maybe a couple 1/4 mile times would be a better measurement of power and performance.. btw, my best time at the track was 13.8@101 w/ 2.1 60ft on nitto450's.. so how much hp would i pull on a dynojet?
my setup..
t3/t4b .48 A/R
intercooled, hondata2b, tail, 3" exhaust, and some other stuff
my setup..
t3/t4b .48 A/R
#36
Do you have a boost gauge? How do you know you are running 10psi? And how is that possible with the .45 bar tial?
#37
Re: How much horsepower for a b18b on 10psi?? (95GS-R)
BTW, you are too rich from 3k on up, especially in the high RPMs. You need to be about 13:1. That 11:1 is waaaaaaaaaay to rich. You're losing a lot of power there.
#38
Re: How much horsepower for a b18b on 10psi?? (Jared)
My tuner hooked up something that reads boost. Its logged on the dyno graph. I'm going to open up the Tial and find out which spring is in their. Maybe Max-Rev changed springs on me, or mispackaged it. I'm going to finish tuning it in a few weeks and hopefully straighten out everything. I have a blitz turbo timer with a built in boost guage with peak/hold/ and warning features. It reads lower boost than what is on the dyno graph.
#39
Location: WTF DC Racer No Way Turbo Washington., DC, USA
I have my dyno graph i will scan it soon, i have my car video on the dyno on my laptop but dont know how to upload. Also have a clip of my gauge cluster boostin 16psi sounds wicked.
#40
I bet you the tuner read the boost wrong. Or hooked it in incorrectlly. With the .45 bar spring in my tial I only see 4 solid pounds of boost. Maybe those numbers you are putting down are more consistent with 4-6.5 lbs of boost. BTW, the reason I see only 4 pounds is because of the way my piping is, wanting to keep AC in a 90 teg makes for some crazy piping.
#41
Re: How much horsepower for a b18b on 10psi?? (blackteg)
There's no way for an electronic pressure gauge to "read boost wrong" - it hooks up to a manifold vacuum tap and records the pressure. His boost is fine, his AF is fine - do NOT lean out to 13:1!!! Yeah his fuel could be a little smoother but it's staying right between 12 and 12.5 which is actually a little on the lean side for safe tuning - he should still make great power from 11.5 to 12. I say his ignition curve is way screwed up.
#42
Do you think you can tune my carb for me?
#43
Re: How much horsepower for a b18b on 10psi?? (93LSivic)
Shadow... Dude, sorry I didn't get to say bye last Sat night!! Anyhow, I was going to go up on Easter Weekend to Engineered and get my stuff tuned, but someone else confirmed before I did... hope that wasn't you!!! hehe. When do you plan on going up next. I'd love to tag along if I can. Also, check your timing up in boost... Sometimes places dial back the timing to be safe... Did Engineered have a wideband on your car when they dynoed it? If timing seems ok, or you don't want to f*** with it, then just take some fuel out... just a little and see if it runs better. An A/F ratio guage would be a good thing to have so you can see the readout at WOT...
Laters... maybe you can come back down next weekend.
#44
Re: How much horsepower for a b18b on 10psi?? (JRSCCivic98)
PARASTIC LOSS - HONDA AUTOMATICS SUCK!!!
The turbo LS that I have only hit 158 on the dyno and ran a 15.8 remember - now if you were hitting 10psi I can understand 200 but I was only running 6.5psi!!! It has to be the damn automatics man!!! promise
#45
damn...seems like bro here is having lots of problems!! timing could be a problem...and what stage hondata do you have? you'll need to tune that as well...also, have you checked your motor or any other places for leaks? better have that checked out as well!! first time i dynod my car w 8 pounds of boost it was 165 whp and 130.5 lbs...found out that that my rings were leaking, had them replaced and dynod again and got 241whp and 210 lbs.
#46
Re: How much horsepower for a b18b on 10psi?? (shermanyang)
OK everyone. Their is a .65 bar spring in the wastegate not a .45 That makes the boost about right. I really hope it's not my rings. That would really suck But it would only give me an excuse to build bigger
JM Performance
06-20-2003 02:22 AM
MotorMatrix.com
01-13-2003 07:11 AM
