How much horsepower for a b18b on 10psi??
Old 06-08-2002, 12:24 PM
_Shadow_'s Avatar
Default How much horsepower for a b18b on 10psi??
Hey guys, here is my setup.
Max-rev kit (2 1/2" DP)
98 GS teg
T3T4 63/54
3"exhaust
Hondata
10psi
How much power should I be putting down? Anyone else have a similiar or the same setup?
Old 06-08-2002, 03:55 PM
Ri5e's Avatar
Default Re: How much horsepower for a b18b on 10psi?? (_Shadow_)
On average, around 250-280 WHP.
Old 06-09-2002, 10:00 AM
_Shadow_'s Avatar
Default Re: How much horsepower for a b18b on 10psi?? (BG Boost)
ok well, that's what I was expecting. I only put down 205hp/189 ft lb torque. What could be the problem???
Old 06-09-2002, 11:46 AM
The_Head's Avatar
What exhaust are you running? Maybe its too restrictive
<< 3" downpipe, 3" custom exhaust, dyno max muffler
Old 06-09-2002, 11:50 AM
PrecisionH23a's Avatar
have you had it tuned right?
Old 06-09-2002, 12:32 PM
_Shadow_'s Avatar
Default Re: How much horsepower for a b18b on 10psi?? (GudeH23a)
Alright my exhaust is 3" mandrel bent piping 3" carsound and a 3" magnaflow. Its not restrictive trust me.
I had it tuned but with some difficulty. The hondata stuff was acting up. We couldnt get the datalogging to work so we did the best we could getting the fuel right. I'll post up a dyno graph in a sec so you guys can see whats up.
Old 06-09-2002, 12:50 PM
_Shadow_'s Avatar
Here is the dyno graph. Will tuning it better bring out 50-80 more horses?? Let me know what you think is the problem. Thanks
Old 06-09-2002, 03:29 PM
93LSivic's Avatar
I see an X...
Old 06-09-2002, 05:23 PM
95GS-R's Avatar
Default Re: How much horsepower for a b18b on 10psi?? (93LSivic)
Here you go ...
Old 06-09-2002, 07:15 PM
Mike D's Avatar
Default Re: How much horsepower for a b18b on 10psi?? (95GS-R)
ok im not too sure, but 12.1 maybe a little rich on the fuel. maybe with your set-up 12.1 a/f ratio is safer, but just something to think about.
what is your timing set at??
Old 06-09-2002, 07:20 PM
xrtdac
Guest
Posts: n/a
Yeah dude the HP is quite low. I run an LS turbo, Drag 3 kit. I put donw on 9psi 231WHP and 204ft-lbs. somethin is not right for you.
Old 06-10-2002, 06:32 AM
_Shadow_'s Avatar
Default Re: How much horsepower for a b18b on 10psi?? (xrtdac)
Anyone else have opinions? What should I check? What would be a better a/f ratio to run?
Old 06-10-2002, 07:38 AM
b18tdelsol's Avatar
hmm..i have a revhard 2c, boosting at 7lbs and i'm making 210whp, on a 2inch exhaust.. for 10si, u should out do me by about 30-50 horsepower.. what other mods do u have?
Old 06-10-2002, 07:45 AM
_Shadow_'s Avatar
Default Re: How much horsepower for a b18b on 10psi?? (b18tdelsol)
OK people I know I should have more power. The only mods are whats listed. Those are the only ones that matter. Could something be wrong with my motor? It has 47K on it. It runs smooth and clean. No smoking or anything. Any ideas?
Old 06-10-2002, 08:39 AM
Speed PHreak's Avatar
timing?
Old 06-10-2002, 08:43 AM
CovertFI's Avatar
no cams, no gears? how do your spark plugs look? did you leave the ac on when you dynoed? lol lots of people go to the track over here and say they left their ac on, but then again they could be ashamed of their of time.
Old 06-10-2002, 08:50 AM
Finest's Avatar
Default Re: How much horsepower for a b18b on 10psi?? (CovertFI)
Uh, doesn't the A/C cut off at high rpms/speeds?
Old 06-10-2002, 08:56 AM
"I left my A/C on, y0!"
Ha ha ha....haven't heard that one before.
Old 06-10-2002, 09:42 AM
Mike D's Avatar
Default Re: How much horsepower for a b18b on 10psi?? (Speed PHreak)
for the a/f ratio; try something around 13.1. any leaner might cause some problems.
also, what do you have for tuning aside from hondata??
good luck
Mike D
Old 06-10-2002, 10:26 AM
_Shadow_'s Avatar
Default Re: How much horsepower for a b18b on 10psi?? (Mike D)
Timing is whatever my tuner set it at. (not sure) My spark plugs look good.
NO my a/c was'nt on
I don't have different cams or cam gears.
I'm not sure what you are talking about when you ask "what do you have for tuning aside from hondata??" What else do I need???
You guys think if I lean out my a/f and advance the timing a bit I will pick up alot more horsepower?
Can someone post up a dyno sheet of a turbo b18b with similiar setup so I can compare. I'd like to see the difference in power curves.
Old 06-10-2002, 12:02 PM
Civicdrgrcr's Avatar
Location: WTF DC Racer No Way Turbo Washington., DC, USA
<--Stock B18b Turbo Read sig. for numbers but mine is tuned like a champ.
I dynoed mine at a mustang place, pure mustangs and they were like WTF!!
Old 06-10-2002, 12:03 PM
Default Re: How much horsepower for a b18b on 10psi?? (Civicdrgrcr)
**** its not in my sig. but
238hp and 217tq at 8psi
272hp and 238tq at 10psi
Old 06-10-2002, 12:06 PM
Mr. Softee's Avatar
graph?
Old 06-10-2002, 12:26 PM
_Shadow_'s Avatar
aww man...I am so jeleous. What performance mods do you have?
Old 06-10-2002, 12:31 PM
_Shadow_'s Avatar
Default Re: How much horsepower for a b18b on 10psi?? (94goldjungsr)
Another thing people, I'm using the wastegate (tial) with I think a .45 bar spring in it to regulate boost. Its the silver Tial I received from Max-Rev. Could there be a problem with the wastegate? Why the hell is it pushing 10psi??? Or is that normal?
Quick Reply: How much horsepower for a b18b on 10psi??
