Old 07-05-2007, 10:32 AM   #1
standbackimapro
standbackimapro's Avatar
Send a message via AIM to standbackimapro
Default Best additive for oil burning?
i got a d15b8, smokes from burning oil, im just looking for a good additive that will stop the burning and the smoke
ASE:A1, A2,A3,A4,A5,A6,A8,A9,X1,L1,Hunter Certified Front End Specialist,Moog Certified Front End Specialist, MECP Basic Installer, ASE L1 Advanced level specialist
standbackimapro is offline   Reply With Quote
Old 07-05-2007, 10:39 AM   #2
HCivicSi23
HCivicSi23's Avatar
Default Re: Best additive for oil burning? (standbackimapro)
Is there really an additive that can do this? Your burning oil because of a piston ring and im not sure that theres an additive that fix a bad piston ring.
359garage http://images.honda-tech.com/set1/smile/emthup.gif
Originally Posted by spray_bombed
You do realize if you get the body kit....you'll need a stand alone fuel management system...which usually costs around 10,000 bucks http://images.honda-tech.com/set1/smile/emhammer.gif
HCivicSi23 is offline   Reply With Quote
Old 07-05-2007, 10:39 AM   #3
Padawan
Darth ModerVader
Padawan's Avatar
Try RESTORE. Just keep in mind that no additive is going to "fix" the problem, it will only help alleviate some of the symptoms.
-NEMO ME IMPUNE LACESSIT-
Padawan is offline   Reply With Quote
Old 07-05-2007, 11:12 AM   #4
standbackimapro
Default Re: Best additive for oil burning? (HCivicSi23)
Yea i know that the car is not burning oil for no reason, i know theres a problem, i just dont really want to repair this motor, just somthing to keep it going for a few months..
and BTW, Burning oil can also be caused by Worn Valve stem seals
Old 07-05-2007, 11:14 AM   #5
HCivicSi23
HCivicSi23's Avatar
Right, but most likely its a piston ring. I guess the restore idea could work... but I think youll still burn some amount of oil. Just fix the motor Click the image to open in full size.
Old 07-05-2007, 11:26 AM   #6
instructor74
instructor74's Avatar
Send a message via AIM to instructor74
lets see $8 for a can of restore in an engine that he doesn't want to rebuild to help with reducing oil burn. Sounds like a good idea. Or he could dump over a grand into rebuilding a motor. Id go with the $8 save your money and get the engine you want. I can tell you from experience that restore does a nice job of reducing oil burn. Just for fun used it in a 4 stroke lawn mower engine. It stopped all noticeable oil burn
http://www.honda-tech.com/showthread.php?t=2952290
93 Civic Si got her new with 12 miles over 235,000 still running strong
09 Civic Si got 50 miles on the clock hope she is as good as the 1st one
instructor74 is offline   Reply With Quote
Old 07-05-2007, 12:28 PM   #7
akunamatta
* B A N N E D *
Default Re: Best additive for oil burning? (Padawan)
is this what your talking about? what are the directions or how do u use it
akunamatta is offline   Reply With Quote
Old 07-05-2007, 12:42 PM   #8
Padawan
Darth ModerVader
Padawan's Avatar
Default Re: Best additive for oil burning? (akunamatta)
That's it.
Directions are on the can, but basically, you just add it to the crankcase.
Old 07-05-2007, 12:51 PM   #9
akunamatta
* B A N N E D *
should you substitute one can for a quart of oil when i change my oil next?
and should i leave this in for the full 3000 mile interval?...
Old 07-05-2007, 12:59 PM   #10
Padawan
Darth ModerVader
Padawan's Avatar
Default Re: (akunamatta)
As I said, the can will tell you everything you need to know. It's 11 oz (about 1/3 of a quart), so it will not replace an entire quart of oil, and you can generally add it without overfilling the crankcase. Basically, just substitute the can of RESTORE for 1/3 quart of your usual oil at the next oil change.
As for leaving it in, you treat it just like the rest of your oil.
Old 07-05-2007, 01:04 PM   #11
akunamatta
* B A N N E D *
k thanks padawan im just making sure because the directions never seem to be clear.... im going to give it a try and see if it helps.
Old 07-05-2007, 01:08 PM   #12
Padawan
Darth ModerVader
Padawan's Avatar
What are the symptoms you're trying to alleviate?
Old 07-05-2007, 01:13 PM   #13
akunamatta
* B A N N E D *
im burning oil when i rev past 4000 rpm's.... not much but i can see a light cloud behind me.
the reason why this started was because i ran some seafoam through my IM..... i will never reccomend using that on a higher mileage engine because im assuming it decomposed the carbon that has been acting like a seal on my 185k mile engine.
Old 07-05-2007, 03:40 PM   #14
Agent_EM1
1997 Honda Accord
Agent_EM1's Avatar
Restore ??? Never heard of that before. Sounds good from what's being said about it.
Retired from Honda-Tech
Agent_EM1 is offline   Reply With Quote
Old 07-05-2007, 03:56 PM   #15
thesmogman
1988 Honda CRX
My Garage
thesmogman's Avatar
You can also try Castrol for higher mileage engines.
Sorry to hear the bad thing about Seafoam. I used it in my D16 with 200K and no problems. But yeah you do take a chance. I have heard some good results from the restorer too.
If you spent the time to fix it.... Fix it better than it was!
thesmogman is offline   Reply With Quote
Old 07-05-2007, 04:09 PM   #16
blackKready
2001 Honda Civic
My Garage
blackKready's Avatar
Send a message via AIM to blackKready
Default Re: (thesmogman)
i dont trust any of that **** personally. if i were you , id switch like was said to high mileage oil , and up the grade to 10W30 instead of 5. stay away from that stupid *** seafoam ****. anything you put in your engine besides oil is most likely no good. if you changed your oil when you should , you shouldnt need such things.
Stock sleeve forged k24 w/k20 head- allinfab turbo setup PT6766 best of 9.83 at 151
http://i83.photobucket.com/albums/j2...acing300px.jpg
blackKready is offline   Reply With Quote
Old 07-05-2007, 04:39 PM   #17
jeffchaisi
jeffchaisi's Avatar
Send a message via AIM to jeffchaisi
restore dont work at all i use it before. try to use some thicker oil like 15-40w or 20-50w they will slow down the oil burning alot. good luck but eventually u will need a rebuild
96 NSX CTSC, CTBBK, CT header, CT intake, CT R&P. 6 speed. 368whp.
03 RHD S2k type V
95 hatch VX DD
jeffchaisi is offline   Reply With Quote
Old 07-05-2007, 06:22 PM   #18
instructor74
Default Re: (blackKready)
Please do some research on oil before you post things like this. 10w 30 is no different then 5w 30 in the summer.
Old 07-05-2007, 07:23 PM   #19
HCivicSi23
HCivicSi23's Avatar
Default Re: (instructor74)
Whats the point? Just take the block apart and replace the piston rings and valve seals. You will always burn some amount of oil, so just leave it if you don't want to rebuild it.
Old 07-05-2007, 07:33 PM   #20
B16CarSeat
B16CarSeat's Avatar
Send a message via AIM to B16CarSeat
Default Re: (HCivicSi23)
he said hes only keeping the motor for a short time so putting the money into a rebuild is pointless for his situation compared to a quickfix... unless he was reselling the motor after he did swapor whatnot
___________________________________
new post but still nub status so cant post for a few hours
HCIVICSI23 your right man i miss read what you said and we basically said 6 one way half dozen the other ... if he wanted to do anything jsut quickfix it... or just buck up and deal with it til he gets rid of it... sorry for the mixup
Modified by B16CarSeat at 9:15 PM 7/5/2007
(__/)
(o.O )
(> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination
B16CarSeat is offline   Reply With Quote
Old 07-05-2007, 07:36 PM   #21
HCivicSi23
HCivicSi23's Avatar
Default Re: (B16CarSeat)
And what I am saying, is if hes ditching the motor... theres no point in doing anything. No matter what you do, you will be burning some amount of oil, so why try to fix it? Just let it alone.
Old 07-06-2007, 10:25 AM   #22
Mhollaek9
Mhollaek9's Avatar
Can anyone vouch for this?
Rislone Ring Seal reduces oil burning and exhaust smoke by increasing the viscosity of motor oil. Quiets noisy engines by increasing oil thickness and providing a cushion between worn parts. Contains high shear polymers which provide a seal for worn pistons and rings to help regain lost compression. For use in all internal combustion engines. May be used with all petroleum based motor oils.
AdamWEST - WestSPEC
http://hondamarketplace.com/showthread.php?t=3103051
Airwalker for Sale
Mhollaek9 is offline   Reply With Quote
Old 07-06-2007, 10:26 AM   #23
Mhollaek9
Mhollaek9's Avatar
AdamWEST - WestSPEC
Airwalker for Sale
Old 07-06-2007, 08:30 PM   #24
akunamatta
* B A N N E D *
i can vouch for RESTORE... just added it 50 miles ago and now, i can bounce it off the rev-limiter (6200 rpm's) and NO SMOKE. thanks padawan
Old 07-06-2007, 11:33 PM   #25
jdmracer12
1997 Honda Civic
jdmracer12's Avatar
dont even waste your money. I had the same problem, and I tried everything. Additives dont work, you'll just burn that too and you would just be wasting your money. dont let the oil get too low or you'll break the cam in half like I did. just swap it out because that motor is junk anyway.
I have never seen a honda tbelt jump teeth with everything else set and working properly. Does the engine turn over like WAA WAA WAA WAA WAA or does it go WEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE? Bent valves?
we all share 3 things in common: we all lie, we all cry, and we all take painful *****
jdmracer12 is offline   Reply With Quote
2000, additive, burn, burns, civic, d15b8, engine, foam, grade, honda, oil, restore, s2000, sea, si, slow
