Egine Builder's, Polls on what lubricant to lub up Cylinder walls before Piston installation!
Old 07-02-2007, 01:17 PM
b20vtech's Avatar
Default Egine Builder's, Polls on what lubricant to lub up Cylinder walls before Piston installation!
I personally use regular non-syntetic 5w30 motor oil on Cylinder wall prep before piston installations, but have seen and herd of so many other things people use... Please help me find out the best solution there is.... btw if im missing anyother stuff that should of been on my poll list plz feel free to inform me......
Old 07-02-2007, 01:47 PM
MAX_CFM's Avatar
Default Re: Egine Builder's, Polls on what lubricant to lub up Cylinder walls before Piston installation! (b
This is what Pro Engine Builders Use .. A tight Dry hole is a bad thing
Old 07-02-2007, 02:38 PM
d15Beta's Avatar
LOL hahahahaahahahahaha
Old 07-02-2007, 02:48 PM
b20vtech's Avatar
lol, no they don't.
Old 07-02-2007, 03:21 PM
WHTZ's Avatar
ILMAO!!!!!!!!!!!!!!!!!!
Old 07-02-2007, 03:37 PM
96Spec Ek's Avatar
Straight 30 weight oil, non detergent.
Old 07-02-2007, 03:52 PM
DonF's Avatar
Default Re: (96Spec Ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96Spec Ek &raquo;</TD></TR><TR><TD CLASS="quote">Straight 30 weight oil, non detergent.</TD></TR></TABLE> This worked better than what other combinations? What did you have problems with? Did this break-in faster or slower than other options? Did the ring life last longer?
Old 07-02-2007, 04:04 PM
Dyno Dave's Avatar
I have been using WD40 for many years and never to this day never had a ring or piston failure from using it on first startup and find the rings seat very quickly.
Regards Dyno Dave
Modified by Dyno Dave at 1:03 AM 7/4/2007
Old 07-02-2007, 04:12 PM
Jay_Sensing's Avatar
In my vast experience of like, 10 motors lol, I have used WD 40 on all of them. Maybe not the best, but definitely not the worst since none of them died an untimely death.
Old 07-02-2007, 04:44 PM
b20vtech's Avatar
My machinist uses wd40 on the walls before he installs the pistons, and after couple of turns rotating the crank, it makes little dark scratches up and down the walls... Now would that be because he was using wd40 or is it just normal like that???
Old 07-02-2007, 04:56 PM
b19coupe's Avatar
I have been using WD40 for years too.
Old 07-02-2007, 05:21 PM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAX_CFM &raquo;</TD></TR><TR><TD CLASS="quote">This is what Pro Engine Builders Use .. A tight Dry hole is a bad thing
LOL
sorry!
Old 07-02-2007, 07:05 PM
b18bEKcoupe's Avatar
Who said synthetic?
Old 07-02-2007, 07:46 PM
Natural Aspirations's Avatar
MMO anyone?
Old 07-02-2007, 07:55 PM
Default Re: (Natural Aspirations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations &raquo;</TD></TR><TR><TD CLASS="quote">MMO anyone?</TD></TR></TABLE>
Its a mystery to me.
Old 07-02-2007, 07:56 PM
Runnerdown's Avatar
I use MMO!! Then the engine runs for about a half an hour before going onto the dyno. 24 inches of vacuum (small cams) and no smoke tells me its working well.
Last time I tried oil was when I put a snowblower engine together in high school. Since then has been wd-40 and mmo.
Old 07-03-2007, 03:56 AM
1 2 NV's Avatar
Default Re: (Runnerdown)
i use ATF.
Old 07-03-2007, 07:15 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (1 2 NV)
i'm prob gonna use torco
Old 07-03-2007, 07:39 AM
AutotechRD's Avatar
Why not use the dry-lube from Total Seal. I would be willing to bet that every team in Pro-Stock uses it...
Old 07-03-2007, 09:04 AM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutotechRD &raquo;</TD></TR><TR><TD CLASS="quote">Why not use the dry-lube from Total Seal. I would be willing to bet that every team in Pro-Stock uses it...</TD></TR></TABLE> And thy replace the pistons and rings when? After how many minuets of run time?
I vote for MMO or WD40 after cleaning with acetone.
Old 07-03-2007, 01:41 PM
Broken Gearbox's Avatar
At the machine shop i work at we use WD40.
Old 07-03-2007, 04:10 PM
Mike K's Avatar
Default Re: (Broken Gearbox)
i always use HondaLube. it's just like WD-40, but i get it free at work.
Old 07-03-2007, 08:10 PM
hayabusa160's Avatar
Default Re: (Mike K)
haha honda lube great stuff.
i love using it at work seems to work better then wd40 imo
Old 07-03-2007, 09:43 PM
Combustion Contraption's Avatar
Interesting. Ive never tried it. I have never found an anerobic sealant that works as well as Honda-Bond tho, so if the results are anything like that, it could be quite good.
Old 07-04-2007, 11:58 AM
kpowerdhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">i use ATF.</TD></TR></TABLE>
Me too.
Quick Reply: Egine Builder's, Polls on what lubricant to lub up Cylinder walls before Piston installation!
