Go Back   Honda-Tech > Honda and Acura Technical Forums > All Motor/ Naturally Aspirated
Old 07-02-2007, 04:32 AM   #1
D-Rob
D-Rob's Avatar
Send a message via AIM to D-Rob
Default The Importance of Valve Adjustment
Lately I've noticed an increase in valvetrain noise.
I didn't think much of it at first. It seemed to sound 'normal' to what I was used to with the Skunk2 Pro2+'s I have been running since October 2005.
Then, I started to notice a decrease in power on the butt dyno. The car just did not seem to have the top-end it once had.
Finally, the breaking point was at the track this past Friday night. My car, which usually traps 104-105mph was only trapping 96-97mph. (I also ended up limping home because of a broken alternator belt. Click the image to open in full size.)
That is when I really thought about the condition of my engine. It just made no sense to lose 7-8mph trap speeds.
So, yesterday the car was 'freshened' up, if you will.
My father and I popped the valve cover off, reset the cam gears to 0 and checked the valve lash.
We found every valve to have .012" of clearance!
Upon tightening them to .007" on the intake side, and .008" on the exhaust, the car sounded 500% healthier.
Also, before the valve adjustment, the car seemed to idle smoothly at 16 degrees of base timing. Now, 21 degrees is the only point at which it will idle, just like it used too.
After the car warmed up, I proceeded to do a few third gear pulls. From 7,500 to 9,000 RPM, the car wanted a bunch more fuel.
Now, she feels like a million bucks.
So, the moral of the story is, if you run BIG HONKIN' cams, check your valve lash often. I had not touched my valvetrain since March of '06 before this. Now, I will be making a point to check/adjust every 6 months.
- Derek
InnovativeMotorWorks
w w w . i n n o v a t i v e - m o t o r w o r k s . c o m
K-Pro / S300 / Neptune / FlashPro
D-Rob is offline   Reply With Quote
Old 07-02-2007, 04:36 AM   #2
1 2 NV
1 2 NV's Avatar
Default Re: The Importance of Valve Adjustment (D-Rob)
wow a good informative post in the all motor forum. Click the image to open in full size. to you.
i cant agree more with valve adjustment every 3-6 months on a dd car. Click the image to open in full size.
MY CARBON FOOTPRINT IS BIGGER THAN YOURS!
1 2 NV is offline   Reply With Quote
Old 07-02-2007, 06:34 AM   #3
ipodhustle
ipodhustle's Avatar
Send a message via ICQ to ipodhustle Send a message via AIM to ipodhustle
Default Re: The Importance of Valve Adjustment (1 2 NV)
shame on you for going that long without a valve adjustment! especially with those big a$$ cams!
good reminder though, a lot of people forget some of the simplest things that should be done regularly, and it really hurts them.
like the guy who didn't clean his K&N filter for over a year. cleaned it, dyno'd it, free'd up like 7whp LOL
FUNNIEST SH!T YOU WILL EVER READ!!!:
http://www.honda-tech.com/zerothread?id=2099939
ipodhustle is offline   Reply With Quote
Old 07-02-2007, 08:09 AM   #4
ef92b
ef92b's Avatar
Default Re: The Importance of Valve Adjustment (ipodhustle)
very often we forget those damn basic stuffs. Click the image to open in full size.
nice to hear you regained the power loss. Click the image to open in full size.
EF Squad Member #35
CRX build
ef92b is offline   Reply With Quote
Old 07-02-2007, 08:12 AM   #5
VVV
VVV's Avatar
My sentiments exactly.Lazy people are morons.
VVV is offline   Reply With Quote
Old 07-02-2007, 08:14 AM   #6
Chris Tune
Chris Tune's Avatar
do a check every month.. checking wont take u over 10 - 15 mins anyways... u can even do it will joking with some peeps around since checking it aint that critical.
240+ whp all motor or 450+ whp turbo... and thats just for starters.
Originally Posted by DonF’s Agent
First off, youre talking to my guy all wrong. and if you do it again, im going to stab you in the face with a soldering iron.
Chris Tune is offline   Reply With Quote
Old 07-02-2007, 08:16 AM   #7
D-Rob
D-Rob's Avatar
Default Re: The Importance of Valve Adjustment (Chris Tune)
Indeed.
The simplest things are usually the most overlooked.
- Derek
Old 07-02-2007, 09:08 AM   #8
DA_JDM
DA_JDM's Avatar
Good post!!! I need to check my valves soon im at the 500miles mark on my new engine and my valves are making a lot of noise when im driving around Click the image to open in full size.
Modified by DA_JDM at 12:56 PM 7/2/2007
Summer 2006 stock ITR motor--> 13.385@104.58mph 1.8/60foot
Summer 2007 Built ITR motor 213whp/133wtq-->13.115@108.87mph 2.1/60foot
Summer 2008 Built 82mm 225whp/148wtq!!! Track & Highway beast!!!
Online parts seller http://images.honda-tech.com/set1/smile/emwink.gif PM for info!!!
DA_JDM is offline   Reply With Quote
Old 07-02-2007, 10:48 AM   #9
PirateMcFred
PirateMcFred's Avatar
Good post D-rob,
It's been a while since I checked the lash on my daily driver nonVTEC build. And considering that it runs .450" lift IN/EX all the time it probably beats the valvetrain even more than the high strung VTEC engines.
I've got something to do tonight!
Pirate
Tired of the same ol' BS? Some place better: LINK
Contact me if you have a Rotrex supercharger for sale.
PirateMcFred is offline   Reply With Quote
Old 07-02-2007, 04:53 PM   #10
b20vtech
b20vtech's Avatar
good info!! Click the image to open in full size.
Need Affordable Head Porting & Engine Building? pm me!
b20vtech is offline   Reply With Quote
Old 07-02-2007, 05:00 PM   #11
b19coupe
2001 Acura Integra
b19coupe's Avatar
A Gamer Tag 000
It amazes me how many people come to the dyno with cars that sound like diesels. Nice to see a reminder on H-T Click the image to open in full size.
Good on ya mate Click the image to open in full size.
Church Automotive Testing
b19coupe is offline   Reply With Quote
Old 07-03-2007, 06:13 AM   #12
b20beast978
b20beast978's Avatar
Send a message via AIM to b20beast978
good post!! very useful information
b20beast978 is offline   Reply With Quote
Old 07-18-2007, 06:20 PM   #13
boost_lee
boost_lee's Avatar
great post, im getting my valves re-adjust. this week.
2004 Ep3 K20a2 pwrd- stock cams - bolt ons- 211whp
1999 Civic Si; bolt ons 148whp
1994 Integra GSR w/ITR conversion - bone stock - 151whp
1995 Lexus SC300 2jzgte -......
1989 Supra Turbo - 350whp+
boost_lee is offline   Reply With Quote
Old 07-18-2007, 11:53 PM   #14
MikeSarr_GSR
MikeSarr_GSR's Avatar
Send a message via AIM to MikeSarr_GSR
Default Re: The Importance of Valve Adjustment (initial_si)
maintenence posts are helpful Click the image to open in full size. these engines can be a real pain
the harder you beat them without knowing how to set them straight Click the image to open in full size.
MikeSarr_GSR is offline   Reply With Quote
Old 07-19-2007, 01:22 PM   #15
rvm
rvm's Avatar
good post!
http://www.ek9.org
rvm is offline   Reply With Quote
Old 07-19-2007, 06:02 PM   #16
Aquafina
Aquafina's Avatar
iTrader Rating: (3)
facebook.com/whoopeedooracing
Default Re: (rvm)
I adjust my lash every 6,000 miles on my stock Y7.
Whoopee Doo Racing: MFactory, Rocket Motorsports, Action Clutch MFactory North American Installer
Aquafina is offline   Reply With Quote
Old 07-19-2007, 07:50 PM   #17
hayabusa160
1992 Honda Civic
hayabusa160's Avatar
Send a message via AIM to hayabusa160
Default Re: (Aquafina)
its important to check it often. i felt a big difference doing one.
1992 honda civic hatch(sold)
2000 honda accord v6(sold)
2009 pontiac g8 gt
hayabusa160 is offline   Reply With Quote
Old 07-19-2007, 09:45 PM   #18
salman
I don't have .007" in my filler Gage,
It Have .006 and .008", Ill recheck mine today..
salman is offline   Reply With Quote
Old 07-20-2007, 04:45 AM   #19
1 2 NV
1 2 NV's Avatar
Default Re: (salman)
.007IN .009EX
Old 07-20-2007, 08:06 AM   #20
b20beast978
just had my valve lash set correctly and now my motor doesnt tick like it used to!!
Old 07-20-2007, 08:19 AM   #21
k_civic
k_civic's Avatar
What its the valve adjusment for Skunk 2 stage 2?
Now i have .008 in .010ex
k_civic is offline   Reply With Quote
Old 07-20-2007, 08:46 AM   #22
b19coupe
2001 Acura Integra
b19coupe's Avatar
A Gamer Tag 000
Default Re: (k_civic)
That's a little loose(but within spec)-valve train a little noisy?
Old 07-20-2007, 09:55 AM   #23
k_civic
k_civic's Avatar
Default Re: (b19coupe)
Not noisy, but a little friction scracht in vtec lobe, only in ex cam( wierd man) Click the image to open in full size. just a little... Thats happen with CTR valve spring, now i have Skunk 2 valve spring. Re-adjust the valve .007in-.008ex?
Modified by k_civic at 11:09 AM 7/20/2007
Old 07-31-2007, 02:14 AM   #24
salman
Have the same problem As Derek, few where at .0010 and .0012,
There is a Big difference in performance,
Old 07-31-2007, 07:19 AM   #25
sircrxracer
sircrxracer's Avatar
Send a message via ICQ to sircrxracer
Holy crap i going to do mine now lol thanks Click the image to open in full size. Rob
90 CRX 12.0 @ 113 yea my kids are Proud!
Pics of my car here! http://www.honda-tech.com/zerothread?id=971694 vid 12.1 pass.
http://guelphracing.nstemp.com...X.wmv
sircrxracer is offline   Reply With Quote
95, adjustment, adjustments, bolt, civic, honda, importance, important, k20a2, lexus, loctite, ons, sc300, spring, valve
