> Honda CRX / EF Civic (1988-1991)
Old 06-28-2007, 01:25 PM   #1
metlmadman
metlmadman's Avatar
Send a message via AIM to metlmadman
Default sohc d-series vs dohc zc intake manifolds
Does anyone know if there is a flange/ bolt pattern difference between the late model sohc d-series and the dohc zc intake manifolds? or are all d-series intake manifold bolt patterns the same?
Just wondering, can I use a late model D-series supercharger on a zc engine with minimal tweaking?
or
EF8 w/ Dohc ZC
FS/FT - 2000 Kawasaki Kx 250 - track built bike $1800 Pm me for pix and/ or info. - make offer
metlmadman is offline   Reply With Quote
Old 06-28-2007, 01:28 PM   #2
SIred91
Rainman
1991 Honda CRX
SIred91's Avatar
Default Re: sohc d-series vs dohc zc intake manifolds (metlmadman)
The bolt pattern is different......jlicrx or zcspeed.com can hook you up with an adapter plate though...
All D series bolt patterns are the same EXCEPT the DOHC ZC.
"I felt this HUGE source of power, Kinda like God, when he's holding a gun!"--Homer
SIred91 is offline   Reply With Quote
Old 06-28-2007, 01:41 PM   #3
Autoworks
Autoworks's Avatar
Default Re: sohc d-series vs dohc zc intake manifolds (SIred91)
hit the nail on the head
I would not try to force a JRSC on with an adaptor though
http://www.GO-AUTOWORKS.com Parts & Race Fabrication
88' D16 HB 10.8 @ 135MPH SOLD
Innovate Motorsports-Innovative Mounts-Full Blown-Bullseye Power
Autoworks is offline   Reply With Quote
Old 06-28-2007, 01:59 PM   #4
89efDUSTY
2006 Ascari A10
89efDUSTY's Avatar
iTrader Rating: (4)
Default Re: sohc d-series vs dohc zc intake manifolds (Autoworks)
I dont believe that is entirely true, my d16a1 manifold did not line up with my d16a6.
With the adapter plate supercharging may be bad like Autoworks said because high probability of a intake leak.
89efDUSTY is offline   Reply With Quote
Old 06-28-2007, 02:01 PM   #5
metlmadman
metlmadman's Avatar
nice, quick responses
thanks guys
EF8 w/ Dohc ZC
Old 06-28-2007, 02:06 PM   #6
SIred91
Rainman
1991 Honda CRX
SIred91's Avatar
Default Re: sohc d-series vs dohc zc intake manifolds (89efDUSTY)
Okay.....DOHC D series intakes are not compatable with SOHC D series....
There.
Old 06-28-2007, 02:08 PM   #7
Autoworks
Autoworks's Avatar
D16A1 should be the same as ZC, I'm sure jilicrx will know for sure, but I am pretty sure that's correct.
Actually, that is correct, the insulated Intake Mani gasket I used on my ZC was for a D16A1 86-89 Integra.
The reason I wouldn't try to force the JRSC on with an adaptor is due to it moving the JRSC back and not ligning up correctly on the pulley side. I'm sure it could all be fixed, but it would be more time and headache than it's worth probably. (pulley tensionor, different belt lengths, pulley alignment...one more reason to turbo )
adapter, crx, dohc, dseries, honda, intake, jilicrx, manifold, manifolds, plate, plates, series, sohc, zc, zcspeedcom
