> Honda Accord (1990 - 2002)
Old 02-26-2008, 04:41 AM   #51
TouringAccord
H-T Order of Merit
TouringAccord's Avatar
Default Re: DIY - Rotor Over Hub Conversion - NOW COMPLETE - 56K take a snooze (nukem384)
yes, the axle should just slide out of the hub if it's not rusted. If it is rusted, spray it with pb blaster and a 3 jaw puller can be used to push the axle out.
TouringAccord is offline Report Post   Reply With Quote
Old 02-26-2008, 11:18 AM   #52
nukem384
nukem384's Avatar
Default Re: DIY - Rotor Over Hub Conversion - NOW COMPLETE - 56K take a snooze (TouringAccord)
also about the axel, it looks like in a lot of pics, that's it's really far extended out. do you just pop it back in or is there a special trick to getting the outer boot back in? i only ask b/c a few years ago i had a horribly bad experience trying to pop the axel back in, and it just wouldn't go, so i ended up taking the boot off and getting axel grease all over the place.
jdm_dc4_fanatic - how long did it take you to press the new bearing onto the hub? I've been calling around and all the shops are giving me prices around $50-100, but I think they are thinking of the typical Honda wheel bearings that are pressed into the knuckle, not just the hub.
TouringAccord - I've seen your posts with the $25ish quote, so would that be for like 15 minutes of labor?
Modified by nukem384 at 10:25 PM 2/26/2008
nukem384 is offline Report Post   Reply With Quote
Old 02-26-2008, 03:45 PM   #53
JDM_DC4_Fanatic
JDM_DC4_Fanatic's Avatar
You dont remove the axel, you just push it back, and pull our the hub.
As for the bearing, I did it for free at work. Just order the hub, and bearing, go to a machine shop with $20 cash and ask them to press them together just as I did.
Someone asked how to tune adjustable cam gears:
Originally Posted by DonF
Just move the stuff around. At some point it will run better, at some point it will bend your valves. Hope for the first, expect the second.
JDM_DC4_Fanatic is offline Report Post   Reply With Quote
Old 02-26-2008, 04:05 PM   #54
nukem384
nukem384's Avatar
Default Re: DIY - Rotor Over Hub Conversion - NOW COMPLETE - 56K take a snooze (JDM_DC4_Fanatic)
i didn't mean remove the axel from the tranny, but just the outer part of the axel, the boot that is connected to the bearing and hub, it looks like that part is popped out in many pics, or am i just totally off and it shouldn't be popping out of the boot at all?
so to press the bearing and hub together literally takes 5 mins to do just like in those 3 sequential pics right?
Old 02-26-2008, 04:53 PM   #55
JDM_DC4_Fanatic
dont even touch the axel boot unless its torn. just push the snout of the axel towards the tranny so the hub can slide out easier. and if that doesnt make sense, jsut dont touch the thing.
Old 02-26-2008, 06:12 PM   #56
nukem384
nukem384's Avatar
totally understand what you're saying, thanks. now i just hope i can find someplace that will press the hub and bearing together for cheap!
Old 02-26-2008, 06:38 PM   #57
JDM_DC4_Fanatic
money talks, bullshit walks my friend. show up with cash, and its a done deal. Dont go up front and talk to the boss, he wil want to make an invoice, blah blah. Just to the back, and findsomeone. Show em the cash, and call it done. Best bet is to go to a garage though. A tranny shop will always have a press.
Old 02-27-2008, 04:33 AM   #58
TouringAccord
H-T Order of Merit
$25 is the general going rate for machine shop work like this. If somewhere is trying to charge you more go elsewhere.
a new hub and new bearing will press together in no time because you don't have to separate the hub from the old bearing or the inner race from the old hub.
The boot on the axle is in no way attached to the hub or bearing. Don't even mess with the boot unless there is a tear in it.
Old 02-27-2008, 07:32 PM   #59
NGUSPEED
NGUSPEED's Avatar
Send a message via AIM to NGUSPEED
Instead of using Acura 2.3CL Brake Rotors, would there be a difference in using 98-02 Honda Accord (4cyl) Rotors instead? I know the part numbers are a little different.
Honda's I Currenty Own: '03 Accord EX - '04 Odyssey EX
Honda's I've Owned: '99 Accord EX V6 - '87 Accord LXi - '91 Civic DX(x2) - '00 Civic EX(x2) - '02 Civic Si - '95 Integra LS(x2) - '96 Accord LX(x2)
NGUSPEED is offline Report Post   Reply With Quote
Old 03-15-2008, 04:34 AM   #60
dleccord
dleccord's Avatar
im gonna have to bump this since i got a question...
when the knuckle is out, how are would it be to remove the four bolts when i dont have anything to hold the knuckle down? how much torque?
I love to hit that hood-rat pootang.
dleccord is offline Report Post   Reply With Quote
Old 03-15-2008, 08:52 AM   #61
bow tie
bow tie's Avatar
awesome man, thanks for the write up
bow tie is offline Report Post   Reply With Quote
Old 03-15-2008, 03:23 PM   #62
dleccord
dleccord's Avatar
Old 03-24-2008, 02:52 PM   #63
Daibutsu
Daibutsu's Avatar
Default Re: (dleccord)
I did this conversion along with replacing the boots on both axels this past Saturday. This write up is fantastic. Thanks
The four bolts holding the bearing in place are not that difficult. You should have no problem placing the knuckle in a good position to get enough leverage on them. I put it on the ground with the upper ball joint end, the tie rod end, and the hub all touching the ground and knelt on it. the bolts came out without any problems. You may want to spray them down first with some WD-40 or some such solvent.
My biggest issue was getting the bearing out of the knuckle. I tried the Wagner directions by replacing the bearing bolts with some extra long ones and using an air hammer on them to vibrate it loose - no luck. The BFH worked wonders in no time. As long as you don't plan on reusing the bearings, I would highly recommend this method.
I am thrilled with the thought of quick and easy brake jobs in the future.
Thanks again
Daibutsu is offline Report Post   Reply With Quote
Old 03-24-2008, 05:52 PM   #64
JDM_DC4_Fanatic
Default Re: (Daibutsu)
Glad I could help
Old 03-26-2008, 03:10 PM   #65
hb_guy
Location: jersey guy in mt. norris, pa bought my first house
Default Re: (LSR 0NE)
nice write up
cd squad #184 http://images.honda-tech.com/set1/smile/emthup.gif
Official CD Squad Thread!!!
http://www.honda-tech.com/zerothread?id=1918616
seller vouches - prostreetonline, p0rnstar http://images.honda-tech.com/set1/smile/emthup.gif
hb_guy is offline Report Post   Reply With Quote
Old 03-27-2008, 11:45 PM   #66
Nisif
Nisif's Avatar
Default Re: DIY - Rotor Over Hub Conversion - NOW COMPLETE - 56K take a snooze (NGUSPEED)
Also wondering if the 98-02 Accord Rotors will work, can anyone confirm this?
FS:Brand new:B18 timing belt http://www.honda-tech.com/zerothread/1993565
F22 water pumphttp://www.honda-tech.com/zerothread/2364834
Nisif is offline Report Post   Reply With Quote
Old 03-28-2008, 01:32 AM   #67
RS2 FAB
Default Re: DIY - Rotor Over Hub Conversion - NOW COMPLETE - 56K take a snooze (Nisif)
is there a reason why you guys ask about the 98-02 rotors? are they bigger?
RS2 FAB is offline Report Post   Reply With Quote
Old 04-01-2008, 09:28 PM   #68
JDM_DC4_Fanatic
Default Re: DIY - Rotor Over Hub Conversion - NOW COMPLETE - 56K take a snooze (RS2 FAB)
I gotta double check, but I am pretty sure that the 6th gen accord rotors have a diffrent offset from the hub, thats why the CL rotors are used.
You could also use the 3.0CL rotors if you wanted to go bigger, but that requires a bracket and pad upgrade as well. However, its 1" bigger in so if you want more stopping power, thats the way to go.
Old 04-02-2008, 12:23 AM   #69
h22accord723
2000 Acura Integra
My Garage
h22accord723's Avatar
I just got my ROH conversion kit from tasautoparts today. The hub and the bearings are already pressed together, also got the cross drilled rotors with it. I can't wait to put em on
95 cd5 22x,xxx miles on chassis as of 3/09
100,xxx on h22a motor, still runnin' like a champ
daily driver
h22accord723 is offline Report Post   Reply With Quote
Old 04-02-2008, 05:34 AM   #70
TASAuto.com
Banned
Default Re: DIY - Rotor Over Hub Conversion - NOW COMPLETE - 56K take a snooze (h22accord723)
Yes you can use 98-02 4cyl rotors
TASAuto.com is offline Report Post   Reply With Quote
Old 04-02-2008, 06:48 AM   #71
NGUSPEED
NGUSPEED's Avatar
Wow. Everything already pressed together. How much was the total cost for everything?
Old 04-04-2008, 01:11 AM   #72
h22accord723
2000 Acura Integra
My Garage
It was about $354.00 can't remember what the shipping charges were. just go to their website it's tasautoparts.com . You can browse the site. They have a lot of cool stuff. good luck hope you find what you need.
daily driver
Old 04-05-2008, 08:30 AM   #73
NGUSPEED
NGUSPEED's Avatar
Wow! I wish I found this about 3weeks ago. This would have been alot easier.
Old 04-06-2008, 06:58 PM   #74
nukem384
nukem384's Avatar
this is a great write up again! so i also got all my parts, ended up having to get a new bearing and hub assembly. the removal of the old hub/bearing/rotor is easy, my question and problem is that the new hub doesn't want to slide through the drive shaft splines. it will go in around half way and then get stuck. is this supposed to happen? are there any special tricks to get it through? tried to get the rust off, sprayed wd-40 on there, but no luck. i tried for quite a while, but was just trying to use brute force, which wasn't working. help!
Old 04-16-2008, 11:39 AM   #75
NGUSPEED
NGUSPEED's Avatar
Default Re: DIY - Rotor Over Hub Conversion - NOW COMPLETE - 56K take a snooze (TASAuto.com)
x2
I used the 98-02 4cyl Accord Rotors and they work!
I would not advise using the 98-02 Accord Hub though. I didnt try it, but a member on an alternate forum stated it doesnt work.
Bookmarks
1998, 98, accord, acura, axel, change, cl, conversion, disc, diy, honda, hub, nut, rotor, size, socket, wheel
