> Honda Accord (1990 - 2002)
Old 07-09-2007, 10:15 AM   #26
TouringAccord
H-T Order of Merit
TouringAccord's Avatar
Default Re: (LSR 0NE)
Originally Posted by LSR 0NE
are the 98 cl rotors the same size as the accords?
yes, thats why he re-used his stock caliper and caliper bracket.
You can upgrade to a prelude VTEC or 2 piston Legend caliper but both would require a rotor upgrade as well. See the other brake threads linked in the FAQ for more info on that.
TouringAccord is offline Report Post   Reply With Quote
Old 07-09-2007, 10:35 AM   #27
LSR 0NE
LSR 0NE's Avatar
Default Re: (TouringAccord)
I thought they were the same but I needed to ask to be sure, thanks for clearing that for me.
Try not, do or do not. There is no try!
http://www.exfuze.com/luisramirez
The greatest supplement on earth!!
LSR 0NE is offline Report Post   Reply With Quote
Old 07-09-2007, 10:51 AM   #28
TouringAccord
H-T Order of Merit
yep
Old 09-13-2007, 08:38 PM   #29
dawgpilot
dawgpilot's Avatar
Default Re: DIY - Rotor Over Hub Conversion - NOW COMPLETE - 56K take a snooze (JDM_DC4_Fanatic)
What year is the Accord that these pic are of? I want to do this to my 1994 EX Coupe. Will it work with the same parts that you used. Thanks for the info.... this site is great.
dawgpilot is offline Report Post   Reply With Quote
Old 09-15-2007, 04:13 PM   #30
JDM_DC4_Fanatic
JDM_DC4_Fanatic's Avatar
Default Re: DIY - Rotor Over Hub Conversion - NOW COMPLETE - 56K take a snooze (dawgpilot)
thats my 92
Someone asked how to tune adjustable cam gears:
Originally Posted by DonF
Just move the stuff around. At some point it will run better, at some point it will bend your valves. Hope for the first, expect the second.
JDM_DC4_Fanatic is offline Report Post   Reply With Quote
Old 02-07-2008, 08:51 AM   #31
Dcsports92
Dcsports92's Avatar
Send a message via AIM to Dcsports92
This is an awesome writeup my only question is I know theres the issue of rust when it comes to the removal, would they make galvenized bolts for the hub assembly?
I've been debating for awhile whether or not to stay 4 lug and just do the Rotor over hub conversion or go all out 5 lug.
My only issue with the 5 lug is that on the rear brakes on the car the spindle nut can only be tighted half way before you have to stake the crap out of it.
H23 VTEC...? Stay tuned.
Dcsports92 is offline Report Post   Reply With Quote
Old 02-07-2008, 02:36 PM   #32
JuNkDoGAccOrD
JuNkDoGAccOrD's Avatar
Send a message via AIM to JuNkDoGAccOrD
Hey with the ROH conversion can we also swap in the legend 2-piston caliper ?????
JuNkDoGAccOrD is offline Report Post   Reply With Quote
Old 02-08-2008, 08:13 AM   #33
redefsir
redefsir's Avatar
Default Re: DIY - Rotor Over Hub Conversion - NOW COMPLETE - 56K take a snooze (JuNkDoGAccOrD)
great write up....
thanks
http://b20vtec.com
redefsir is offline Report Post   Reply With Quote
Old 02-08-2008, 10:55 AM   #34
Secret Chimp
Secret Chimp's Avatar
Default Re: DIY - Rotor Over Hub Conversion - NOW COMPLETE - 56K take a snooze (redefsir)
What's a good way to separate the hub from the knuckle? My steering knuckle has next to no rust compared to the one in the pics, but I've tried twice and I can't get the thing to come out. I've tried banging around the backside with a hammer but I probably just half-killed my bearing seals doing that. Also tried PB Blaster and a torch, etc, no luck.
If I can't do it perhaps I'll just take the whole dang knuckle to a machine shop if they'd take it..
Secret Chimp is offline Report Post   Reply With Quote
Old 02-09-2008, 06:36 AM   #35
Bird333
Bird333's Avatar
Default Re: DIY - Rotor Over Hub Conversion - NOW COMPLETE - 56K take a snooze (Secret Chimp)
Get 4 long bolts (60-70mm) and screw them partially into the back of the bearing. Then take a 3 pound hammer (Thor hammer), and alternately bang on them in a criss-cross pattern. Try the hit the bolts straight on because you can/will slightly bend the bolts. It may take you quite awhile to get it out, but eventually you should start to see it move. Good luck!
Bird333 is offline Report Post   Reply With Quote
Old 02-09-2008, 02:02 PM   #36
Secret Chimp
Default Re: DIY - Rotor Over Hub Conversion - NOW COMPLETE - 56K take a snooze (Bird333)
Great idea! I don't have a 3 pound Thor hammer, but I have a gigantic old excavator tooth that weighs at least 8 pounds that should do the trick.
Old 02-23-2008, 09:40 AM   #37
NGUSPEED
NGUSPEED's Avatar
Send a message via AIM to NGUSPEED
Default Re: DIY - Rotor Over Hub Conversion - NOW COMPLETE - 56K take a snooze (NGUSPEED)
Just to make sure ...
- Which one is the Hub?
- Which one is the Bearing?
Honda's I Currenty Own: '03 Accord EX - '04 Odyssey EX
Honda's I've Owned: '99 Accord EX V6 - '87 Accord LXi - '91 Civic DX(x2) - '00 Civic EX(x2) - '02 Civic Si - '95 Integra LS(x2) - '96 Accord LX(x2)
NGUSPEED is offline Report Post   Reply With Quote
Old 02-24-2008, 12:28 AM   #38
h22a_black
h22a_black's Avatar
hub left bearing right
h22a_black is offline Report Post   Reply With Quote
Old 02-24-2008, 07:10 AM   #39
NGUSPEED
NGUSPEED's Avatar
Default Re: DIY - Rotor Over Hub Conversion - NOW COMPLETE - 56K take a snooze (h22a_black)
That's what I thought. I know sometimes when you ask the dealer for those parts, they are mislabeled. Thanks
Old 02-24-2008, 06:00 PM   #40
h22a_black
h22a_black's Avatar
np
Old 02-24-2008, 06:27 PM   #41
JDM_DC4_Fanatic
I'm back from the dead
Best way to get the hub out, is to use a slide hammer, and whale on it like theres no tomorrow. I was abel to use a hammer and just smash it out, but I also removed the whole knuckel.
Old 02-25-2008, 04:21 AM   #42
TouringAccord
H-T Order of Merit
yes
Old 02-25-2008, 04:22 AM   #43
TouringAccord
H-T Order of Merit
eh, I wouldn't. It's a good way to separate the hub from the bearing but I wouldn't do it if you are trying to keep the hub and bearing together.
Old 02-25-2008, 05:43 AM   #44
JDM_DC4_Fanatic
Default Re: DIY - Rotor Over Hub Conversion - NOW COMPLETE - 56K take a snooze (TouringAccord)
I said that going on the assumption that they are doing a ROH conversion, and wouldent need the hub or bearing, as new ones would be put in.
Also, when the bearing is soo rusted that it doesnt come out of the knuckel easily, one way or another it gets ruined. i've seen it time and time again.
However, I do see your point.
Old 02-25-2008, 05:51 AM   #45
TouringAccord
H-T Order of Merit
Default Re: (dleccord)
true, guess with all the recent brake threads I didn't think of it that way
Old 02-25-2008, 11:29 AM   #46
h22a_black
h22a_black's Avatar
hey im 905 too lol.. u part of TAC?
amazing write up by the way
Old 02-25-2008, 05:30 PM   #47
JDM_DC4_Fanatic
I'm CB7_Stu on TAC. I guess you dont make it out to the commerce or wb meets much?
My 4th gen has come along way since this brake conversion. Does feel good to see soo many people benefiting from it.
Old 02-25-2008, 05:46 PM   #48
NGUSPEED
NGUSPEED's Avatar
Parts:
1998 Acura 2.3CL Front Hubs OEM part # - 44600-YS8-A00
Just a head's up ... The correct OEM part # for the 1998 Acura 2.3CL Front Hubs is 44600-SY8-A00.
I also read on a fellow Accord Forum that you can also use the 1998-2002 Honda Accord 4cyl Front Hub as well, & that OEM Part # is 44600-S84-A00. Can someone confirm this?
Old 02-25-2008, 06:44 PM   #49
JDM_DC4_Fanatic
Thanks for the correction. As far as I know, the other bearing wont work. Only the 90-97 accord and 2.3 CL bearing are interchangeable.
Old 02-25-2008, 08:04 PM   #50
nukem384
nukem384's Avatar
this is a great how to! one question though....on the part where you basically take out the whole knuckle from the car, how hard is it to take off the knuckle from the driveshaft/axel? does it just slide right off if there is no rust? i've read the how to on how to change your brake pads/rotors, and the guy used a front hub puller to remove just the hub/bearing/rotor, is this tool not necessary because you are taking the entire knuckle out?
nukem384 is offline Report Post   Reply With Quote
Bookmarks
1998, 98, accord, acura, axel, change, cl, conversion, disc, diy, honda, hub, nut, rotor, size, socket, wheel
