Help...OBD II Code Question?
Old 06-16-2007, 09:41 AM
DC2_JAPAN's Avatar
Default Help...OBD II Code Question?
My friends car is throwing two codes right now and Im not sure on how to diagnose this problem....
54 P1336 CSF Sensor Intermittent Interruption
and the other code is a P1399 and I cant find the definition of this code anywhere. I looked on the threads on this site and no luck!!!
DC2_JAPAN's Avatar
Default Re: Help...OBD II Code Question? (DC2_JAPAN)
Old 06-16-2007, 09:42 AM
DC2_JAPAN's Avatar
I know there are a lot of techs on here with a lot of knowledge so if anyone can help I would much appreciate it. THANKS
DC2_JAPAN's Avatar
TTT
Old 06-16-2007, 09:43 AM
DC2_JAPAN's Avatar
Also, is this a common problem.... What would cause this?
Old 06-16-2007, 09:51 AM
pdiggitydogg's Avatar
P1336 Engine Speed (RPM) Fluctuation Sensor Intermittent Interruption
that last code is for chrysler = "wait to start"
You should not be getting that code at all....ever
Check the codes the other way:
https://honda-tech.com/zerothread/1901557
Come back with what those codes are
Old 06-16-2007, 09:59 AM
DC2_JAPAN's Avatar
Default Re: (pdiggitydogg)
but what is that code tryin to tell me? how do i diagnose it?
Old 06-16-2007, 10:09 AM
Syndacate's Avatar
Default Re: (DC2_JAPAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2_JAPAN &raquo;</TD></TR><TR><TD CLASS="quote">but what is that code tryin to tell me? how do i diagnose it?</TD></TR></TABLE>
By doing it the right way.
You shouldn't be getting codes that are impossible for the ECU to emit.
Follow the link pdiggitydogg gave you.
Old 06-16-2007, 10:11 AM
DC2_JAPAN's Avatar
Default Re: (Syndacate)
What I mean is.... what exactly is this telling me?
Is it electrical, mechanical, do I need to replace anything, HOW do I diagnose this problem?
Old 06-16-2007, 10:20 AM
Syndacate's Avatar
It's usually just a bad sensor.
Assuming it's the same as a crankshaft fluctuation sensor...if it's not - then I don't know what it is.
Old 06-16-2007, 10:21 AM
DC2_JAPAN's Avatar
54 CKF - crank fluctuation sensor
I did the jump and thats what it says... Could the sensor be bad? could a fuse be bad? could there be something wrong with the wiring? These are the kinds of questions im looking to be answered
Old 06-16-2007, 10:38 AM
DC2_JAPAN's Avatar
Where would this sensor be located and do any of you know what the Voltage specs should be for it? I have a DMM so I can test voltage for it... Thanks
Old 06-16-2007, 01:01 PM
DC2_JAPAN's Avatar
Old 06-16-2007, 01:02 PM
DC2_JAPAN's Avatar
Old 06-16-2007, 01:11 PM
you bumped exactly one minute later?
Its located on the oil pump, behind the timing belt, near the crank pulley
Connector is 3 pin and can be seen coming from that area
With ignition OFF:
disconnect ckf and measure the resisntance between pins 1 and 3
Spec ~ 1.6-3.2k
If thats good, then check for individual continuity between both 1 and ground and 3 and ground
Is your friend using an obd1 engine with an obd2 ecu?
Old 06-16-2007, 02:55 PM
DC2_JAPAN's Avatar
Thanks I really appreciate the help... Its nice when ppl share their knowledge like this...
Old 06-18-2007, 06:55 PM
GAME OVER 2007's Avatar
AUTOZONE
Old 06-19-2007, 12:08 PM
He already tried a scan tool...obviously, it didnt work out too well
blwn95civic
09-19-2007 11:30 AM
LoseRPunKx182
08-04-2005 01:50 AM
mprelude
01-10-2005 11:52 AM
Me2
04-11-2004 03:13 PM
93b18civic
03-21-2004 06:48 PM
Quick Reply: Help...OBD II Code Question?
