Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 06-14-2007, 05:40 PM   #1
dj-t
dj-t's Avatar
Default How can you tell if your wheel bearing is going out?
I have a 90 civic hatch and for the last couple of weeks my car sound like I am riding on some off road mud tires. One of my friend says that it is a sign of my wheel bearing going out. Is he right? I just want to confirm this before I start taking things apart. Thanks
dj-t is offline   Reply With Quote
Old 06-14-2007, 05:46 PM   #2
Tyson
Tyson's Avatar
Default Re: How can you tell if your wheel bearing is going out? (dj-t)
yep.
jack the corner up, turn the wheel with your hands. you should hear the noise. try not to confuse it with the brakes dragging tho.
forget what ppl say about shaking your wheel. you should do it anyway to check your balljoints. but its not the way to check wheel bearings.
Don't IM me your TECHNICAL question. Start a thread, I'll answer there.
I am not a moderator, nor do I need to provide you technical advice.
Tyson is online now   Reply With Quote
Old 06-14-2007, 06:01 PM   #3
dj-t
dj-t's Avatar
Default Re: How can you tell if your wheel bearing is going out? (Tyson)
Are you saying that it should sound like bad or worn out brakes if I turn it. I'll try that out now.
Old 06-14-2007, 06:04 PM   #4
Tyson
Tyson's Avatar
youll know. itll sound rough, you might feel it too.
compare with the other side.
Old 06-14-2007, 06:22 PM   #5
dj-t
dj-t's Avatar
Found it, passenger rear bearing is bad like you said it sounds rough. Thanks for your help Tyson.
Old 06-14-2007, 11:27 PM   #6
Tyson
Tyson's Avatar
and THATS the proper way to diagnose a bad wheel bearing.
Old 06-14-2007, 11:40 PM   #7
crx22
crx22's Avatar
You can also tell by driving the car and loading each side by turning the wheel turn left and it loads the right side and vice versa....use your ears and tell front to back. Then you can double check once you get an idea where....if you have done it a few times you can tell which one just by driving.
crx22 is offline   Reply With Quote
Old 06-14-2007, 11:50 PM   #8
cr-x-91
cr-x-91's Avatar
true but the cops will get you b4 u find the bad bearing..
cr-x-91 is offline   Reply With Quote
Old 02-07-2008, 04:05 PM   #9
redsi89
redsi89's Avatar
Send a message via AIM to redsi89
Default Re: (cr-x-91)
ok so i'm having trouble with mine too. when i turn to the left it gets quieter and the left gets worse. is myt left bearing bad?
B16A 89 CRX Si
redsi89 is offline   Reply With Quote
Old 02-07-2008, 04:21 PM   #10
mullet eater
mullet eater's Avatar
Default Re: (redsi89)
It sounds like your left sides bad. If you can put it up on a lift and have somebody drive it in the air you should be able to here it.
Life is what you make of it!
Patience is everything!
mullet eater is offline   Reply With Quote
Old 02-07-2008, 04:42 PM   #11
19cougar68
19cougar68's Avatar
i heard you can also test the wheel bearing by spinning the wheel and holding the spring, if the spring vibrates then thats the wheel bearing that needs to be replaced
19cougar68 is offline   Reply With Quote
Old 02-08-2008, 06:03 AM   #12
Hondaisok
1991 Honda Civic
Hondaisok's Avatar
Can you test the front tires this way? I would assume that you need to put the tranny in neutral, but can you spin the tires fast enough on the front to diagnose a bad wheel bearing?
Hondaisok is offline   Reply With Quote
bad, barings, bearing, bearings, civic, cr, honda, oing, out, put, spinning, start, test, wheel, worn, youre
