#26 | |||||
07 Si Nighthawk Black Pearl Coupe http://images.honda-tech.com/set1/smile/emwink.gif |
#27 |
anybody know???
#28 |
Awfully helpful, thanks for that!
#29 |
I went to the dealership a couple times with this problem and first they told me that it was break in. next they changed the transmission fluid which helped a little but they told me if it does not get better they would put in a new transmission.(under warranty) if i end up switching it out ill post.
#30 |
Anyone hear of having shifting problems in the 08's? I just recently purchased this car, I haven't noticed any of the symptoms above and hopefully I don't so I was just a little curious if anyone on here has experienced that yet.
2008 Civic si sedan |
#31 |
As this seems to be common enough, but are there any members that have NOT had an incident of the invisible 3rd gear?
Former 98 ITR#368 Now 06 WRX STI
#32 |
I think I'm going to stop by the dealership soon too. The issues been getting more common. True I work less than 5 miles from home and usually go there in the cold mornings, but I've noticed the problem even after I've driven on the highway for some time.
Prelude SH parts FS: email: piotrush82@hotmail.com - Spoon strut bars F+R ($250) |
#33 | |
Goodbye '95 Saturn hellooo '08 NHBP FG2! [b]Injen CAI, Tanabe 'dalion battery complete l SS + bushings for my f-ing broken shoulder cuz.... Remember, real men drive stick http://images.honda-tech.com/set1/smile/emthup.gif |
#34 |
ive been to the dealership twice and both times they say they could not duplicate the problem. and as soon as im leaving the dealership there it goes again. i heard there was a service bulletin for it could someone get me a link if there is.
2006 EX KIA :'( but then comes the si 2007 Fiji FA5 : skunk2 70mm : Skunk2 tie bar : P2R TBS : K&n drop in : Royal Purple : |
#35 | |
#36 | |
#37 | |
#38 |
I'm having similiar problems with my 06si w/33k, mostly I95 to/from work. Haven't been to a race track, but do drive "spirited" once in awhile. I switched to the "new" Honda MTF, and made shifting better for a bit, but then still get notchy, stubborn shift every so often. I do agree this most prevelent in mornings/cold weather, but once engine is warm for past 10mi at what RPM do you guys still expiernce problems????
#39 |
i had the fluid changed for free (even though i'm at 40K miles and over warrantee).
they did a one-time-favor type thing. the shifting is noticeably smoother. not a ton a difference, but the car feels new again.
'06 NHBP Si. Auger boot, OEM allseason mats in front, 22% tint 225/45/17 bridgestone potenza pole position tires. old car: '06 RX-8 http://images.honda-tech.com/set1/smile/emthup.gif |
#40 |
at what RPMs is everyone expierncing problems????? after engine is warm of course.
#41 |
I've had this problem with two tranny's. I had the transmission replaced at 16k miles because the gears were torn up. They claimed I abused it but i just ground in 2nd and 3rd all the time. I have fun with it every now and then but I never abused it. This 2nd tranny does it too. I am thinking of putting royal purple into it.
2006 Si habanero red pearl |
#42 |
i'm running the purple too, but syncromesh is the key.
#43 |
ok, i'll check it out. Thanks
#44 |
Hope this works, not sure if this was posted here yet, but I didn't see in on the first page so its not getting enough exposure...
http://s134.photobucket.com/al...o.flv
#45 | |
Cought this on the news in San Diego....
Hopefully soon Honda will recall the transmission, otherwise i will sell my car Quote:
Uno |
#46 |
"1. Shuffle through your gears upon initial start-up while idling -- Give the shifter a quick run through all the gears to allow the fluid to get moving"
-I believe the car has to be moving to actually get the fluid to move around. The fluid is just sitting in the bottom of the trans. when cold. There may be some trace fluid left on the gears, but not much(other than what they are sitting in) They need to be in motion(driving) to get the fluid to move about. Maybe drive easy till things warm up. Mine seems to do it when @ normal operating temp. though. Just some info I thought I'd add. |
#47 |
I have an 08 and I've noticed some issues with my third gear. Occationally seconds gear. I thought the put the MTF in the 08's?
"El ToRo NeGrO". <U>08 NHBP FA5</U>. 20%Tint INJEN CAI:Skunk2 Mega Power R Exhaust |
#48 | |
We've replace a bunch of 3rd gearsets, fixes em every time. |
#49 |
i have the same issue with 3rd gear, grinds easy but only popped out once. Dealer cant duplicate the problem.....so it goes unfixed. Isnt there supposed to be a recall for this soon?
#50 |
Hang tight guys, There will be a new TSB out soon that includes a new designed third gear that will be replaced under warrenty. It should be out next month.
HONDA/ASE CERTIFIED TECH Stock C1,9.8PSI 264/191 RSTECH tuned |
| Bookmarks |
| Tags |
| 2nd, 3rd, bad, crx, gear, grind, grinding, grinds, nighthawk, out, pop, pops, rsx, saturn, scratch |
