Go Back   Honda-Tech > Community Forums > General Discussion Forums > Photography
Old 06-11-2007, 05:43 AM   #1
JakeB.
Photography Pundit
JakeB.'s Avatar
Default Tutorial: Portrait Touch-up (repost)
More of PS tutorial, but... Portrait Touch-up
This lesson with go through one of the more intensive portrait touch-ups, generally reserved for shots that will go into my portfolio.
There is not going to be a drastic change to this photo... I've started with one that has already been color corrected. I'm using Photoshop 7.0.
Here is the original image opened in PS.
The first thing I wanted to do was get rid of a few distractions in the background. I created a new layer, to track my progress.
For cloning, I used a soft edged stamp at 100 pixels in diameter; You should use your own judgement on the size. I use the soft brush when I want the cloned area to blend in well, a hard brush when there is a defined area that I can't go out of.
Here you can see I cloned out the stickers on the double doors in the BG.
Next, I wanted to take care of a few blemishes on my subjects face. Again I created a new layer.
I use the healing brush when I can to take care of this. The healing brush takes the area you meter from and blends it with the area you apply the brush to... this helps create a smoother effect than cloning.
Here you can see my brush settings, and the after effects.
Next, I wanted to get rid of the stray hairs (flyaways) around her head. This could be done by cloning or healing, but if you have a fairly shallow DOF you can also enhance that effect at the same time by using Guassian Blur.
Here I create another layer, then cut out the forgrouond area.
I generally use a combination of the Magic Wand tool, the eraser, and the Lasso tool to take the foreground out of this layer.
Then I apply the Guassian Blur to the layer. Depending on the settings for your blur, it may creap back into the foreground, so go back and use the eraser to get rid of any blur that is covering your subject. I also used the eraser on a large setting at a very low opacity to fade the layer from bottom to top, that helps enhance the effect of a diminishing DOF.
On this shot, I also wanted to darken the background some. I already have the background cut out so I just copy that layer. Then I take the burn tool, at a fairly large size, and burn the whole layer.
Then, I reduce the opacity of that layer to my liking.
Next, I wanted to touch up the eyes and teeth a little. Use whatever method you like to select these areas, but I lasso the whole face, then erase what I don't want.
The teeth and whites of the eyes are on a seperate layer from the iris'.
For the whites, I open the saturation bow and reduce the master saturation to about 75%, and bring the lightness up to about 50%.
I used the color balance and saturation tools to adjust the color portions of the eyes.
This makes the eyes and teeth a bit too bright, so i use the layer opacity to adjust to my liking.
I also wanted to add a little color to the lips. Again, I used the lasso, eraser, and magic wand to select the area onto a new layer.
I used the color balance box instead of the saturation, to make the whole layer more red.
Again, this was maybe a little too much, so I reduced the opacity of the layer to liking.
Finally, some skin smoothing. I again used a combo of the lasso, and eraser to select the areas I wanted to smooth.
Make sure to erase the eyes, mouth, and nostrils from this layer; we want those to be as sharp as possible.
We want some skin texture to show through so, again, reduce the opacity of the layer to your liking.
That's it.
Was it worth it? Maybe not, but I want the best shot possible to represent me.
JakeB. is offline Report Post   Reply With Quote
Old 06-12-2007, 08:18 PM   #2
Burrito
Burrito's Avatar
Send a message via AIM to Burrito
Default Re: Tutorial: Portrait Touch-up (JakeB.)
in for reference
Burrito is offline Report Post   Reply With Quote
Old 06-12-2007, 09:34 PM   #3
cambodian
cambodian's Avatar
Default Re: Tutorial: Portrait Touch-up (Burrito)
cambodian is offline Report Post   Reply With Quote
Old 06-12-2007, 10:47 PM   #4
tuan...
tuan...'s Avatar
you forgot the blemish on her chin!
2004 Acura Tsx
6 speed
Navigation
OEM lip kit and fogs
tuan... is offline Report Post   Reply With Quote
Old 10-10-2007, 11:04 AM   #5
DjTripp
DjTripp's Avatar
Send a message via AIM to DjTripp
Default Re: (tuan...)
Good ish, thanks for the write up
Vouches: 98DC2R, Bulldogg83, MNsnowdaboy, Almost, wtfitzsoda, Rus1an
2004 CGP TSX | 1999 EPB Si | 2000 Civic EX
DjTripp is offline Report Post   Reply With Quote
Old 10-10-2007, 11:17 AM   #6
Mr Fatty
Mr Fatty's Avatar
Default Re: (DjTripp)
wow, that's awesome... all I've ever used was the healing brush to remove freckles!
Mr Fatty is offline Report Post   Reply With Quote
Old 10-10-2007, 11:29 AM   #7
Egg-weezy
Egg-weezy's Avatar
Good stuff!!
Nice bump dj tripp
06' WRX TR
Nikon D200 w/ Tamron 17-35 F2.8 and lots o lights
Egg-weezy is offline Report Post   Reply With Quote
Old 10-10-2007, 05:16 PM   #8
DagYo!
DagYo!'s Avatar
Send a message via AIM to DagYo!
Default Re: (Mr Fatty)
levels, contrast, saturation, unsharp mask, history brush and healing tool sometimes, that's it.
Ron Paul 2008
My Flickr
DagYo! is offline Report Post   Reply With Quote
Old 10-10-2007, 08:02 PM   #9
A's 94 GSR
A's 94 GSR's Avatar
Send a message via AIM to A's 94 GSR
Default Re: (DagYo!)
I like it. Nice write up.
Flickr | '94 BG-33P GSR | DC SQUAD Member: #0357 | TEAL HATCH CLUB Member: #085
[Canon Rebel XT | Canon 10-22 F/3.5-4.5 | Canon 50mm f/1.8 | Tamron 28-75mm f/2.8 | 2 Vivitar 285HV | 2 Cactus V2]
A's 94 GSR is offline Report Post   Reply With Quote
Bookmarks
portrait, touch, tutorial
