Old 06-04-2002, 09:04 AM   #1
John
John's Avatar
Default odd buzzing, then ABS light...
Well, my ABS light has finally come on permenantly. When I first started my car yesterday, it assumed it's fast idle as usual, then I heard a buzzing sound coming from underneath the hood. After about 10 seconds, the buzzing stopped, there was a pop (probably a relay coming on) from underneath the dash, and my ABS light comes on. Since I worked 16 hours yesterday, and I'll be doing the same today, I haven't had time to investigate the matter.
Anyone have any ideas or personal experiences that relate to this matter? I'll thumb through my Helms tomorrow evening when I have a little free time, but until then I'm clueless.
[url="http://www.honda-tech.com/garage?cmd=viewcar&id=102"]2003 350Z Track model w/ "stuff"[/url]
2006 Titan SE 4x4
John is offline   Reply With Quote
Old 06-04-2002, 09:18 AM   #2
4doorH22
4doorH22's Avatar
Default Re: odd buzzing, then ABS light... (DunReit)
Jump the maintenance jumper, turn key, and read ABS error code. There will be 2 series of bursts, the first is the main code, the second is the sub code. Could be throwing more than one code as well so wait for it to cycle through and you start seeing repeating codes.
Post the main/sub codes back here.
'92 Accord EX sedan ('00 OBD1 H22A4) sleeper
'11.5 M3 sedan Jerez Black Metallic 6MT M Performance Exhaust no DCT no EDC no NAV no nonsense
4doorH22 is offline   Reply With Quote
Old 06-04-2002, 09:18 AM   #3
SOHCArchangel
SOHCArchangel's Avatar
Default Re: odd buzzing, then ABS light... (4doorH22)
the damn thing keeps loosing fluid and the buzzing is the system trying to pressurize itself(?)
95 cd7 RIP murdered in santa fe nm
2003 chevy express, 2006 LBZ Duramax hauls all and 0wnz all (while keepin shiz at 25 degrees too),1999 3.0l ranger, 2002 grand am thrown rod at 41k miles....
SOHCArchangel is offline   Reply With Quote
Old 06-04-2002, 09:21 AM   #4
John
John's Avatar
Default Re: odd buzzing, then ABS light... (SOHCArchangel)
That's what I was thinking, but I didn't see any evidence of leaking anywhere.
2006 Titan SE 4x4
Old 06-04-2002, 09:39 AM   #5
carolinaACCORD
carolinaACCORD's Avatar
Send a message via AIM to carolinaACCORD
not to take away from dunreit's question, but mine stays on all the time, also.
i jumped the connecter once and it flashed two long-paused-and then two short.
can ya'll help with that?
thanks.
-James
92 Civic HB Torch Red
96 Toyota Tacoma 2WD Viper GTS Blue Metallic
carolinaACCORD is offline   Reply With Quote
Old 06-04-2002, 09:41 AM   #6
John
John's Avatar
Default Re: odd buzzing, then ABS light... (carolinaACCLUDE)
Were there any symptoms prior to your light coming on?
2006 Titan SE 4x4
Old 06-04-2002, 10:02 AM   #7
carolinaACCORD
not really, it just came on one day, and hasn't went off. it's been on for over a year now, i have not been that worried about it.i thought it could be a fuse, but i checked that. maybe a broken or messed up wire somewhere?
-James
Old 06-04-2002, 10:05 AM   #8
SOHCArchangel
well i kept adding brake fluid till i came tot he realization that there is a leak in the system somewhere....and so i stopped
Old 06-04-2002, 10:23 AM   #9
Charlie Moua
Charlie Moua's Avatar
iTrader Rating: (3)
I have the same problem wiht my accord. It's not really a problem because i drive it all the time. It only makes noise in the morning right after I drive off about 50-70 feet, then it stops. the noise it's loud, just enough so i can hear it. i hope that it's nothing seriouse.
My brothers accord right ABS is fu#@*ing up to, he took it to honda and the said it was going to cost him $780(jsut for one side)to get it fix 97 exv6. But there isn't any noise at all coming from his brakes, it drives just fine. But he's gonna get it fix soon since we live in MN
man i hope someone can get us a answer.
Jordan Tuned ~ MAPerformance ~ Progress Technology ~ CNC Werx
phearable.net ~ SpeedTrap Turbo Consulting ~ 4piston ~ Rocket Motorsports/P.R.E.
VOUCH
Charlie Moua is online now   Reply With Quote
Old 06-04-2002, 10:24 AM   #10
carolinaACCORD
oh, son of a b!#&h!!!
disregard all i said, i meant my srs light is always on, im a little 0fF T0DaY.
[Modified by carolinaACCLUDE, 2:25 PM 6/4/2002]
-James
Old 06-04-2002, 10:29 AM   #11
John
John's Avatar
Default Re: odd buzzing, then ABS light... (Charlie)
Is it a buzzing noise? It's a noise I've heard in the past, but only lasts about a second after you start up, kinda like something is pressurizing (as Misa mentioned).
2006 Titan SE 4x4
Old 06-04-2002, 10:48 AM   #12
Martaigne
Send a message via AIM to Martaigne
It's a bad ABS modulator. The buzzing noise is the modulator attempting to keep pressure in the ABS system. You'll have to replace it, and getting it from the dealer is hella expensive (I was quoted $800 just for the part). I just removed the fuses from my ABS fusebox under the hood and said to hell with it. I know how to unlock my own brakes.
<FONT COLOR="#354463">~Chris</FONT>
<FONT COLOR="#5F7797">1994 SM G-78P CD7 M2S4 F22B1</FONT>
[url="http://www.accordinglydone.com"]Accordingly Done Administrator[/url]
[url="http://www.accordinglydone.com/forum/showthread.php?s=&threadid=1292"]Your 5 Lug Swap Questions Answered[/url]
Martaigne is offline   Reply With Quote
Old 06-04-2002, 10:52 AM   #13
4doorH22
4doorH22's Avatar
Default Re: odd buzzing, then ABS light... (martaigne)
I drove without ABS for a few months. I can threshold brake no problem, but it sure is nice to have ABS in those wet, sudden, panic stop situations.
Old 06-04-2002, 11:11 AM   #14
John
John's Avatar
Or the snow.
2006 Titan SE 4x4
Old 06-04-2002, 11:49 AM   #15
John
John's Avatar
OK, so is there a definitive way to determine if the ABS modulator or the ABS motor set is failing? You want to see Majestic's great deal on the modulator? haha... take a look kids: 95 Accord EX ABS Modulator
2006 Titan SE 4x4
Old 06-04-2002, 11:59 AM   #16
4doorH22
4doorH22's Avatar
Was I in a vacuum when I wrote this? There should be a code for the modulator.
Old 06-04-2002, 12:12 PM   #17
John
John's Avatar
Click the image to open in full size. Missed that, sorry Dave. Yes, I do value your insight. We'll check it this weekend probably since I'm working so much this week.
2006 Titan SE 4x4
Old 06-04-2002, 12:15 PM   #18
Charlie Moua
iTrader Rating: (3)
yes it's a buzzing noise. whayea is your accord? mine is a 93 10th edition
VOUCH
Old 06-04-2002, 12:19 PM   #19
KGAccord
KGAccord's Avatar
Hmm I think I have this buzzing problem too. It desn't do it all the time. Is it possible that it could have gotten damaged during my swap. That's when I first noitced it, last night.
^'04 WRX Owner http://images.honda-tech.com/set1/smile/emsmileo.gif
Official Whore #006
KGAccord is offline   Reply With Quote
Old 06-04-2002, 12:35 PM   #20
4doorH22
4doorH22's Avatar
Default Re: odd buzzing, then ABS light... (KGAccord)
My ABS would sometime buzz shortly after startup when I'd start moving. Only after 10 years did I find out why it only buzzes sometimes and not all the time. It only happens when I leave my house sometimes. The house has a steep driveway and a very small, shallow pothole in it (so small you can't even feel it when you drive over it). It's only when I'm going down the driveway and hit this pothole that the ABS system lets out a quick buzz even though I'm not on the brakes. Apparently the ABS motor triggers with any deceleration, even without brakes (you may have noticed your ABS kick in when you're engine braking in the snow). Well, I engine brake down the driveway and when my tire hits the hole the ABS kicks in for a split second and lets out the buzz. I skip the hole, no buzz.
So, for all you folk hearing a little buzz after startup, does it happen downhill with a minor road imperfection?
[Modified by 4doorH22, 4:37 PM 6/4/2002]
Old 06-04-2002, 12:37 PM   #21
John
John's Avatar
The buzzing happens when I start the car, even before I start moving.
2006 Titan SE 4x4
Old 06-04-2002, 12:52 PM   #22
KGAccord
KGAccord's Avatar
Me too, just not all the time
Official Whore #006
Old 06-04-2002, 12:54 PM   #23
4doorH22
4doorH22's Avatar
Oh okay. Mine has never, ever buzzed when the car is sitting still. What is up with your crazy 5th gens?
Old 06-04-2002, 12:55 PM   #24
John
John's Avatar
They're all made in America, that's the problem... Click the image to open in full size.
2006 Titan SE 4x4
Old 06-04-2002, 02:20 PM   #25
Kazmans94cord
Kazmans94cord's Avatar
Send a message via AIM to Kazmans94cord
yeah mine does the same thing...its either the pressure or its the system tring to get the fluid in there...or however you wanna phrase it...but yeah ive heard the 5gens are really bad about this..they should have a recall...and whats up with the Majestic thing....$8008.86?? they should really fix that...i know they have a reman. one for like $5-600 something like that...
Kazmans94cord is offline   Reply With Quote
2003, 30, abs, accord, acura, adding, brake, buzz, buzzing, chevy, civic, express, fluid, honda, light, lights, noise, system
