2004 Civic, CAN'T FIND TRANSMISSION DRAIN PLUG
Old 06-01-2007, 10:28 AM
TheJellyRoll's Avatar
Default 2004 Civic, CAN'T FIND TRANSMISSION DRAIN PLUG
I've changed transmission fluid many times in other cars. I found out that there is no pan, no filter. I just need to pull the plug and go from there. Well, I looked everywhere and I can't find the Drain Plug. If someone can help I'd be very greatful.
Old 06-01-2007, 02:05 PM
Default Re: 2004 Civic, CAN'T FIND TRANSMISSION DRAIN PLUG (TheJellyRoll)
OK I found a plate that had 2 bolts holding it in. Undernieth there is a gold thing sticking out with a small screw on it. It looks like its connected to something I don't want to mess with, but is this what I'm looking for. I'm new to this car and I don't want to break anything. Please Help.
Old 06-01-2007, 02:28 PM
fventura03's Avatar
not sure if it's the same on an auto (not sure what you have, auto or manual) but on a manual here's the bolt you need to remove circled in white, at the bottom - this is for an older civic, so it won't be at the same location for your car - just look around:
Old 06-01-2007, 02:30 PM
fventura03's Avatar
a bit more help:
this is what the fill plug looks like:
and the drain:
how did i find this? i searched the archives for "transmission plug"
Old 06-01-2007, 10:20 PM
03EM2guy's Avatar
Default Re: (fventura03)
fyi ...manual's dont have a filter...
ryanevansoh
12-09-2008 05:44 AM
Garrett
08-10-2004 12:05 PM
FallenLordz
04-09-2004 11:26 AM
Quick Reply: 2004 Civic, CAN'T FIND TRANSMISSION DRAIN PLUG
