> Hybrid
Old 06-19-2007, 09:07 AM   #26
skunked
skunked's Avatar
Send a message via AIM to skunked
Default Re: (Bense)
I bent up some welding wire as a template and went down to the local NAPA to find a hose with the right bends. Make sure you measure OD of the radiator and the water inlet on the head as well.
2.2L H2B NA DC2 S/P 12.1@110
http://www.quartersportsdrag.com/
SINISTER RACING
skunked is offline Report Post   Reply With Quote
Old 06-19-2007, 09:18 AM   #27
Bense
Moderator
Bense's Avatar
Send a message via ICQ to Bense Send a message via AIM to Bense Send a message via MSN to Bense Send a message via Yahoo to Bense Send a message via Skype™ to Bense
Default Re: (skunked)
You Liar
Bense is offline Report Post   Reply With Quote
Old 06-19-2007, 03:03 PM   #28
HeikDiesel
HeikDiesel's Avatar
Send a message via AIM to HeikDiesel
You forgot to write down that part number didnt you?
Originally Posted by CRXREFIC
wrong its DOHC B16 lol if you watch the video down the page.... you can see the inside the rice box.... oh yea i think they fuk up the turbo setup because the turbo gauge its going negative pounds
HeikDiesel is offline Report Post   Reply With Quote
Old 06-19-2007, 03:52 PM   #29
skunked
skunked's Avatar
Default Re: (Bense)
Originally Posted by Bense
You Liar
yep, I have been asked this questions several times too.
SINISTER RACING
Old 06-19-2007, 04:14 PM   #30
Bense
Moderator
Bense's Avatar
lol
Old 06-19-2007, 05:57 PM   #31
HeikDiesel
HeikDiesel's Avatar
well dang you. I think eventually Im just going to have some hoses made and some fittings just welded in the spouts
Old 06-19-2007, 08:37 PM   #32
ek forever guy
ek forever guy's Avatar
Send a message via AIM to ek forever guy
Default Re: (HeikDiesel)
Anyone try to run a/c on an ek with h2b?
Just as a thought, I'm going to browse some h2b pictures and guesstimate on clearance.
Oh snappies L:O
I'm Back.
ek forever guy is offline Report Post   Reply With Quote
Old 06-19-2007, 10:17 PM   #33
unusual71
unusual71's Avatar
there aren't a lot of H2B EK setups yet so you probably wont get a good answer bud. my guess is probably not though based on all the H2B setups on H-T.
unusual71 is offline Report Post   Reply With Quote
Old 06-20-2007, 12:08 AM   #34
Bense
Moderator
Bense's Avatar
Default Re: (ek forever guy)
It could be done but you would have to modify the frame rail and/or headlight support thinger mabobber and have custom ac lines. It can be done, just gotta get creative.
Old 06-21-2007, 08:06 PM   #35
HeikDiesel
HeikDiesel's Avatar
So after talkin with bense earlier I guess the 97 version is a odd-ball. It comes with 50mm mains not 55. The crank snout is smaller. Im gonna try and measure as much as I can tonight and give you guys some specs
Old 06-22-2007, 05:24 PM   #36
Bserious
Bserious's Avatar
Send a message via AIM to Bserious
Few have questioned the possiblity of AC & Power Steering with the H2B concept. Hopefully this post will help sum up a little bit about what is involved.
Take a look at this pic...
A little bit a banging is required to run the alternator in the OEM position. The framerail was cut for clearance in this pic... an effective solution other than the "bang, test, bang bang some more, test, good" procedure.
The power steering belt travels on the outside of the alternator pulley. Do you see any room to run it in this pic? No. So you have two options, don't run it at all or modify your frame rail to do so.
I have seen H22 Hybrid configurations with AC where the belt powering the alternator is also powering the AC compressor (serpentine) inconjuction with a tensioner. I cannot recall if the bracketry mounting the compressor was OEM or afterrmarket (HCP?).
Again you can see from the above pic that the clearance is tight. Using the serpentine method mentioned above with possibly the use of a few custom/mix match components, it is feasable.
QSD 9167921549
BDHK... all just numbers.
Bserious is offline Report Post   Reply With Quote
Old 06-22-2007, 09:28 PM   #37
ek forever guy
Default Re: (Bserious)
So there's hope, so how would I get the serpentine to run? With a special tensioner?
Oh snappies L:O
I'm Back.
Old 06-22-2007, 09:34 PM   #38
Bserious
Bserious's Avatar
You see, that's not an 'H2B' thing. That is a H22 'Hybrid' question, and I am sure if you looked through one of the "H22 Air Condition" thread the answers will be found.
QSD 9167921549
Old 06-22-2007, 10:12 PM   #39
Bense
Moderator
Bense's Avatar
Thanks for the help Seth
Old 06-23-2007, 06:24 AM   #40
ek forever guy
Default Re: (Bense)
x2
Oh snappies L:O
I'm Back.
Old 06-28-2007, 03:13 PM   #41
HeikDiesel
HeikDiesel's Avatar
What have you guys been doing for fuel lines? Im still running the f20 fuel rail
Old 07-07-2007, 10:27 AM   #42
hatch96y7
hatch96y7's Avatar
Default Re: (RotiEatter)
can u tell me what the poly mount filling is and how its used
hatch96y7 is offline Report Post   Reply With Quote
Old 07-07-2007, 10:28 AM   #43
Bense
Moderator
Bense's Avatar
Default Re: (hatch96y7)
I just went to lowes and found some polyurethane concrete filler stuff. it was like 4 bucks. same thing as the window weld.
Old 07-14-2007, 04:40 PM   #44
Bense
Moderator
Bense's Avatar
i've thought about using a single channel crank pulley from a f20b and flipping it around backwards
Old 07-14-2007, 04:47 PM   #45
1700anddroping
Send a message via ICQ to 1700anddroping
Default Re: (88ED8)
Originally Posted by 88ED8
^^ thats tight!!! but hows the alt mounted to compensate for engine movement?
the bracket will have some of what the motor mounts are made out of,so it will give just a hair.with the hasport race mounts in.i don't think she is going to move very much at all....but we shall see.i just cain't get over how trick it looks.....i'm loving it.
1700anddroping is offline Report Post   Reply With Quote
Old 07-14-2007, 04:51 PM   #46
88ED8
88ED8's Avatar
Send a message via AIM to 88ED8 Send a message via MSN to 88ED8
Default Re: (1700anddroping)
cool, makes me glad that I went with the 88a bushings
88ED8 is offline Report Post   Reply With Quote
Old 07-17-2007, 09:08 AM   #47
Bense
Moderator
Bense's Avatar
Default Re: H2B FAQ (Bense)
M12-1.25 x 47mm bolt grade 10 from honda 90032-PNA-000
Old 07-21-2007, 01:46 PM   #48
BIG T
BIG T's Avatar
Send a message via AIM to BIG T
if you elminate the balance shafts will there be issues with oil pressure then??
1999 Vogue Silver Honda Civic DX Hatchback/ AC Delete/PS Delete/ Integra Rear Disk/ 24MM REAR SWAYBAY/ 26MM FRONT SWAYBAR /ASR Subframe Brace/Koni Yellow Adjustable Shocks/ Ground Control Coils (500F/400R)/K20A2 Engine Swap
An on ramp is a terrible thing to waste
BIG T is offline Report Post   Reply With Quote
Old 07-21-2007, 01:53 PM   #49
Bense
Moderator
Bense's Avatar
i just left mine sitting there. i just instruct peeps to remove the belt + pulleys
Old 07-21-2007, 02:06 PM   #50
BIG T
BIG T's Avatar
Default Re: (2fast4u831)
is having your crank pulley and balance shaft machined the same as buying the part from mcmaster carr.
Bookmarks
alternator, bracket, engine, f2b, faq, fuel, h2b, injectors, kind, relocation, setup, swap, towers, united, worth
