> Hybrid
Old 05-12-2009, 07:44 AM   #226
hondaZvic
1999 Honda Civic
My Garage
hondaZvic's Avatar
Send a message via AIM to hondaZvic
Default Re: H2B / F2B FAQ
this is good info flyrod, just read your thread,
MY COUPE | MY HATCH
hondaZvic is offline Report Post   Reply With Quote
Old 06-18-2009, 01:31 PM   #227
turtleman321
turtleman321's Avatar
Send a message via AIM to turtleman321
what wiring needs to be done for an h2b into a crx si? do i use the si harness? and then convert to OBD1 at the ecu with a conversion harness?
turtleman321 is offline Report Post   Reply With Quote
Old 06-18-2009, 03:49 PM   #228
FLATBUSH PROJECTS
FLATBUSH PROJECTS's Avatar
Send a message via AIM to FLATBUSH PROJECTS Send a message via Yahoo to FLATBUSH PROJECTS
i need some help. i have the esp kit and it calls for a obd0 alternator. but i have a obd1 alternator and need some help with the wiring. if anyone has done this please hit me up
-NOMIS IND.-CCCYLINDERHEADS.COM-GREENLOVE BICYCLES-H22SQUAD.COM-
AUG SPECIAL-TIMING BELT,WATER PUMP -$100
-WE DO BUILDS,SWAPS,HEADWORK TUNE UPS-
FLATBUSH PROJECTS is offline Report Post   Reply With Quote
Old 06-24-2009, 03:56 PM   #229
MKTurismo
MKTurismo's Avatar
Does any one know the weight differences of the B series and H22. would an H22 be a good road racing application in for ex. the DC2?
MKTurismo is offline Report Post   Reply With Quote
Old 06-24-2009, 06:05 PM   #230
sampletegi
weight difference, if i remember correctly, was posted by skunked in the h2b facts section somewhere in the middle of it. It was something like a 40lb difference. But you will also be losing AC and Power Steering so there is weight shed with the setup. I have the setup in my dc2 and can say the driving characteristics are very similar to the b18 before it; my setup was built as a canyon track car. I also dont have my AC, PS, Window Wash and have a lightweight battery. Id say my current weight is lower than my b series and i have +10hp stock over my modded b18c1. I think i came out on top with the swap.
sampletegi is offline Report Post   Reply With Quote
Old 07-28-2009, 10:13 AM   #231
Honda_Mad
Honda_Mad's Avatar
Just a Lil ?
From what i gathered 3inch exhaust nets the most gains. How many mufflers do i need, 1 or 2. I dont really care about how loud the car is jas looking 2 make power, any help would be appreciated
Honda_Mad is offline Report Post   Reply With Quote
Old 08-20-2009, 09:56 PM   #232
h22sedan
h22sedan's Avatar
Send a message via AIM to h22sedan
Icon2 Re: H2B / F2B FAQ
I don't believe it has been covered yet as to which clutch slave cylinder to use with the H2B setup.
I'm planning on using the QSD H2B kit, it appears you use the stock B clutch fork...and from what I've seen in pictures it looks like a H22 slave cylinder, and I'm confused as to why you'd need the adapter block for the B slave (unless it's a clearence issue).
EJ8 Squad Member #595
'92 PGP Civic Sedan JDM H22A LSD - Resting in pieces.
'97 VSM Civic Coupe Soon to be H22A powered.
h22sedan is online now Report Post   Reply With Quote
Old 08-21-2009, 12:42 AM   #233
Bserious
Bserious's Avatar
Send a message via AIM to Bserious
You use a B-series slave. In the OEM position the slave hangs out past the tranny on into the motor side. The reason something must be done here is to clear the larger H22 engine profile.
QSD 9167921549
BDHK... all just numbers.
Bserious is offline Report Post   Reply With Quote
Old 08-21-2009, 07:30 AM   #234
h22sedan
h22sedan's Avatar
Awesome. That was basically the only thing I was unsure about.
New transmission came today along with my crank pulley spacer from Mcmaster Carr.
Old 09-27-2009, 08:50 AM   #235
allmotorteg_96
Send a message via AIM to allmotorteg_96
Hello all. I am really thinking about doing a G23/2b. G23 with a H2B adapter and B series tranny. The only thing i have not been able to figure out is can i still use the B series axles with the G23 setup?
allmotorteg_96 is offline Report Post   Reply With Quote
Old 09-27-2009, 12:21 PM   #236
LA_HONDAS
LA_HONDAS's Avatar
yes you use b-series axles for the h2b/f2b swap
Originally Posted by Discosteak
want to expain why i sound like a dumbass? and not the guy who made a manifold out of a fence? what are you going to do for a downpipe? soupcans?
LA_HONDAS is offline Report Post   Reply With Quote
Old 09-27-2009, 08:11 PM   #237
allmotorteg_96
Thanks i just didnt know how different the F block was from the H block.
Old 10-18-2009, 02:13 PM   #238
H2B-EK4
what clutch is recomeded for h2b aiming for 220whp and maily road use and little 1/4?
thanks
H2B-EK4 is offline Report Post   Reply With Quote
Old 10-29-2009, 10:54 AM   #239
h2bciv
Send a message via AIM to h2bciv
I would recommend ACT street for dd
h2bciv is offline Report Post   Reply With Quote
Old 10-29-2009, 05:34 PM   #240
jbell
Send a message via AIM to jbell
hey there, i'm planning a h2b setup-
has anyone had experience with the h23 bluetops?
-are the rear bracket in place that are needed for the half shaft bracket?
-using a 6 rib, single pulley on the stock crank would still require framerail mods in a dc2, correct?
-i'd like to use an 8 rib pulley, but i'd not sure honda makes one, and an alternator to suit.
reason being- i plan to relocate the alternator, and stuff a rotrex supercharger down there also. it'll require some custom brackets, but no big deal. i'm just afraid to beat/mod my frame rail. do i have any other options?
marijuana: helping us learn the metric system one gram at a time.
AP2 '05 SSM, cf ht.
jbell is offline Report Post   Reply With Quote
Old 11-08-2009, 02:38 AM   #241
HYBRIDWORKS
sup jbell ,we did a h2b with a h23blue top
-the h23blue top will allow you to use the half shaft bracket converter
-we used a kaizenspeed balance shaft eliminator kit which allowed us to bring the pulley
closer to the motor, we also had to make a metal spacer to keep it in place since the
pulley bolt wouldnt hold it anymore. we also had to run with out the timing belt cover.
otherwise we would had to cut/ weld and box in sheet metal to make it fit.
-not sure if theres an 8 rib, but to help you out with trying to relocate the
alternator. and getting a rotrex charger to fit. i can ask one of my friend who is pretty
cool with zack at QSD to see if he can come up with some ideas for you.
if you have any Q's you can reach me at the shop listed below between 9am-6pm pacific time.
ask for Anthony
we'd be glad to help since we have alot of experience with h2b's
HYBRIDWORKS Address: 221 Commercial st Vallejo CA 94589 Phone: (707)554-3770
Complete auto care, performance, and tuning. EFI university and ASE & Master ASE certified techs
HYBRIDWORKS is offline Report Post   Reply With Quote
Old 11-10-2009, 09:04 PM   #242
Hella_Fresh
Hella_Fresh's Avatar
Send a message via AIM to Hella_Fresh
i have a question for everyone... how low can you go? is it like having a b series? other then having clearance issues of the motor. im worried about axles binding
GarageWorks est 2007
www.myspace.com/therealgarageworks
Hella_Fresh is online now Report Post   Reply With Quote
Old 11-11-2009, 05:38 PM   #243
H2B-EK4
When moving the crank pylley closer to the motor, the balance shaft gear is removed, this balance shaft gear made sure the cam belt did not slip off. But when its removed is there chance it can slip onto the crank pully?
Ive heard pepole using a washer between the cam belt and the crank pulley anyone know what it is and where i can get one from
thanks
Bookmarks
alternator, bracket, engine, f2b, faq, fuel, h2b, injectors, kind, relocation, setup, swap, towers, united, worth
