#1 | |||||
Moderator
http://people.clemson.edu/~ABense |
#2 |
Correct B-series Starter, Courtesy of Skunked. -Brax |
#3 |
I'm really 2slow
1994 Honda Civic |
Another question: "Can I run an H2B without banging my framerail?"
YES! But you cannot use the balance shafts and timing belt covers unless you modify the covers or make your own out of sheet metal or any other sturdy material. The balance shafts will remain on the motor but are not used. If you want to completely remove them I suggest the balance shaft eliminator kit from http://www.kaizenspeed.com but you will have to take out the crankshaft. This was done on my eg hatch but im sure all other chassis provide about the same clearance. I'm running the QSD kit by the way. First thing is to remove your crank pulley and timing balancer belt drive pulley. Next step is to take them to a machine shop to have them shave down your crank pulley and make a spacer out of the balancer belt drive pulley. I had both done for $60. (1st pic below. This is what drives the balance shafts) make sure they cut enough material out of the spacer so it fits over the crank pulley opening. Now, you can either make your own alternator bracket or buy one from http://www.explicitspeedperformance.net Im running the lower alternator bracket moved 1/2" to the passenger side with a D-series alternator(they are smaller and I had 3 laying around) Pic of balancer belt drive pulley after it was cut out to make the spacer. ![]() The rear balance shaft gear was thrown away so I illustrated with the water pump gear. Use your jaw pullers to remove the balance shaft gear(bought at harbor freight for a few bucks). Once the gear is off you need to cover that area. I used a freeze plug size 1.25" bought from kragen and some JB weld(you can see the opening that needs to be covered in the 2nd pic below). The front balance shaft gear just has 1 bolt holding it. I took it off for a cleaner look you can also get the neat balance shaft block off plate from bisimoto( pic below) Illustration of how to remove the rear balance shaft gear(shown using the water pump gear) Lastly, slide the crank pulley first and spacer second Thanks for the pics bserious! ![]() Clearance between framerail-crank pulley and spacers used to replace that balance shaft belt tensioner. ![]() Modified by 2fast4u831 at 8:41 PM 5/30/2007 Modified by 2fast4u831 at 11:47 AM 11/26/2007 |
#4 | ||
Moderator
There's also this solution that I found
#5 |
There are a handfull of companies that are currently producing H2B headers (RMF, Camp1320, SixSigma, etc...) but they start at $500+. Another option is to mod a less expensive aftermarket header if you are tight on money and you can do this yourself with handtools.
1. Purchase a section of piping from the muffler shop, I chose 2.5" because Im also running a 2.5" exhaust. 2. Use a piece of string and measure the cirumfrance of the 2.5" piping. 3. Next take this same piece of string and measure the collector until you find the area of the collector that has a circumferance that is equal to that of the 2.5" piping. 4. You can use a hacksaw, and will want to make a rough cut that leaves you room to make further adjustments. 5. The cut up collector will be oval shaped and your piping is round. You can use a shop vice to bend the piping to the corresponding shape. 6. Next mount the header to the head, mock up the piping, and trim the collector until you get the desired angle. 7. Once you have everything lined up, mark it with a marker so that you know how it mates up, and take it to a muffler shop to have them weld it up. Modified by Alchemist at 1:23 PM 5/30/2007 |
#6 |
Can you just remove the balance shafts completely? Would this solve the banging problem? Also does anyone make a crank pully similar to the n1 crank pully?
#7 | ||
As well many others offere them. Quote:
![]() Do you see the shiny, sliver spout in the background, hidden half way behind the crank pulley/alternator belt in the picture? That is the Balance shaft counter gear housing WITHOUT the gear on it. Imagine if the gear was there, then some banging would be required. Modified by Bserious at 5:08 PM 11/4/2007 |
#8 |
Moderator
Another Idea that I considered is "machining" the back side of the crank pulley about 1/4" and moving that pulley even closer to the engine. Then the 3 ribbed alternator belt for the d-series would ride on the outside ribs of the crank pulley. We might have to run another similar washer from mcmaster. Please note that in south carolina, "machining" really means to use your angle grinder with a softer disk.
My H2D has even less room than the H2B. If you convert to the F22/H23 manual timing belt tensioner (which I highly reccomend) you can shorten that timing belt bolt. Just an FYI that custom bolt from honda uses a M11-1.25 thread that goes into the block, and it's M10-1.25 external thread. The easiest and best solution is going to be to use a M10-1.25 die from mcmaster, (part number 2573A58, ~$10.16) to thread the bolt like so. Photo courtesy of Aaron Hillman: ![]() Thread it first then shorten the bolt. This is pretty much the only option here because honda decided to use a M11-1.25 thread in the block. You absolutely will not find another M11-1.25 bolt. They don't make them. Or you could do it south carolina style and Just jam a 7/16-20 bolt. Which is 11.1125mm and 1.25 pitch is equivalent to 20.32 threads per inch or something stupid close lol. Moving on, if you remove the balance shafts with the kaizen speed kit, use a machined h22 crank pulley and use an explicitspeed alternator kit 1/2" moved over* along with that shortened H23 tensioner stud. I see no reason at all that anyone will need to modify the frame at all. * = explicitspeed will have to make this for you, read their site for more info about this. If you don't want to go through the process of removing the balance shafts, you could just run this cover that bisi sells, it is made so that you can just remove the gear cover and bolt this thing on with the balance shaft still in place. I did this and remove the gear from the exhaust side balance shaft. ![]() That's all for now
#9 |
This is my upper radiator hose set-up in an EF
-two 90 degree hoses clamped to a piece of pipe -no kinks ![]()
760/SEVEN_SIXTY/BUILT High Desert service for Motor Swaps/Builds PM for all inquiries |
#10 |
King of the One Liners
Is the Flywheel and Spacer the only difference in the 2 kits? Not starting a debate but maybe if someone chimes in if there are any other differences it would help. thanks
AllenBuilt/RSTech Tuned All Motor F2K Coupe: 10.97 - 126.8 http://www.rstech-racing.com |
#11 | |
I'm really 2slow
1994 Honda Civic |
#12 | |
From what I know the QSD kit leaves the trans in the original location giving ideal axle angle and to keep the shift linkage from binding up. I do see a problem with that that the oil pan now tilts towards the front of the car, submerging the pickup tube in less oil and also the exhaust issues but Bense solved the oil drain issue and i think i might just add a little extra oil when I run mine.
#13 |
Moderator
both of you guys are correct about the differences.
#14 | |
I dont know if this should go here but who is making all that EGR block off plates for h22's I know he does euro r manifold work too
I found it finally Bense so I dunno if you wanna delete this or use this info but this guy makes a lot of good stuff for f20 h22 guys wanting to run the euro r manifold and block egr http://www.roskoracing.com
#15 |
Will this fit onto an accord/prelude chastity?
#16 | |
no the H2B is only for the EF, DA, EG/DC, and EK's
#17 | |
Moderator
#18 | |
So I have a question fellas. On the balancer shaft drive gear you guys are machining that down to be put on after the pulley? so it should go timing belt drive, spacer, pulley, spacer, bolt?
So basically your taking number 15 out completely, making a spacer that sits inside the driverside of the pully and it shifts it that much over? What about altenator angles and such? Modified by HeikDiesel at 11:08 AM 6/13/2007 Modified by HeikDiesel at 11:16 AM 6/13/2007
#19 | |
#20 | ||
#21 | |
The ony reason you run a spacer on the outside of the crank pulley (see Bense's pics above) would be if you are trying to move the pulley closer to the motor. In this case you would not run the spacer between the T-belt gear and crank pulley. This would also require a custom alternator bracket that would move the alternator inline with the crank pulley. |
#22 | |
Awesome
You guys are a lot of helpSo just to make sure im just gonna run that washer, timing belt drive, pulley, spacer and then bolt to move it inboard. I just checked I did order the explicit 1/2" over kit so that should work golden Modified by HeikDiesel at 11:42 AM 6/13/2007
#23 |
Moderator
excellent
I'm holding a test washer that I ordered, but it was too think 1/2" instead of the 3/8" It's fun to play with btw lol.
#24 | |
What radiator hoses are we supposed to use, I figured it wasnt the same as a normal swap because of the angle? I dont think Ive ever seen this question adressed?
#25 |
Moderator
I've seen guys use the flex hoses. I used a 98 prelude hose that i cut off some but I don't like the fitment.
| Bookmarks |
| Tags |
| alternator, bracket, engine, f2b, faq, fuel, h2b, injectors, kind, relocation, setup, swap, towers, united, worth |
