Calculating dry weight: how much does gas weigh?
Old 06-03-2002, 06:05 AM
Civic44's Avatar
Default Calculating dry weight: how much does gas weigh?
I put my car on the digital scales yesterday and I'm trying to calculate the dry weight in race trim. Does anyone know how much pump gas weighs in comparison to water? I know how many liters of gas I had, and I know a liter of water weighs 1 kilo, so if someone could tell me gas weighs, for example, 63% as heavy as water, I could calculate how hevy my gas was. Thanks all.
Vince
Old 06-03-2002, 06:16 AM
Willard's Avatar
Default Re: Calculating dry weight: how much does gas weigh? (Civic13)
Water - 62.4 pounds per qubic foot..
Gasoline weighs about 6 pounds per gallon and diesel is about 8 pounds per gallon.
But to answer your question....
Specific gravity of petroleum = 0.88
http://www.reade.com/Particle_Briefings/spec_gra2.html
Will
Old 06-03-2002, 06:17 AM
Apocalypse's Avatar
1 gallon gas = 6.152 LB
edit: anything you probably would ever need about weights and measures
http://www.weights.az.gov/Consumer/M...onversion.html
[Modified by SpeedFreek24, 10:18 AM 6/3/2002]
Old 06-03-2002, 11:04 AM
Grumpy's Avatar
Default Re: Calculating dry weight: how much does gas weigh? (SpeedFreek24)
except the weight for kerosine is wrong on the chart. It shouild be 6.7 pounds per gallon NOT 4.8. It IS HEAVIER than gasoline.
Grumpy
Old 06-03-2002, 11:07 AM
Apocalypse's Avatar
Default Re: Calculating dry weight: how much does gas weigh? (Grumpy)
Hey Grumpy,
I understand you met my dad yesterday.
I talked to Elyse but didn't get a chance to make it over to your sit of the paddock t meet you.... soon enough though.
Old 06-03-2002, 12:29 PM
Holden's Avatar
I once tried to answer this question while working at a big Petroleum company and got all the info.
Forget about 3 decimal places in the pounds per gallon number. The weight of gasoline varies by region and season. The colder the region or season, the lighter the gas is due to more butane being used to enhance vaporization on cold starts.
From the lightest possible gas to the heaviest, the difference is about 1/4 pound per gallon.
I just go with 6 pounds/gallon and call it a day!
Ldo
10-19-2008 08:39 AM
onekoop
10
10-11-2006 10:45 PM
type-r 01 886
Honda Motorcycles
06-07-2004 03:20 PM
fastwanabe
05-26-2003 03:38 PM
Quick Reply: Calculating dry weight: how much does gas weigh?
