#1 | |||||
#2 |
good info
#3 | |
... im guessing this also applies to the d16y7 which is very similar to the b7 engine...correct? besides the intake manifold
#4 |
Depending on which b7 we're talking about, the usdm b7 only had 8 valves.
the y7 has 16. Which leads me to believe the OP is talking about the usdm b7 because a 16valve head upgrade really would be a big benefactor. Good write-up NVMD. [edit] D15B8 Found in: 1992-1995 Honda Civic CX (U.S. model) Displacement : 1493 cm3 Bore and Stroke : 75 mm X 84.5 mm Compression : 9.1:1 Power : 70 hp @ 4500 rpm & 83 ft·lbf @ 3000 rpm Valvetrain : SOHC (2 valves per cylinder) Fuel Control : OBD-1 MPFI Modified by ek forever guy at 9:44 PM 5/21/2007
Oh snappies L:O I'm Back. |
#5 |
I like this...
Obviously not my cup of tea but at least ur taking a smart approach about it...
Need suggestions on good xbox 360 games - I don't play multi-player (online) and first person shooters I reserve for the computer - Any suggestions are welcome '97 EX - Stock as stock can get - Daily driver, KYB struts, Tokico reds, I/H/E |
#6 | |
#7 | |
#8 |
I think the d15 can take fairly well to bolt on mods.
I had a 95 DX sedan that put down 100 hp to the wheels. This was in line with the usual 105 whp from the stock EX. I had a chikara header, short ram intake, tenzo R axle back exhaust, lightened flywheel, and a full MSD set up. These are embarrassing mods to think about today but the late nineties were tough for imports. Throw on the Vtec head and some better parts and the d15 should be getting close to a stock b16a in whp. Not bad for a lowly DX.
Since 2003! www.k-series.com |
#9 |
great info...thanks
#10 |
DONT: do intake, header, exhaust (you'll be disappointed) and then modify the fuel and ignition system (will get you nowhere at this point).
DO: raise compression (pistons) and upgrade the cam. Then do the things I told you not to.
My motor doesn't exist. |
#11 |
good info
TEAM STREET GEEKZ |
#12 |
subscribee
George Perinis Saturn Vue V-6 AWD (VTEC..http://images.honda-tech.com/set1/smile/emsmile.gif) Vouches: jdmekcivic2eg, tachyteg, boosthead, Torque Monster, 97silverEk, Todd00, Crosser, fangtl, Omniman, thrashin, B. Falfa, DavidR, 2KWK4U, c13r, mor ber, dwnthehatch, solo-x, H22coupe and more if needed.! |
| Bookmarks |
| Tags |
| cam, car, d15b7, easy, flywheel, found, guide, idiots, in, light, lightweight, make, mod, performance, things, tuning |
