honda accord 2000 car alarm
Old 05-14-2007, 12:23 PM
mila's Avatar
Default honda accord 2000 car alarm disarm
My car alarm sounds at all times of the day for no reason. the only way I can turn it off is by putting the key in the ignition to turn the car on or I just let it go until it stops by itself. The alarm also almost always sounds after I have unlocked and entered the car just before I start the car. My remote does not work to shut the alarm off, yet I can still use it to open the trunk.
Has anyone else had this problem?
And how can it be fixed?
How can I temproraily disarm the alarm that came with the car when I bought it in 2000?
thanks for any help on this...
Old 05-14-2007, 01:19 PM
rossodsm's Avatar
Default Re: honda accord 2000 car alarm disarm (mila)
Sometimes those alarms malfunction, you have to reset it by disconnecting the battery, but i'm not to familiar with stock alarms.
Old 05-14-2007, 02:57 PM
power11's Avatar
Default Re: honda accord 2000 car alarm disarm (rossodsm)
or. you can put your key into the drivers side lock and turn it left then right and it should reset and turn off.
Old 05-15-2007, 12:25 PM
mila's Avatar
thanks for the suggestion, ill try to disconnect the battery, i'll try anything at this point.
Old 05-15-2007, 12:28 PM
mila's Avatar
Default Re: honda accord 2000 car alarm disarm (power11)
ive tried to put the key in the driver's side lock and turn it left then right, unfortunately that doesnt work....thanks though...ill report back when i finally figure it out so that hopefully other people that may have this problem can be helped....
Old 05-15-2007, 02:35 PM
YeuEmMaiMai's Avatar
try resetting the multiplex unit on the car by
setting the intermittent wiper ring to the middle position
turn every accessory off
turn the car to the on position and do not start
Old 06-06-2007, 04:03 PM
mila's Avatar
I disconnected the battery and , yes, that worked great. the alarm doesnt go off anymore at strange times for no reason!
Thanks so much.
I seem to have isolated the problem also.
It seems as though there is something wrong with the sensors/wiring to the alarm from the car seat, when i sit or press on the car seat this activates the alarm when it shouldnt be activated. Will have to look into the exact problem. But for now I am grateful that the alarm doesnt go off while sitting in the drive for no reason.
thanks again
anthonymarriott
09-19-2017 12:26 AM
TsunamiHair
Honda Civic (2001 - 2005)
04-18-2009 04:20 PM
mila
Audio / Security / Video
05-14-2007 12:38 PM
nuclearfurnace
07-17-2004 08:59 PM
95 Gizzer
03-27-2003 05:44 PM
Quick Reply: honda accord 2000 car alarm
