Old 05-14-2007, 12:08 PM   #1
luvs2spooge
luvs2spooge's Avatar
Send a message via AIM to luvs2spooge
Default what DIZZY will work for the jdm d15b vtec motor?
was wondering what dizzy would work for the jdm d15b vtec engine... im using an obd2 sohc vtec dizzy at the moment right now. and its not workin so well..
can i use a sohc d16z6 dizzy w/ this motor?
anyone got one for sale cheap pm me.. have headers or intake to trade.
luvs2spooge is offline   Reply With Quote
Old 05-14-2007, 12:27 PM   #2
Relic1
1992 Honda Civic
My Garage
Relic1's Avatar
the Z6/Z1 distributor would be your best bet. (OBD1 SOHC VTEC)
and you're right, I can't spell.
the civic hatch community
Relic1 is offline   Reply With Quote
Old 05-14-2007, 01:12 PM   #3
1995Civic
1995Civic's Avatar
Default Re: (Relic1)
Agreed.
I would just run a Z6, much easier to find.
1995Civic is offline   Reply With Quote
Old 05-14-2007, 05:24 PM   #4
luvs2spooge
Default Re: (1995Civic)
does a dizzy have anything to do w/ bad gas mileage? im getting 10/gallon
Old 05-14-2007, 05:31 PM   #5
1995Civic
1995Civic's Avatar
Default Re: (luvs2spooge)
Hmm..not that I know of.
Air filter, fuel filter, spark plugs, tire pressure, etc are what have effects on gas mileage.
Old 05-14-2007, 09:52 PM   #6
boots420
boots420's Avatar
Send a message via AIM to boots420
Default Re: what DIZZY will work for the jdm d15b vtec motor? (luvs2spooge)
i have a d15b dizzy. 50 bux. pm me if ya interested........
94 Ej1-Stock-Daily Driver
Bought/Sold: fourthgenhatchB17, wrx-killer-Sti-eater
WTB: 92-95 Instrument Panel Cluster, 92-95 Radiator Overflow Tank
boots420 is offline   Reply With Quote
Old 05-14-2007, 09:58 PM   #7
luvs2spooge
Default Re: what DIZZY will work for the jdm d15b vtec motor? (boots420)
is it a d15b vtec one? jdm
Old 05-28-2007, 06:43 PM   #8
luvs2spooge
Old 05-29-2007, 12:02 PM   #9
luvs2spooge
Old 05-29-2007, 12:39 PM   #10
Syndacate
Syndacate's Avatar
Send a message via AIM to Syndacate
You could PM him y'know. Just click the little "IM" emblem under his avatar.
'97 Honda Civic EX - Occasional DD - KYB struts, Tokico reds, I/H/E
'05 Dodge SRT4 ACR - Occasional DD / GS AutoX car
'82 Honda CM450E - Prossible project bike; '85 Honda CB450SCL - Stock DD
Syndacate is offline   Reply With Quote
Old 05-31-2007, 12:46 PM   #11
luvs2spooge
Default Re: what DIZZY will work for the jdm d15b vtec motor? (Syndacate)
thanks boots... works great!! great seller if you know what i mean.
but i got code 13 car still boggin weird... nothing wrong w/ dizzy its my car...
Old 05-31-2007, 12:55 PM   #12
Relic1
1992 Honda Civic
My Garage
Relic1's Avatar
CEL13 is the PA sensor (or atmospheric pressure sensor). has ZERO to do with the distributor.
which ECU are you using?
Most ECUs in the US have the sensor inside the ECU but they can be damaged when chipping the ECU and they have also been known to go bad on very rare occasions.
If you have a JDM ECU then it doesn't have one and shouldn't throw the CEL unless something is wrong.
UNLESS...the ECU is chipped. JDM ECUs will throw the CEL (due to no ahrdware in the ECU) then disable the PA/boro sensor and you'll be fine.
BTW, CEL13 will cause the car to get super crap MPG, you'll be in limp home mode.
Old 05-31-2007, 02:29 PM   #13
boots420
boots420's Avatar
no problem brotha. always glad to help another honda homie out. sounds like that CEL13 is your new problem. which probably explains why your getting that horrible gas mileage. which ecu are you using? the stock jdm d15b ecu?
Old 05-31-2007, 04:24 PM   #14
luvs2spooge
i was using a stock ecu w/ no cel but it bogged alot.. and today after i put on the dizzy i used the stock ecu for a lap around the block it bogged so i put in a chipped p28 which drives better but had cel. should i put back the stock ecu?
Old 05-31-2007, 08:32 PM   #15
boots420
boots420's Avatar
that stock ecu for the jdm d15b is a P08 correct? I would start off with getting it to run with that stock ecu. my bet is....... that timing is still waay off.
run the stock ecu, check and set timing. then report back. i bet it'll be running like a champ.
Old 05-31-2007, 11:41 PM   #16
luvs2spooge
Default Re: (boots420)
the stock ecu is p28.. i tried switchin it again and w/ the stock ecu it bogs.. but no check light.. i did timing w/ the chipped one its set at 14 i think... ill try to set the timing w/ the stock ecu where should i set it at?
Old 06-01-2007, 09:02 AM   #17
boots420
boots420's Avatar
you dont have an aftermarket cam gear right?
if not then just set the timing. making sure that both of the lines on the pully and timing cover line up.
did you fix that fuel leak? cause that is def also part of the problem.
Old 06-01-2007, 11:53 AM   #18
luvs2spooge
yep fixed that fuel leak massive one too h uh.. lol.. imma try to do timing on the stock ecu today wish me luck
Old 06-01-2007, 12:31 PM   #19
boots420
boots420's Avatar
best of luck friend. hey, look at it this waay. as least she starts and runs. she'll be spooln' up soon. don't you worry.
Old 06-05-2007, 12:04 PM   #20
boots420
boots420's Avatar
did you ever get that thing running cherry?
Old 06-05-2007, 12:14 PM   #21
luvs2spooge
still using the chipped ecu.. w/ the code.. runs better than stock one.. never had a chance to do timing on stock ecu.. but it runs fine haha needs to be tuned though. might trade the car need money so bad.. thanks again boots... ill hit you up for sure about the other thing soon
Old 01-06-2013, 01:19 AM   #22
roadrialworker
i have a 93 Del sol with a swapped d15b in it and having problems starting up and then when it does start it doesnt want to run right. if someone could please help me out to figure out what is going on that would be great.
roadrialworker is offline   Reply With Quote
Old 01-06-2013, 04:50 AM   #23
grumblemarc
The Grumpiest
1996 Honda Civic
grumblemarc's Avatar
iTrader Rating: (3)
Send a message via AIM to grumblemarc Send a message via Yahoo to grumblemarc Send a message via Skype™ to grumblemarc
You searched. Great. You bumped an OLD thread. Bad. "doesn't want to run right" doesn't tell anyone anything. More information? That would be great.
FAQs!--How to Turbocharge your Civic--Want a faster Civic?--Building your dream car 101
Don't use the words "Help!" or "Best" in your threads titles. It shows everyone that you don't have a clue and that you are extremely lazy.
grumblemarc is online now   Reply With Quote
Old 01-06-2013, 10:07 PM   #24
deschlong
D__ojo__por qué__GuY
1993 Honda Civic
My Garage
deschlong's Avatar
iTrader Rating: (4)
Start your own thread, roadrial. And give a lot more details when you do.
|OMG, deschlong has a build thread - a '93 Si Hatch with serious OEM goodies.|
|»»LINK to my DIYs«« for 92-95 Civics | FS: 92-95 Civic Optional & Rare Parts | Buyer's guide to QUALITY Aftermarket Parts | |
deschlong is offline   Reply With Quote
9295, bogging, d15, d15b, distributors, dizzy, dizzys, fit, jdm, jdmd15b, kind, leak, sohc, vtec, work
