built motor smoking
Old 05-10-2007, 11:33 AM
pnut1.8c1's Avatar
Default built motor smoking
i have a b18c1 with a b16 head with 13:1 comp i have the stock ecu and injectors i have tried to adjust my fuel preasure regulator every were from 30psi to 40psi, im running on 100 octaine but my car still smokes a lot.....any sugestions....thanks
Old 05-10-2007, 11:44 AM
b20vtech's Avatar
Default Re: built motor smoking (pnut1.8c1)
bad stem seals?? bad rings???
Old 05-10-2007, 12:37 PM
coneheadsracing's Avatar
Default Re: built motor smoking (b20vtech)
is this the first time firign it up? Who built it? Were the piston rings set properly, could be that you are still seating everything and it may stop.
Egyptian_Kid's Avatar
What color is the smoke? Any oil consumption? How did you break in the motor?
Old 05-10-2007, 12:41 PM
Pinche Caro's Avatar
What color is the smoke? When does it smoke? Check Spark plugs for signs of oil leaking through..
Old 05-10-2007, 12:46 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pnut1.8c1 &raquo;</TD></TR><TR><TD CLASS="quote">any sugestions....thanks </TD></TR></TABLE>
Do a compression and leakdown test. Then tune it with a wideband on a dyno.
Old 05-10-2007, 10:54 PM
hybridmiklo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pnut1.8c1 &raquo;</TD></TR><TR><TD CLASS="quote">i have a b18c1 with a b16 head with 13:1 comp i have the STOCK ECU and INJECTORS i have tried to adjust my fuel preasure regulator every were from 30psi to 40psi, im running on 100 octaine but my car still smokes a lot.....any sugestions....thanks </TD></TR></TABLE>
That's what probably started the problem.
Old 05-11-2007, 01:51 PM
dinko's Avatar
Default Re: built motor smoking (hybridmiklo)
tuning with a FPR...awesome!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">
Do a compression and leakdown test. Then tune it with a wideband on a dyno.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Egyptian_Kid &raquo;</TD></TR><TR><TD CLASS="quote">What color is the smoke? Any oil consumption? How did you break in the motor?</TD></TR></TABLE>
it would also help if you listed your setup. are you in that big of a hurry to type this **** up.
i picture like a dude starting his car up infront of his house...it starts smoking....he leaves the car running and runs like a bat outta hell into the house...posts a new topic on honda-tech titled "omfg my car is smoking!!! help!!" and you run back outside..doing circles around the car while pulling on your hair...
Old 05-11-2007, 06:55 PM
IntegraType-R's Avatar
stock ecu on 13.1 cr motor? the smoke is more then likely blueish..you might think its oil.. but its really your **** running lean as expletive.. when i slapped my itbs on and tried starting it up for ***** on my current tune, when i had a manifold, it idled like poo..and it blew blue smoke out the butt..hooked a wideband up..i was 20AFR..lean buddy~~~~ of course the car wasn't wrong for longer then 30 seconds..but still yoru running entirely too lean..dont start your car..or u'll be rebuilding it again.
Old 05-12-2007, 10:54 AM
ATYPR's Avatar
stock cams??
how long did it run before it started to smoke?
Old 05-13-2007, 08:28 AM
h22Sicoupe's Avatar
Default Re: built motor smoking (FUCATYPR)
if your running stock ecu, and injectors i'm pretty sure you're running stock fuel pump. 13:1 requires at least 370cc and a fuel pump and some tuning.
Old 05-13-2007, 09:15 AM
Chris Tune's Avatar
Default Re: built motor smoking (h22Sicoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22Sicoupe &raquo;</TD></TR><TR><TD CLASS="quote">if your running stock ecu, and injectors i'm pretty sure you're running stock fuel pump. 13:1 requires at least 370cc and a fuel pump and some tuning.</TD></TR></TABLE>
who told u that joke? if he's fuel pump is healthy i dont think he will never max it... i have used stock fuel pumps up to 280 whp turbo... dont think he will make more than that...
tune the engine at least for idle and part throttle driving, then u'll know for sure if its mechanical or a tuning problem...
Old 05-13-2007, 11:57 AM
h22Sicoupe's Avatar
Default Re: built motor smoking (chris_tune)
how high are you revving and what size injectors? most 13:1 peeps rev their **** to 9200.
i had a stock FP on 370cc and @ 7800rpms the pump couldn't handle anymore, had to switch it out to a 255lph walbro.
spintboy
12
09-25-2008 01:13 AM
kixcrx
19
03-29-2007 07:02 PM
escape2me
06-29-2005 11:24 AM
Spec R
04-22-2005 09:16 AM
done
04-23-2004 06:55 PM
Quick Reply: built motor smoking
