air conditioning only cold while accelerating?
Old 05-10-2007, 09:42 AM
Blown383's Avatar
Default air conditioning only cold while accelerating?
Recently my a/c only gets cold while I'm accelerating. At a stop signs it gets warm pretty quick. The car is a 96' Accrod EX-V6. Does anyone know what the problem is? Does it need more freon?
-B
Old 05-10-2007, 10:03 AM
He knows where you live!
TheMuffinMan's Avatar
When was the last time you had it recharged? Is the AC fan kicking in?
Old 05-10-2007, 10:31 AM
Blown383's Avatar
Default Re: (TheMuffinMan)
I have never recharged the a/c system and how would I check to see if the a/c fan is kicking on? Thanks for the speedy reply!
-B
Old 05-10-2007, 10:47 AM
technine's Avatar
Default Re: (Blown383)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown383 &raquo;</TD></TR><TR><TD CLASS="quote">I have never recharged the a/c system and how would I check to see if the a/c fan is kicking on? Thanks for the speedy reply!
-B</TD></TR></TABLE>
Turn your a/c on and open your hood up. You will see and here the a/c fan run.
Old 05-10-2007, 01:17 PM
Blown383's Avatar
I checked the fans and they are turning on when I hit the A/C button. Anythoughts?
-B
Old 05-10-2007, 01:42 PM
YeuEmMaiMai's Avatar
system low on charge
Old 05-10-2007, 02:02 PM
Blown383's Avatar
Default Re: (YeuEmMaiMai)
Someone on another forum asked me to check the a/c fan clutch. How would I go about doing that and how would I check to see if the charge is low?
-B
Old 05-10-2007, 04:47 PM
DCFIVER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown383 &raquo;</TD></TR><TR><TD CLASS="quote">Someone on another forum asked me to check the a/c fan clutch. How would I go about doing that and how would I check to see if the charge is low?
if it's low then you have a leak. Look into that first....
Old 05-10-2007, 06:47 PM
skingfreak's Avatar
Default Re: (cb7-R)
i wouldn't jump right to a leak, since he said he has never recahrged it, and its a 96...eventulay you have to recharge it no matter what. i would look into the recharging idea
Old 05-10-2007, 07:22 PM
The-Kid's Avatar
sorry to jack, but how much would it cost to do a recharge? and where would you get one?
Old 05-10-2007, 08:19 PM
DCFIVER's Avatar
Default Re: (skingfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skingfreak &raquo;</TD></TR><TR><TD CLASS="quote">i wouldn't jump right to a leak, since he said he has never recahrged it, and its a 96...eventulay you have to recharge it no matter what. i would look into the recharging idea </TD></TR></TABLE>
Freon does not evaporate or dissapte in any way shape or forum. if you have a completely sealed AC system then it will last forever. However a leak will always develop. Some leaks are so minute that it would take around 5 years to completely empty the system,while others will do it much quicker.
Old 05-10-2007, 08:47 PM
Blown383's Avatar
So how do I go about looking for the leak?
-B
Old 05-10-2007, 09:18 PM
DCFIVER's Avatar
Well you can take it to a shop or do it your-self. You need AC dye and an ultra violet light. Inject the dye into the low side then cycle the system for a day or two. Use the light to find the leak afterwards. Sometimes it is almost impossible to find in which case you will need a "sniffer" This is a tool that detects freon an emits a beeping sound when the source of the leak is located.When used together these methods are guaranteed to fing the leak.
nightscream
10
07-06-2010 05:58 PM
DCshoecompany
09-10-2007 11:23 AM
vietintegboi
07-07-2007 10:02 PM
DYRcivic
05-11-2007 07:05 AM
Peter Fox
07-22-2003 06:22 AM
Quick Reply: air conditioning only cold while accelerating?
