Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Prelude
Old 05-08-2007, 07:56 AM   #1
ceyazzie
ceyazzie's Avatar
Default what dose the the"BRAKE LAMP" mean???
My BRAKE LAMP light comes on when the car moves... whats that light for???? do i have a problem??
ceyazzie is offline   Reply With Quote
Old 05-08-2007, 07:59 AM   #2
AndyD
AndyD's Avatar
Default Re: what dose the the"BRAKE LAMP" mean??? (ceyazzie)
Does your car have ABS? I think it is an ABS error.
Get the code. Know how to get the code?
Before you do that though, have someone push the brake pedal to make sure all of your brake lights are working.
'92 Accord Sedan w/H22A. '92 Prelude Si 4WS engineless. '89 240SX w/SR20DET.
Vouch thread
CB7 F22A1 H22 5spd swap parts FS
AndyD is offline   Reply With Quote
Old 05-08-2007, 08:01 AM   #3
gavzter
gavzter's Avatar
Send a message via ICQ to gavzter
Default Re: what dose the the"BRAKE LAMP" mean??? (AndyD)
it means you have a brake light out Click the image to open in full size.
Gavz
[url="http://www.preludeuk.co.uk"]http://www.preludeuk.co.uk[/url]
gavzter is offline   Reply With Quote
Old 05-08-2007, 08:08 AM   #4
ceyazzie
ceyazzie's Avatar
Default Re: what dose the the"BRAKE LAMP" mean??? (gavzter)
ohh. i think tha third brake light is out??? i need to check.
Old 05-08-2007, 11:36 AM   #5
royalfelix
royalfelix's Avatar
also ur emergency brake can be on OR.... was my problem u could be low on brake fluid.
92 lude h23a1 /10.1*1/8 mile
royalfelix is offline   Reply With Quote
Old 05-08-2007, 03:27 PM   #6
mattsnooz
mattsnooz's Avatar
Default Re: what dose the the"BRAKE LAMP" mean??? (royalfelix)
yeah, could be the rear window break light.
h23, the stroke is long, and strong, and she wants to get the friction on.
http://www.comfortcurtains.totalwarehouse.com
mattsnooz is offline   Reply With Quote
Old 05-08-2007, 04:16 PM   #7
mkazm83
mkazm83's Avatar
Send a message via AIM to mkazm83
Default Re: what dose the the"BRAKE LAMP" mean??? (mattsnooz)
Low on fluid.
mkazm83 is offline   Reply With Quote
Old 05-08-2007, 04:20 PM   #8
TheWalrus
TheWalrus's Avatar
Send a message via AIM to TheWalrus
youre probly low on brake fluid...if its a brake light out, itll come on the first time you step on the pedal, but if it flickers when youre taking turns and *****, check the fluid level and for pad wear
95 Prelude - Theft recovery shell
92 Prelude - Donating parts ^
97 Protege - Gets me to work...slowly
TheWalrus is offline   Reply With Quote
Old 05-08-2007, 05:52 PM   #9
sivikvtec
sivikvtec's Avatar
Send a message via AIM to sivikvtec
Default Re: (TheWalrus)
I though the parking brake light came on when you were low on fluid. The Brake Lamp light is for bulb failure. It randomly comes on every now and then on my car.
sivikvtec is offline   Reply With Quote
Old 05-08-2007, 06:13 PM   #10
InvaderTrax
InvaderTrax's Avatar
Send a message via AIM to InvaderTrax
The light labeled Brake Lamp only comes on when you have a brake light out. The Brake light will come on if your parking brake is up (or bad sensor), or if you are low on brake fluid (again, or bad sensor). The ABS light will come on if you have a problem with your anti-lock brake system
Originally Posted by v8h8 View Post
Cool build! I cant really tell what is what from the pictures. I also like the fact that you have a KNN air filter, those are a must!!! Just swap for a V-TECH head and youll be set!
InvaderTrax is offline   Reply With Quote
Old 05-08-2007, 11:51 PM   #11
gavzter
gavzter's Avatar
Default Re: (InvaderTrax)
as said - it's the PARKING BRAKE / HAND BRAKE light that will flash on or stay on when you're low on brake fluid.
the BRAKE LAMP light should simply mean you have a brake light out.
However.. on my old 4th gen, all three lights: brake lamp, parking brake and abs light came on when I had a brake lamp fail Click the image to open in full size.
Gavz
Old 05-08-2007, 11:54 PM   #12
P13_mein
P13_mein's Avatar
Send a message via AIM to P13_mein
fix your rear brake lamp(s)
"Wow! your sh*t pulls man! whaddya do to it?"
"ahhm... bought it" http://images.honda-tech.com/set1/smile/emwink.gif
P13_mein is offline   Reply With Quote
Old 05-09-2007, 04:38 AM   #13
manbearpig
manbearpig's Avatar
Default Re: what dose the the"BRAKE LAMP" mean??? (P13_mein)
If they're all working, just pull the bulb. I rewired my led spoiler (it was cut when i got the car) and ever since then, it's been on. Even though all 3 lights work fine.
manbearpig is offline   Reply With Quote
Old 05-09-2007, 06:10 AM   #14
Yield
Yield's Avatar
I was getting the "brake lamp" light even though all my lights were working properly. I just changed my rear pads and it went away... whatever that means!
Yield is offline   Reply With Quote
Old 05-09-2007, 07:19 AM   #15
NtheWorks
NtheWorks's Avatar
Send a message via AIM to NtheWorks
same thing happens on mine. My right front rotor is pretty messed up though and I have it in my garage just havn't done it yet. Does the car really sense when your rotor or pads are bad while you're moving and not stepping on the brake?
I'm always looking for skilled people to do cheap work on my Prelude so PM me if you need some extra cash [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
NtheWorks is offline   Reply With Quote
Old 05-09-2007, 07:30 AM   #16
mkazm83
mkazm83's Avatar
Default Re: what dose the the"BRAKE LAMP" mean??? (NtheWorks)
The car "knows" because as your pads wear the piston pushes out. As it pushes out, the fluid level decreases. When its decreased below a preset level, the brake light tuns on.
Old 05-09-2007, 07:35 AM   #17
NtheWorks
NtheWorks's Avatar
Default Re: what dose the the"BRAKE LAMP" mean??? (mkazm83)
I replaced the pads and not the rotor. I know, dumb move, but maybe since the rotor is fairly thin it does the same thing?
Old 05-11-2007, 06:11 AM   #18
NirVTEC
NirVTEC's Avatar
This is the BRAKE LAMP Gremlin......Just deal with it if youve already tried everything else.
My comes and goes and its been that way through several fluid swps, pad swaps, bulb swaps........It add to my Dashboard Christmas Tree!
SRS
ABS
BRAKE LAMP
BRAKE
I am convinced the MORE lights you have on, the faster your car is! Click the image to open in full size.
I'M BAAAAAACK!
NirVTEC is offline   Reply With Quote
Old 05-11-2007, 11:40 AM   #19
Yield
Yield's Avatar
Maybe, but I'm not sure I buy it. I had my fluid up to the high mark before I did the pad swap and it light didn't disappear immediately after the pad swap. It took a week Click the image to open in full size.
Nirvtec - I also think it might just be a bad connection/relay/gremlin somewhere. Back when I first bought the car it would come on sometimes when it was really hot out. Anyway, it's gone now...
Old 05-11-2007, 04:48 PM   #20
TheWalrus
TheWalrus's Avatar
Default Re: what dose the the"BRAKE LAMP" mean??? (Yield)
the float in your reservoir may have been stuck at the bottom...thats why those 2 wires are on the lid
92, accord, board, brake, break, car, dash, flashes, flashing, flickers, honda, lamp, light, parking, prelude, whats
