FAQ: Low beam headlights don't work but high beams & parking lights do, what's wrong?
If your car is a 2001 or 2002, it could have been part of a NHTSA recall where the light switch terminal overheated and killed your low beams. Check out NHTSA recall 04V086000.
Text of the recall:
Report Date : May 4, 2007 at 10:32 PM
NHTSA Campaign ID number : 04V086000
Make / Models : Model/Build Years:
HONDA / CIVIC 2001-2002
HONDA / INSIGHT 2000-2002
Manufacturer : AMERICAN HONDA MOTOR CO.
NHTSA CAMPAIGN ID Number : 04V086000 Mfr's Report Date : FEB 24, 2004
Component: EXTERIOR LIGHTING:HEADLIGHTS
Potential Number Of Units Affected : 440000
Summary:
ON CERTAIN PASSENGER VEHICLES, THE LOW-BEAM TERMINAL ON THE HEAD LIGHT WIRE HARNESS CAN OVERHEAT AND COULD CAUSE THE LOW BEAMS TO FAIL WITHOUT WARNING.
Consequence:
AN UNEXPECTED LOSS OF LOW BEAMS COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL INSPECT THE HEAD LIGHT SWITCH AND COUPLER FOR SIGNS OF HEAT DAMAGE. IF HEAT DAMAGE IS PRESENT, THE DEALER WILL REPLACE THE SWITCH AND COUPLER. IF NO HEAT DAMAGE IS PRESENT, THE DEALER WILL REPLACE THE HEAD LIGHT SWITCH AND ONE MATING PIN IN THE COUPLER. OWNER NOTIFICATION BEGAN ON APRIL 5, 2004. OWNERS SHOULD CONTACT HONDA AT 1-800-999-1009.
Notes:
CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
If you think this covers your car, take your car to a Honda dealer. If your car is covered under the recall, Honda will replace your headlight switch at no charge.
2001 ES2
Reason: fixed code errors
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Honda-Tech.com content, comments, or advertising. Honda-Tech.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Honda-Tech.com in any way.
Copyright/trademark/sales mark infringements are not intended or implied.
