Codes: P0301, P0302, P0303, P300, P1399 help
Old 04-23-2007, 04:25 PM
gohonda's Avatar
Default Codes: P0301, P0302, P0303, P300, P1399 help
P0301- Cylinder 1 misfiring
P0302- cylinder 2 misfiring
P0303- cylinder 3 misfiring
P0300- random / multiple misfire detected.
P1399- Manufactures control Ignition system OR Misfire
ANYone have any ides how to fix this or where to start. The CEL blinks while driving right now!
car just had tune up: plugs, wires, distributor cap and rotor.
Old 04-23-2007, 04:29 PM
LoseRPunKx182's Avatar
Default Re: CODES: P0301, P0302, P0303, P300, P1399 HELP! (gohonda)
did u put the plug wires back on correctly and the firing order's correct?
Old 04-23-2007, 04:31 PM
nyrican23's Avatar
Default Re: CODES: P0301, P0302, P0303, P300, P1399 HELP! (LoseRPunKx182)
I got the same problem. I'm gonna start with replacing the spark plugs and check the wires. You might want to start there
Old 04-23-2007, 05:56 PM
Daisy... Daisy...
Dogginator's Avatar
Let's start with some questions.
When did this problem start? (Did you overrev with a misshift, etc.?)
Are the valves adjusted? Have you performed a compression check?
Is the timing adjusted?
What do the spark plugs look like?
Does the CEL blink only at low RPM or at all RPM?
Old 04-23-2007, 08:25 PM
ls19integra95's Avatar
Default Re: CODES: P0301, P0302, P0303, P300, P1399 HELP! (Dogginator)
sounds like your timing may be off...
Old 04-24-2007, 10:45 AM
gohonda's Avatar
Default Re: CODES: P0301, P0302, P0303, P300, P1399 HELP! (ls19integra95)
The CEL was on and then after a couple days started blinking.
No, I will search how to do this and do it ASAP.
No, I need to check the timing.
Spark plugs should be new. just had tune up.
All RPM.
Old 04-24-2007, 12:30 PM
Daisy... Daisy...
Dogginator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gohonda &raquo;</TD></TR><TR><TD CLASS="quote">Are the valves adjusted? Have you performed a compression check?
How to articles can be found here.
http://www.c-speedracing.com/howto.php
It is most likely your distributor. It is still best to check the other things first, as they are cheaper. If you have a spare distributor, you can try to swap it. be sure to check the timing with a timing light.
Old 04-24-2007, 11:27 PM
gohonda's Avatar
Hey in regards to checking the timing, can you check the timing on a 1998 integra?
i called a couple mechanics today and they said you can't adjust the timing on the 1998. So what does this mean? ? how do you check the timing?
Old 04-25-2007, 03:38 AM
Daisy... Daisy...
Dogginator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gohonda &raquo;</TD></TR><TR><TD CLASS="quote">i called a couple mechanics today and they said you can't adjust the timing on the 1998. So what does this mean?</TD></TR></TABLE>
It means get a new mechanic. Download a Helm manual for the procedure. (Search google for "hondahookup manuals". There is a 1998 manual posted there.) To check the timing, you basically warm the car, jumper the ECU jumper in the passenger kick panel (same jumper used to pull the CEL), check the timing on the crank pully with a timing light (white mark is 0 deg BTDC, red mark is 16 deg BTDC, use the white mark if the light has a degree adjustment), and adjust the distributor orientation until the timing is 16 +-2 deg BTDC.
C-speed has a link in the other link that I posted.
http://www.c-speedracing.com/h...g.php
Old 10-30-2007, 02:02 PM
all-mtr-teg's Avatar
Any suggestions, im getting the same 0301, 0303, 1300 and 1399 codes. Swapped dizzy and still got the same codes, got new plugs, valves adjustment and timing is at 14 BTDC. What else should i do?
Old 10-30-2007, 02:55 PM
* B A N N E D *
GRAF-FITI's Avatar
Default Re: CODES: P0301, P0302, P0303, P300, P1399 HELP! (all-mtr-teg)
shitty/dirty injectors....i've been there with these codes before, replaced plugs, wires, cap, rotor, coil, module....none of it worked
ran some Lucas injector cleaner/octane booster and it cleared it right up...for about4 months
when it happened again i replaced the injectors and it has been great ever since (a year and a half ago)
Old 10-30-2007, 02:59 PM
Default Re: CODES: P0301, P0302, P0303, P300, P1399 HELP! (GRAF-FITI)
Do dirty injectors cause a lean misfire because lack of gas?
Old 10-30-2007, 03:01 PM
* B A N N E D *
GRAF-FITI's Avatar
dirty injectors can cause all kinds of ****.....but i would HIGHLY recommend going to your local parts store and at least TRYING the lucas octane booster
it's a red bottle for like $9....i wouldn't recommened it if it didn't work....and i remember when i had this problem i searched after i replaced the ****, and got all kinds of stupid/irrelevant posts
now since i have experience i can tell YOU what worked for ME....i won't gaurantee it but can damn sure say it's worth a shot and probably will work
Old 10-31-2007, 07:28 AM
I dumped in some of that CRC emission pass and deleted the codes with my scanner, so far the CEL hasnt come on but it seems to just pop on when it feels like it. Sometimes as idle, sometimes while cruising on the freeway
* B A N N E D *
GRAF-FITI's Avatar
lol dude i didn't tell you to use the CRC emissions junk, i told you the red bottle lucas octane booster
Old 10-31-2007, 08:10 AM
i've been running the 104 octane booster for about 2 months, what's the difference between that and the lucas, does the lucas brand have more injector cleaner?
Old 10-31-2007, 08:30 AM
* B A N N E D *
GRAF-FITI's Avatar
lucas is higher concentrated
Old 10-31-2007, 08:45 AM
boostedh22lude1's Avatar
check ur dizzy/coil/plugs/wires with all those misfire codes its probably within those 4
Old 10-31-2007, 09:36 AM
All the research i've done led me to believe that the nos and the 104 outlaw had the highest octane boosting capability, what about just using the straight lucas injector cleaner? But anyways, i know its not the injectors cause this morning i swapped the injectors 1 and 3 with 2 and 4, and right now i just got another cylinder 1 and 3 misfire, unless its the actual injector harness that's bad
Old 10-31-2007, 09:38 AM
Default Re: CODES: P0301, P0302, P0303, P300, P1399 HELP! (boostedh22lude1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22lude1 &raquo;</TD></TR><TR><TD CLASS="quote">check ur dizzy/coil/plugs/wires with all those misfire codes its probably within those 4</TD></TR></TABLE>
Swapped dizzy, wires, new plugs, and injectors and still got the same codes, valves adjustment and timing is at 14 BTDC. What else should i do?
Old 02-25-2008, 07:17 PM
Blackice087's Avatar
i have the same problem with the codes p0304 and p0302 p1300 and p1399. i replaced my injectors all new wiring harness, new distributor spark plugs and wires. and still getting the same thing.
Old 02-25-2008, 07:37 PM
Default Re: CODES: P0301, P0302, P0303, P300, P1399 HELP! (Blackice087)
I replaced my crankshaft position sensor and 2 months later, no cels yet.
Old 05-27-2008, 07:17 PM
ChinitodeNJ's Avatar
replaced distributor, wires, and spark plugs. still nothing....i was going to change my injectors BUT after looking at the forum i dont think i want to spend money on something that isnt going to fix the problem. Has anyone actually come up with a gauranteed solution?
Old 05-27-2008, 07:33 PM
Default Re: CODES: P0301, P0302, P0303, P300, P1399 HELP! (ChinitodeNJ)
Mine recently came on again, so I am stumped. Luckily the CEL's popped on the day after I got her smogged. Safe for another 2 years.
Old 05-31-2008, 04:04 AM
anyone??
Quick Reply: Codes: P0301, P0302, P0303, P300, P1399 help
